[Hardware] Free PDF Quiz CompTIA - CAS-005 - Unparalleled Exam Cram CompTIA SecurityX Certi
26
Hardware Free PDF Quiz CompTIA - CAS-005 - Unparalleled Exam Cram CompTIA SecurityX Certi
Posted at 4/20/2026 10:46:41      View171 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 CompTIA CAS-005 dumps are available on Google Drive shared by PassReview: https://drive.google.com/open?id=1AEdqV-DBs_-L3fjuZQcK8cm9tOqlSySk
If you buy and use the CAS-005 study materials from our company, you can complete the practice tests in a timed environment, receive grades and review test answers via video tutorials. You just need to download the software version of our CAS-005 Study Materials after you buy our study materials. You will have the right to start to try to simulate the real examination. We believe that the CAS-005 study materials from our company will not let you down.
CompTIA CAS-005 Exam Syllabus Topics:
  • Governance, Risk, and Compliance: This section of the exam measures the skills of CompTIA security architects that cover the implementation of governance components based on organizational security requirements, including developing policies, procedures, and standards. Candidates will learn about managing security programs, including awareness training on phishing and social engineering.
  • Security Engineering: This section measures the skills of CompTIA security architects that involve troubleshooting common issues related to identity and access management (IAM) components within an enterprise environment. Candidates will analyze requirements to enhance endpoint and server security while implementing hardware security technologies. This domain also emphasizes the importance of advanced cryptographic concepts in securing systems.
  • Security Architecture: This domain focuses on analyzing requirements to design resilient systems, including the configuration of firewalls and intrusion detection systems.
  • Security Operations: This domain is designed for CompTIA security architects and covers analyzing data to support monitoring and response activities, as well as assessing vulnerabilities and recommending solutions to reduce attack surfaces. Candidates will apply threat-hunting techniques and utilize threat intelligence concepts to enhance operational security.
Exam CAS-005 Preparation - Reliable CAS-005 Dumps EbookTo pass the CompTIA CAS-005 exam on the first try, candidates need CompTIA SecurityX Certification Exam updated practice material. Preparing with real CAS-005 exam questions is one of the finest strategies for cracking the exam in one go. Students who study with CompTIA CAS-005 Real Questions are more prepared for the exam, increasing their chances of succeeding. Finding original and latest CAS-005 exam questions however, is a difficult process. Candidates require assistance finding the CAS-005 updated questions.
CompTIA SecurityX Certification Exam Sample Questions (Q168-Q173):NEW QUESTION # 168
An analyst wants to conduct a risk assessment on a new application that is being deployed.
Given the following information:
- Total budget allocation for the new application is unavailable.
- Recovery time objectives have not been set.
- Downtime loss calculations cannot be provided.
Which of the following statements describes the reason a qualitative assessment is the best option?
  • A. The organization wants to find the monetary value of any outages.
  • B. The analyst has previous work experience in application development.
  • C. Sufficient metrics are not available to conduct other risk assessment types.
  • D. An organizational risk register tracks all risks and mitigations across business units.
A qualitative risk assessment is appropriate when quantitative data such as budget, downtime costs, or RTOs are unavailable. It relies on expert judgment, likelihood, and impact categories rather than precise metrics, making it the best option in this scenario.
NEW QUESTION # 169
An organization determined its preparedness for a ransomware attack is inadequate. A security administrator is working on ways to improve and monitor the organization's response to ransomware attacks. Which of the following is the best action for the administrator to take?
  • A. Define the recovery point objective.
  • B. Perform a business impact analysis.
  • C. Verify the encryption key length.
  • D. Conduct backup testing.
NEW QUESTION # 170
A security analyst reviews network logs and notices a large number of domain name queries originating from an internal server for an unknown domain, similar to the following:
2736287327321782.hgQ43jsi23-y.com
0357320932922C91.hgQ43jsu23Ty.com
4042301801399103.hgQ43jsu23Ly.com
Which of the following should the analyst do next?
  • A. Add the host names to a block list.
  • B. Browse for a website on the requested domain.
  • C. Reconfigure the server's DNS settings.
  • D. Check for data exfiltration.
A high volume of DNS queries to unknown domains may indicate domain generation algorithm (DGA) activity associated with malware.
Checking for data exfiltration is the next logical step to determine if sensitive data is being leaked to these domains.
Reconfiguring DNS settings, browsing unknown domains, or blocking the domains are reactive steps that do not address the root cause.
NEW QUESTION # 171
SIMULATION
[Security Architecture]
You are a security analyst tasked with interpreting an Nmap scan output from company's privileged network.
The company's hardening guidelines indicate the following:
There should be one primary server or service per device.
Only default ports should be used.
Non-secure protocols should be disabled.
INSTRUCTIONS
Using the Nmap output, identify the devices on the network and their roles, and any open ports that should be closed.
For each device found by Nmap, add a device entry to the Devices Discovered list, with the following information:
The IP address of the device
The primary server or service of the device (Note that each IP should by associated with one service/port only) The protocol(s) that should be disabled based on the hardening guidelines (Note that multiple ports may need to be closed to comply with the hardening guidelines) If at any time you would like to bring back the initial state of the simulation, please click the Reset All button.
See explanation below
10.1.45.65 SFTP ServerDisable 8080
10.1.45.66 Email Server Disable 415 and 443
10.1.45.67 Web Server Disable 21, 80
10.1.45.68 UTM Appliance Disable 21
NEW QUESTION # 172
A security engineer would like to control configurations on mobile devices while fulfilling the following requirements:
- Support and control Apple and Android devices.
- The device must be corporate-owned.
Which of the following would enable the engineer to meet these requirements? (Choose two.)
  • A. Update policy to prohibit the use of BYOD devices.
  • B. Implement a captive portal solution.
  • C. Implement an MDM solution.
  • D. Create a group policy to lock down mobile devices.
  • E. Implement a RADIUS solution.
  • F. Update verbiage in the acceptable use policy for the internet.
Implement an MDM solution (Mobile Device Management): An MDM solution is specifically designed to manage, monitor, and secure mobile devices. It allows organizations to enforce configuration policies, enforce encryption, restrict apps, and control access to corporate resources on both Apple and Android devices. This solution directly meets the requirement to support and control corporate-owned devices.
Update policy to prohibit the use of BYOD devices: By prohibiting the use of Bring Your Own Device (BYOD) devices, the organization ensures that only corporate-owned devices are used, fulfilling the requirement that the devices must be corporate-owned. This policy helps maintain control over the mobile devices within the organization's environment.
NEW QUESTION # 173
We know how expensive it is to take CAS-005 exam. It costs both time and money. However, with the most reliable exam dumps material from PassReview, we guarantee that you will pass the CAS-005 exam on your first try! Youve heard it right. We are so confident about our CAS-005 Exam Dumps for CompTIA CAS-005 exam that we are offering a money back guarantee, if you fail. Yes you read it right, if our CAS-005 exam braindumps didnt help you pass, we will issue a refund - no other questions asked.
Exam CAS-005 Preparation: https://www.passreview.com/CAS-005_exam-braindumps.html
BTW, DOWNLOAD part of PassReview CAS-005 dumps from Cloud Storage: https://drive.google.com/open?id=1AEdqV-DBs_-L3fjuZQcK8cm9tOqlSySk
