How Itcertmaster will Help You in Passing the CBIC CIC Certification Exam?
Posted at 4/20/2026 07:51:04
View170
Replies0
BONUS!!! Download part of Itcertmaster CIC dumps for free: https://drive.google.com/open?id=1O7ip-LwTVuJKxCBKpwM4C2LtfQv8vIKF
On the other hand, those who do not score well can again try reading all the CBIC Certified Infection Control Exam (CIC) dumps questions and then give the CIC exam. This will help them polish their skills and clear all their doubts. Also, you must note down your CBIC Certified Infection Control Exam (CIC) practice test score every time you try the CBIC Exam Questions. It will help you keep a record of your study and how well you are doing in them.
Our CIC study practice guide takes full account of the needs of the real exam and conveniences for the clients. Our CIC certification questions are close to the real exam and the questions and answers of the test bank cover the entire syllabus of the real exam and all the important information about the exam. Our CIC Learning Materials can stimulate the real exam's environment to make the learners be personally on the scene and help the learners adjust the speed when they attend the real CIC exam.
CBIC CIC Valid Exam Dumps - CIC Online Lab SimulationIf you are forced to pass exams and obtain certification by your manger, our CIC original questions will be a good choice for you. Our products can help you clear exams at first shot. We promise that we provide you with best quality CIC original questions and competitive prices. We offer 100% pass products with excellent service. We provide one year studying assist service and one year free updates downloading of CBIC CIC Exam Questions. If you fail exam we support to exchange and full refund.
CBIC Certified Infection Control Exam Sample Questions (Q186-Q191):NEW QUESTION # 186
Which of the following pathogens is associated with the highest risk of seroconversion after percutaneous exposure?
- A. Syphilis
- B. Hepatitis C
- C. Hepatitis A
- D. Shigella
Among the listed pathogens,Hepatitis Chas thehighest risk of seroconversion following a percutaneous exposure, though it's important to note thatHepatitis Bactually has the highest overall risk. However, since Hepatitis B is not listed among the options, the correct choice from the available ones isHepatitis C.
* TheAPIC Textconfirms:
"The average risk of seroconversion after a percutaneous injury involving blood infected with hepatitis C virus is approximately 1.8 percent".
* The other options are not bloodborne pathogens typically associated with high seroconversion risks after needlestick or percutaneous exposure:
* A. Shigella- transmitted fecal-orally, not percutaneously.
* B. Syphilis- transmitted sexually or via mucous membranes.
* C. Hepatitis A- primarily fecal-oral transmission, low occupational seroconversion risk.
APIC Text, 4th Edition, Chapter 103 - Occupational Exposure to Bloodborne Pathogens
NEW QUESTION # 187
The BEST choice for surgical instrument cleaning and material compatibility is a detergent solution with:
- A. A neutral pH
- B. Sodium hypochlorite
- C. An acidic pH
- D. Quaternary ammonium compounds
The Certification Study Guide (6th edition) emphasizes that the primary goal of surgical instrument cleaning is to remove organic and inorganic soil while preserving the integrity and functionality of the instrument. For this reason, detergents with a neutral pH are considered the best choice for routine surgical instrument cleaning and material compatibility.
Neutral pH detergents are effective at removing blood, tissue, and other organic matter without causing corrosion, pitting, or degradation of metals, plastics, seals, and coatings commonly used in surgical instruments. The study guide notes that repeated exposure to harsh chemical environments can damage instruments, compromise device performance, and shorten instrument lifespan-ultimately affecting patient safety and increasing replacement costs.
Acidic detergents may be used selectively for removal of mineral deposits or water scale but are not appropriate for routine cleaning due to their corrosive potential. Sodium hypochlorite (bleach) is strongly discouraged for surgical instruments because it is highly corrosive and can rapidly damage stainless steel.
Quaternary ammonium compounds are low-level disinfectants and are not suitable for cleaning critical or semi-critical medical devices prior to disinfection or sterilization.
This question reflects a high-yield CIC exam principle: effective cleaning must balance soil removal with material compatibility. Neutral pH detergents best meet both requirements and are widely recommended by manufacturers and reprocessing standards for surgical instrumentation.
Reference: Certification Study Guide (CBIC/CIC Exam Study Guide), 6th edition, Chapter 10: Cleaning, Sterilization, Disinfection, and Asepsis.
NEW QUESTION # 188
A change in the disinfection protocol is indicated for which of the following scenarios?
- A. An enzymatic solution being used for rectal probes
- B. A high-level disinfectant being used for diaphragm fitting rings
- C. 2% glutaraldehyde being used for cryosurgical probes
- D. Sodium hypochlorite being used for blood pressure cuffs
The CBIC Certified Infection Control Exam Study Guide (6th edition) emphasizes the importance of applying Spaulding's classification to determine appropriate cleaning, disinfection, and sterilization levels for medical devices based on their intended use. According to this framework, rectal probes are classified as semi-critical devices because they come into contact with mucous membranes. Semi-critical devices require at least high- level disinfection after thorough cleaning.
An enzymatic solution, as listed in option C, is not a disinfectant. Enzymatic detergents are designed solely for cleaning, meaning they help remove organic material such as blood, mucus, and feces, but they do not kill microorganisms. Using an enzymatic solution alone for rectal probes is therefore inadequate and represents an improper disinfection practice, making this the scenario that clearly requires a protocol change.
Option A is acceptable because diaphragm fitting rings are noncritical devices that contact intact skin and may be safely processed using high-level disinfection. Option B is appropriate because blood pressure cuffs are noncritical items and can be disinfected using low- to intermediate-level disinfectants such as sodium hypochlorite. Option D is also appropriate, as cryosurgical probes are semi-critical devices and 2% glutaraldehyde is an accepted high-level disinfectant.
Recognizing the distinction between cleaning versus disinfection and applying the correct level of processing is a core competency for infection preventionists and a frequently tested concept on the CIC exam.
NEW QUESTION # 189
During an outbreak of ventilator-associated pneumonia (VAP), the infection preventionist should FIRST:
- A. Implement preemptive antibiotic therapy in all ventilated patients.
- B. Isolate all ventilated patients in negative pressure rooms.
- C. Review adherence to ventilator bundle elements.
- D. Perform bacterial cultures from ventilator circuits.
* Reviewing compliance with VAP prevention bundles (e.g., head-of-bed elevation, oral care, sedation breaks) is the first step in outbreak control.
* Preemptive antibiotics (B) are not recommended due to antibiotic resistance risks.
* Negative pressure rooms (C) are not required for VAP.
* Ventilator circuit cultures (D) do not guide patient management.
CBIC Infection Control References:
* APIC Text, "VAP Prevention Measures," Chapter 11.
NEW QUESTION # 190
An infection preventionist (IP) observes an increase in primary bloodstream infections in patients admitted through the Emergency Department. Poor technique is suspected when peripheral intravenous (IV) catheters are inserted. The IP should FIRST stratify infections by:
- A. Type of dressing used: gauze, CHG impregnated sponge, or transparent.
- B. Type of skin preparation used for the IV site: alcohol, CHG/alcohol, or iodophor.
- C. Site of insertion: hand, forearm, or antecubital fossa.
- D. Location of IV insertion: pre-hospital, Emergency Department, or in-patient unit.
When an infection preventionist (IP) identifies an increase in primary bloodstream infections (BSIs) associated with peripheral intravenous (IV) catheter insertion, the initial step in outbreak investigation and process improvement is to stratify the data to identify potential sources or patterns of infection. According to the Certification Board of Infection Control and Epidemiology (CBIC), the "Surveillance and Epidemiologic Investigation" domain emphasizes the importance of systematically analyzing data to pinpoint contributing factors, such as location, technique, or equipment use, in healthcare-associated infections (HAIs). The question specifies poor technique as a suspected cause, and the first step should focus on contextual factors that could influence technique variability.
Option A, stratifying infections by the location of IV insertion (pre-hospital, Emergency Department, or in- patient unit), is the most logical first step. Different settings may involve varying levels of training, staffing, time pressure, or adherence to aseptic technique, all of which can impact infection rates. For example, pre- hospital settings (e.g., ambulance services) may have less controlled environments or less experienced personnel compared to in-patient units, potentially leading to technique inconsistencies. The CDC's Guidelines for the Prevention of Intravascular Catheter-Related Infections (2017) recommend evaluating the context of catheter insertion as a critical initial step in investigating BSIs, making this a priority for the IP to identify where the issue is most prevalent.
Option B, stratifying by the type of dressing used (gauze, CHG impregnated sponge, or transparent), is important but should follow initial location-based analysis. Dressings play a role in maintaining catheter site integrity and preventing infection, but their impact is secondary to the insertion technique itself. Option C, stratifying by the site of insertion (hand, forearm, or antecubital fossa), is also relevant, as anatomical sites differ in infection risk (e.g., the hand may be more prone to contamination), but this is a more specific factor to explore after broader contextual data is assessed. Option D, stratifying by the type of skin preparation used (alcohol, CHG/alcohol, or iodophor), addresses antiseptic efficacy, which is a key component of technique.
However, without first understanding where the insertions occur, it's premature to focus on skin preparation alone, as technique issues may stem from systemic factors across locations.
The CBIC Practice Analysis (2022) supports a stepwise approach to HAI investigation, starting with broad stratification (e.g., by location) to guide subsequent detailed analysis (e.g., technique-specific factors). This aligns with the CDC's hierarchical approach to infection prevention, where contextual data collection precedes granular process evaluation. Therefore, the IP should first stratify by location to establish a baseline for further investigation.
* CBIC Practice Analysis, 2022.
* CDC Guidelines for the Prevention of Intravascular Catheter-Related Infections, 2017.
NEW QUESTION # 191
We put high emphasis on the protection of our customers personal data and fight against criminal actson our CIC exam questions. Our CIC preparation exam is consisted of a team of professional experts and technical staff, which means that you can trust our security system with whole-heart. As for your concern about the network virus invasion, CIC Learning Materials guarantee that our purchasing channel is absolutely worthy of your trust.
CIC Valid Exam Dumps: https://www.itcertmaster.com/CIC.html
The web-based CBIC Certified Infection Control Exam (CIC) practice exam is accessible from any major OS, But most of the CBIC CIC Valid Exam Dumps CIC Valid Exam Dumps exam demos are worthless for the real exam preparation, We will provide you with three different versions of our CIC exam questions on our test platform: PDF, software and APP versions, Our Company is always striving to develop not only our CIC latest practice dumps, but also our service because we know they are the aces in the hole to prolong our career.
Apps for mobile platforms might seem simple, but they're far from it, The Macro Recorder Doesn't Work, The web-based CBIC Certified Infection Control Exam (CIC) practice exam is accessible from any major OS.
But most of the CBIC Infection Control exam demos are worthless for the real exam preparation, We will provide you with three different versions of our CIC exam questions on our test platform: PDF, software and APP versions.
Quiz CIC - CBIC Certified Infection Control Exam High Hit-Rate Reliable Study MaterialsOur Company is always striving to develop not only our CIC latest practice dumps, but also our service because we know they are the aces in the hole to prolong our career.
We always take our candidates' benefits CIC as the priority, so you can trust us without any hesitation.
- CIC Actual Questions ⛺ CIC Latest Test Simulations 🥶 CIC Valid Mock Exam 🧵 Easily obtain free download of { CIC } by searching on [url]www.pdfdumps.com 🍤CIC Interactive Questions[/url]
- Positive CIC Feedback 🚤 Latest CIC Test Objectives 🟠 CIC Latest Test Simulations 🍂 Open website ☀ [url]www.pdfvce.com ️☀️ and search for ➥ CIC 🡄 for free download 🔃CIC Real Braindumps[/url]
- CIC Latest Exam Answers 👺 CIC Real Braindumps 😣 Test CIC Simulator 👊 Search for ➡ CIC ️⬅️ and easily obtain a free download on ➠ [url]www.pass4test.com 🠰 👉CIC Real Braindumps[/url]
- 100% Pass Quiz 2026 CBIC Trustable CIC Reliable Study Materials 🙁 Search for ➤ CIC ⮘ and download exam materials for free through ➤ [url]www.pdfvce.com ⮘ 📒Regualer CIC Update[/url]
- CBIC Offers Valid and Real CBIC CIC Exam Questions 👽 Search for ➽ CIC 🢪 and easily obtain a free download on [ [url]www.prep4sures.top ] 📐CIC Valid Exam Pass4sure[/url]
- 2026 CIC Reliable Study Materials 100% Pass | Professional CIC: CBIC Certified Infection Control Exam 100% Pass 🎦 Download ☀ CIC ️☀️ for free by simply entering [url]www.pdfvce.com website 🥂Exam Dumps CIC Pdf[/url]
- Authoritative CBIC Reliable Study Materials C High Hit Rate CIC Valid Exam Dumps 🏅 Download ✔ CIC ️✔️ for free by simply entering ⇛ [url]www.examdiscuss.com ⇚ website 🧩CIC Valid Exam Pass4sure[/url]
- CIC Complete Exam Dumps ⬅ CIC Certification Dumps 😵 CIC Latest Test Simulations 🔮 Download CIC for free by simply searching on ➡ [url]www.pdfvce.com ️⬅️ 💞Valid Exam CIC Blueprint[/url]
- CIC Certification Dumps 🍡 Test CIC Simulator 😓 Latest CIC Test Objectives 🧓 Search for ✔ CIC ️✔️ and download exam materials for free through [url]www.exam4labs.com 🤕CIC New Practice Questions[/url]
- CIC Reliable Study Materials - Leader in qualification Exams - CBIC CBIC Certified Infection Control Exam 🏤 Open { [url]www.pdfvce.com } and search for { CIC } to download exam materials for free 🎉Regualer CIC Update[/url]
- CIC Valid Exam Pass4sure 🛹 Exam Dumps CIC Pdf 🃏 CIC Interactive Questions 🖼 Easily obtain ▛ CIC ▟ for free download through ☀ [url]www.practicevce.com ️☀️ 🔗Latest CIC Test Objectives[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, mentor.khai.edu, reikicaricias.com, www.stes.tyc.edu.tw, coursecrafts.in, faithlife.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BTW, DOWNLOAD part of Itcertmaster CIC dumps from Cloud Storage: https://drive.google.com/open?id=1O7ip-LwTVuJKxCBKpwM4C2LtfQv8vIKF
