[General] SPLK-5002學習筆記 & SPLK-5002考試重點
38
【General】 SPLK-5002學習筆記 & SPLK-5002考試重點
Posted at 10 hour before      View:7 | Replies:0        Print      Only Author   [Copy Link] 1#
Fast2test提供有保證的題庫資料,以提高您的Splunk SPLK-5002考試的通過率,您可以認識到我們產品的真正價值。如果您想參加SPLK-5002考試,請選擇我們最新的SPLK-5002題庫資料,該題庫資料具有針對性,不僅品質是最高的,而且內容是最全面的。對于那些沒有充分的時間準備考試的考生來說,Splunk SPLK-5002考古題就是您唯一的、也是最好的選擇,這是一個高效率的學習資料,SPLK-5002可以讓您在短時間內為考試做好充分的準備。
Splunk SPLK-5002 考試大綱:
主題簡介
主題 1
  • Building Effective Security Processes and Programs: This section targets Security Program Managers and Compliance Officers, focusing on operationalizing security workflows. It involves researching and integrating threat intelligence, applying risk and detection prioritization methodologies, and developing documentation or standard operating procedures (SOPs) to maintain robust security practices.
主題 2
  • Automation and Efficiency: This section assesses Automation Engineers and SOAR Specialists in streamlining security operations. It covers developing automation for SOPs, optimizing case management workflows, utilizing REST APIs, designing SOAR playbooks for response automation, and evaluating integrations between Splunk Enterprise Security and SOAR tools.
主題 3
  • Detection Engineering: This section evaluates the expertise of Threat Hunters and SOC Engineers in developing and refining security detections. Topics include creating and tuning correlation searches, integrating contextual data into detections, applying risk-based modifiers, generating actionable Notable Events, and managing the lifecycle of detection rules to adapt to evolving threats.
主題 4
  • Data Engineering: This section of the exam measures the skills of Security Analysts and Cybersecurity Engineers and covers foundational data management tasks. It includes performing data review and analysis, creating and maintaining efficient data indexing, and applying Splunk methods for data normalization to ensure structured and usable datasets for security operations.
主題 5
  • Auditing and Reporting on Security Programs: This section tests Auditors and Security Architects on validating and communicating program effectiveness. It includes designing security metrics, generating compliance reports, and building dashboards to visualize program performance and vulnerabilities for stakeholders.
最受推薦的SPLK-5002學習筆記,真實還原Splunk SPLK-5002考試內容Fast2test不僅能為那你節約寶貴的時間,還可以讓你安心地參加考試以及順利的通過。Fast2test具有很好的可靠性,在專業IT行業人士中有很高的聲譽。你可以通過免費下載我們的Fast2test提供的部分關於Splunk SPLK-5002考題及答案作為嘗試來確定我們的可靠性,相信你會很滿意的。我對我們Fast2test的產品有信心,相信很快Fast2test的關於Splunk SPLK-5002考題及答案就會成為你的不二之選。你也會很快很順利的通過Splunk SPLK-5002的認證考試。選擇我們Fast2test是明智的,Fast2test會是你想要的滿意的產品。
最新的 Cybersecurity Defense Analyst SPLK-5002 免費考試真題 (Q88-Q93):問題 #88
When building detections using the Authentication Data Model, which values are recommended for use against the actions field?
  • A. success, denied, pending, error
  • B. success, failure, pending, error
  • C. allowed, blocked, processing, error
  • D. allowed, blocked, teardown, error
答案:B
解題說明:
In the Authentication Data Model, the recommended values for the action field are success, failure, pending, and error. These standardized values ensure consistent mapping across authentication data sources for accurate detection and reporting.
問題 #89
A threat actor group has begun a campaign that is relevant to an organization. How can the organization's engineer raise the risk score for corresponding intelligence matches in the applicable threat collection?
  • A. Set the weight of the threat collection to a higher integer.
  • B. Set the weight of the threat collection to a lower integer.
  • C. Set the weight of the threat collection to 500.
  • D. Set the weight of the threat collection to 0.
答案:A
解題說明:
In Splunk Enterprise Security, increasing the threat collection weight raises the resulting risk score for any indicators matched from that collection. This allows the organization to prioritize intelligence associated with active or relevant threat actor campaigns.
問題 #90
What is the primary purpose of correlation searches in Splunk?
  • A. To store pre-aggregated search results
  • B. To identify patterns and relationships between multiple data sources
  • C. To extract and index raw data
  • D. To create dashboards for real-time monitoring
答案:B
解題說明:
Correlation searches in Splunk Enterprise Security (ES) are a critical component of Security Operations Center (SOC) workflows, designed to detect threats by analyzing security data from multiple sources.
Primary Purpose of Correlation Searches:
Identify threats and anomalies: They detect patterns and suspicious activity by correlating logs, alerts, and events from different sources.
Automate security monitoring: By continuously running searches on ingested data, correlationsearches help reduce manual efforts for SOC analysts.
Generate notable events: When a correlation search identifies a security risk, it creates a notable event in Splunk ES for investigation.
Trigger security automation: In combination with Splunk SOAR, correlation searches can initiate automated response actions, such as isolating endpoints or blocking malicious IPs.
Since correlation searches analyze relationships and patterns across multiple data sources to detect security threats, the correct answer is B. To identify patterns and relationships between multiple data sources.
Splunk ES Correlation Searches Overview
Best Practices for Correlation Searches
Splunk ES Use Cases and Notable Events
問題 #91
What is the primary purpose of data indexing in Splunk?
  • A. To secure data from unauthorized access
  • B. To visualize data using dashboards
  • C. To store raw data and enable fast search capabilities
  • D. To ensure data normalization
答案:C
解題說明:
Understanding Data Indexing in Splunk
In Splunk Enterprise Security (ES) and Splunk SOAR, data indexing is a fundamental process that enables efficient storage, retrieval, and searching of data.
#Why is Data Indexing Important?
Stores raw machine data (logs, events, metrics) in a structured manner.
Enables fast searching through optimized data storage techniques.
Uses an indexer to process, compress, and store data efficiently.
Why the Correct Answer is B?
Splunk indexes data to store it efficiently while ensuring fast retrieval for searches, correlation searches, and analytics.
It assigns metadata to indexed events, allowing SOC analysts to quickly filter and search logs.
#Incorrect Answers & Explanations
A: To ensure data normalization # Splunk normalizes data using Common Information Model (CIM), not indexing.
C: To secure data from unauthorized access # Splunk uses RBAC (Role-Based Access Control) and encryption for security, not indexing.
D: To visualize data using dashboards # Dashboards use indexed data for visualization, but indexing itself is focused on data storage and retrieval.
#Additional Resources:
Splunk Data Indexing Documentation
Splunk Architecture & Indexing Guide
問題 #92
What is a key advantage of using SOAR playbooks in Splunk?
  • A. Automating repetitive security tasks and processes
  • B. Manually running searches across multiple indexes
  • C. Enhancing data retention policies
  • D. Improving dashboard visualization capabilities
答案:A
解題說明:
Splunk SOAR (Security Orchestration, Automation, and Response) playbooks help SOC teams automate, orchestrate, and respond to threats faster.
#Key Benefits of SOAR Playbooks
Automates Repetitive Tasks
Reduces manual workload for SOC analysts.
Automates tasks like enriching alerts, blocking IPs, and generating reports.
Orchestrates Multiple Security Tools
Integrates with firewalls, EDR, SIEMs, threat intelligence feeds.
Example: A playbook can automatically enrich an IP address by querying VirusTotal, Splunk, and SIEM logs.
Accelerates Incident Response
Reduces Mean Time to Detect (MTTD) and Mean Time to Respond (MTTR).
Example: A playbook can automatically quarantine compromised endpoints in CrowdStrike after an alert.
#Incorrect Answers:
A: Manually running searches across multiple indexes # SOAR playbooks are about automation, not manual searches.
C: Improving dashboard visualization capabilities # Dashboards are part of SIEM (Splunk ES), not SOAR playbooks.
D: Enhancing data retention policies # Retention is a Splunk Indexing feature, not SOAR-related.
Splunk SOAR Playbook Guide
Automating Threat Response with SOAR
問題 #93
Fast2test的SPLK-5002考古題是經過眾多考生檢驗過的資料,可以保證有很高的成功率。如果你用過考古題以後仍然沒有通過考試,Fast2test會全額退款。或者你也可以選擇為你免費更新考試考古題。有了這樣的保障,實在沒有必要擔心了。
SPLK-5002考試重點: https://tw.fast2test.com/SPLK-5002-premium-file.html
