100% Pass 2026 H12-811_V2.0: Reliable HCIA-Datacom V2.0 Trusted Exam Resource
38
Posted at yesterday 10:00      View:10 | Replies:0        Print      Only Author   [Copy Link] 1#
Just like the old saying goes, there is no royal road to success, and only those who do not dread the fatiguing climb of gaining its numinous summits. In a similar way, there is no smoothly paved road to the H12-811_V2.0 Certification. You have to work on it and get started from now. If you want to gain the related certification, it is very necessary that you are bound to spend some time on carefully preparing for the Huawei exam, including choosing the convenient and practical study materials, sticking to study and keep an optimistic attitude and so on.
Don't underestimate the difficulty level of the Huawei H12-811_V2.0 certification exam because it is not easy to clear. You need to prepare real H12-811_V2.0 exam questions to get success. If you do not prepare with actual H12-811_V2.0 Questions, there are chances that you may fail the final and not get the H12-811_V2.0 certification.
New H12-811_V2.0 Trusted Exam Resource | High-quality Huawei H12-811_V2.0: HCIA-Datacom V2.0 100% PassFor candidates who want to evaluate and enhance their Huawei H12-811_V2.0 Test Preparation online, the web-based practice test is a perfect choice. You can attempt our 60 Huawei web-based practice exam whenever it suits you because it is accessible from any location with an internet connection. This HCIA-Datacom V2.0 browser-based practice exam helps you overcome exam fear as it simulates the environment of the real test.
Huawei HCIA-Datacom V2.0 Sample Questions (Q50-Q55):NEW QUESTION # 50
With the continuous development of AI, data center application scenarios are gradually divided into general- purpose computing and intelligent computing scenarios. Data centers need to ensure service continuity of general-purpose computing clusters while unleashing the full potential of intelligent computing clusters, so as to guarantee stable and efficient operation in the AI era. Which of the following statements are true about the service requirements of data center networks in the two scenarios? (Select all that apply)
  • A. The intelligent computing network requires ultra-low latency, including the latency of data transmission within a compute node. The latency can be further reduced by using the RoCE protocol.
  • B. The general-purpose computing network requires high network stability and efficiency. Technologies such as M-LAG can be used to implement fast failover, and VXLAN can be deployed to build a large Layer 2 network for VM migration.
  • C. The intelligent computing network requires zero packet loss, which necessitates the deployment of various lossless network technologies such as PFC and ECN.
  • D. The general-purpose computing network demands a well-defined hierarchy, adopting a core- aggregation-access three-layer architecture.
The correct statements are B and C . Option B is true because general-purpose computing data center networks focus heavily on stability, reliability, service continuity, and flexible VM deployment. Technologies such as M-LAG improve gateway and uplink redundancy and support fast failover, while VXLAN enables large-scale Layer 2 extension for VM mobility and resource flexibility.
Option C is also true because intelligent computing networks, especially those serving AI training and distributed GPU clusters, require an extremely low-loss or lossless forwarding environment. Technologies such as PFC and ECN are standard methods used to build such networks and reduce congestion-related packet loss. Option A is not selected because modern general-purpose data center networks do not necessarily require the traditional core-aggregation-access three-layer architecture ; contemporary data centers commonly use leaf-spine fabrics instead. Option D is not selected because although intelligent computing networks do require ultra-low latency and RoCE helps reduce network communication latency, the wording about "latency of data transmission within a compute node" is not the standard network-side requirement emphasized in HCIA-Datacom. The focus is mainly on inter-node network transport efficiency and lossless forwarding.
NEW QUESTION # 51
On the OSPF network shown in the figure, all IP addresses can communicate with each other. Then the following configurations are added on R1:
[R1] acl 3000
[R1-acl4-advance-3000] rule deny ip source 10.0.1.1 0.0.0.0
[R1-acl4-advance-3000] rule deny ip source 10.1.1.1 0.0.0.0
[R1-acl4-advance-3000] rule permit ip source 10.3.1.1 0.0.0.0
[R1-acl4-advance-3000] quit
[R1] traffic classifier test
[R1-classifier-test] if-match acl 3000
[R1-classifier-test] quit
[R1] traffic behavior test
[R1-behavior-test] permit
[R1-behavior-test] quit
[R1] traffic policy test
[R1-trafficpolicy-test] classifier test behavior test
[R1-trafficpolicy-test] quit
[R1] interface GE 0/0/1
[R1-GE0/0/1] traffic-policy test outbound
[R1-GE0/0/1] quit
Which IP addresses of S1 can successfully ping 10.0.23.3? (Select all that apply)
  • A. 10.1.1.1
  • B. 10.2.1.1
  • C. 10.0.1.1
  • D. 10.3.1.1
Answer: A,B,C,D
All four addresses can successfully ping 10.0.23.3, so the correct answer is A, B, C, D .
The key point is that the traffic policy is applied outbound on GE0/0/1 of R1, which is the interface facing S1
. When S1 pings 10.0.23.3, the echo request travels from S1 to R1 and then to S2. The return echo reply from
10.0.23.3 comes back to R1 and is then sent outbound on GE0/0/1 toward S1. Therefore, the traffic policy examines the reply packets , not the original ping request packets.
In those reply packets, the source IP address is 10.0.23.3 , and the destination is one of S1's loopback addresses. The ACL rules denying 10.0.1.1 and 10.1.1.1 as source addresses do not match these reply packets, because those addresses appear as destination addresses , not source addresses. In addition, the ACL contains rule permit ip, which permits all remaining IP traffic. As a result, replies to all four S1 addresses are forwarded successfully, so every listed address can ping 10.0.23.3.
NEW QUESTION # 52
OSPF supports the division of a network into areas, each identified by an area ID that ranges from 0 to 255.
Area 0 is designated as the backbone area.
  • A. FALSE
  • B. TRUE
This statement is false because although Area 0 is indeed the backbone area , the statement about the area ID range is incorrect. In OSPF, the area ID is a 32-bit value , which can be represented either in decimal format or in IPv4 address format such as 0.0.0.0. It is not limited to the numeric range 0 to 255 .
For example, an area can be configured as 0, 1, 100, or in dotted-decimal form such as 0.0.0.1 or 0.0.0.10, depending on implementation and configuration style. HCIA-Datacom teaches that OSPF uses hierarchical area design to improve scalability, reduce SPF calculation scope, and optimize LSA flooding. The backbone area , which is Area 0, serves as the transit area connecting all non-backbone areas in a standard OSPF design. Therefore, the second part of the statement is correct, but the first part is wrong, making the entire statement false. This question tests whether the learner understands both the function of Area 0 and the actual format of OSPF area identifiers.
NEW QUESTION # 53
During WLAN deployment, a Fit AP fails to go online on the WAC. You log in to the WAC and run the display ap online-fail-record command to locate the fault. The command output shows that the cause is Insufficient license resources . This means that the license resources on the WAC are insufficient and that you need to expand the license capacity.
  • A. TRUE
  • B. FALSE
This statement is true . On a Huawei WAC, the number of APs that can go online is controlled by the available license resources . If a Fit AP fails to come online and the command display ap online-fail-record shows Insufficient license resources , it means the controller does not currently have enough licensed capacity to allow additional APs to register successfully.
In this case, the administrator must expand the license capacity or adjust existing license allocation so that the AP can be admitted. This is a common WLAN deployment issue, especially when new APs are added without first verifying the current AP license limit on the WAC. HCIA-Datacom troubleshooting methodology emphasizes interpreting controller diagnostics and fault records accurately. An AP can fail to go online for many reasons, including CAPWAP reachability problems, version mismatch, authentication issues, or licensing limitations. When the failure reason explicitly indicates insufficient license resources, the troubleshooting direction is clear: the controller's AP license capacity must be checked and, if necessary, increased. This question tests the ability to map a specific WAC alarm record to the correct operational response.
NEW QUESTION # 54
Assume that the IP address of GE0/0/0 on R1 is 10.0.12.1/24. Multiple commands can be used to enable OSPF on this interface. Match the commands with their configuration views.
ospf 1 # [R1]
area 0 # [R1-ospf-1]
network 10.0.12.1 0.0.0.0 # [R1-ospf-1-area-0.0.0.0]
ospf enable 1 area 0 # [R1-GE0/0/0]
Huawei devices support two common ways to enable OSPF on an interface.
The first method is the process-based method . In this method, you first enter system view, then enter the OSPF process view using ospf 1, so this command belongs to [R1] . After that, you enter the area view using area 0, so this command belongs to [R1-ospf-1] . Inside the area view, the command network 10.0.12.1
0.0.0.0 is used to match the interface with IP address 10.0.12.1, so it belongs to [R1-ospf-1-area-0.0.0.0] .
The second method is the interface-based method . In this method, OSPF is enabled directly under the interface using ospf enable 1 area 0, so this command belongs to [R1-GE0/0/0] .
This question tests the difference between global OSPF process configuration and direct interface OSPF enabling , both of which are standard Huawei OSPF configuration methods.
NEW QUESTION # 55
The HCIA-Datacom V2.0 prep torrent that we provide is compiled elaborately and highly efficient. You only need 20-30 hours to practice our H12-811_V2.0 exam torrent and then you can attend the exam. For most of our customers, who are busy with their jobs or other things. But if they use our H12-811_V2.0 test prep, they won't need so much time to prepare the exam and master exam content in a short time. What they need to do is just to spare 1-2 hours to learn and practice every day and then pass the exam with H12-811_V2.0 Test Prep easily. It costs them little time and energy to pass the exam.
Reliable H12-811_V2.0 Test Review: https://www.passleadervce.com/HCIA-Datacom/reliable-H12-811_V2.0-exam-learning-guide.html
Huawei H12-811_V2.0 Trusted Exam Resource For we have successfully help tens of thousands of candidates achieve their aims, H12-811_V2.0 effective exam dumps are significance for studying and training, We provide actual H12-811_V2.0 questions pdf dumps also for quick practice, Huawei H12-811_V2.0 Trusted Exam Resource Efficient study material, Huawei H12-811_V2.0 Trusted Exam Resource Besides, we offer the money refund policy, in case of failure, you can ask for full refund.
It takes hard work sustained over time with effective implementation of better practices, You can download our H12-811_V2.0 Test Questions at any time, For we have successfully help tens of thousands of candidates achieve their aims.
100% Pass Quiz 2026 Huawei Fantastic H12-811_V2.0: HCIA-Datacom V2.0 Trusted Exam ResourceH12-811_V2.0 effective exam dumps are significance for studying and training, We provide actual H12-811_V2.0 questions pdf dumps also for quick practice, Efficient study material.
Besides, we offer the money refund H12-811_V2.0 policy, in case of failure, you can ask for full refund.
