[General] C-THR82-2505 Hot Spot Questions, Exam C-THR82-2505 Question
38
【General】 C-THR82-2505 Hot Spot Questions, Exam C-THR82-2505 Question
Posted at 5 hour before      View:5 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that Real4Prep C-THR82-2505 dumps now are free: https://drive.google.com/open?id=1UPaYuDEk2xRng2D75ZeCtPQxM962RYZq
Whatever may be the reason to leave your job, if you have made up your mind, there is no going back. By getting the SAP C-THR82-2505 Certification, you can avoid thinking about negative things, instead, you can focus on the positive and bright side of taking this step and find a new skill set to improve your chances of getting your dream job.
Thus, you can see how a single decision can bring a lot of positive and fruitful changes in your life. However, if you are thinking about what if you were not able to get the SAP C-THR82-2505 certification or pass the SAP Certified Associate - SAP SuccessFactors Performance and Goals (C-THR82-2505) exam? Don't worry, you will find it easy to adjust to this new thing and get complete support from the Real4Prep who offer SAP C-THR82-2505 Exam Questions and practice exams for the SAP C-THR82-2505 certification exam.
Exam C-THR82-2505 Question, New C-THR82-2505 Dumps BookThe immediate downloading feature of our C-THR82-2505 Certification guide is an eminent advantage of our products. Once the pay is done, our customers will receive an e-mail from our company. There is a linkage given by our e-mail, and people can begin their study right away after they have registered in. Our C-THR82-2505 exam braindumps are available for downloading without any other disturbing requirements as long as you have paid successfully, which is increasingly important to an examinee as he or she has limited time for personal study. Therefore, our SAP Certified Associate - SAP SuccessFactors Performance and Goals guide torrent is attributive to high-efficient learning.
SAP Certified Associate - SAP SuccessFactors Performance and Goals Sample Questions (Q72-Q77):NEW QUESTION # 72
What can you do with the Import Performance Goals feature? Note: There are 3 correct answers to this question.
  • A. Delete goals
  • B. Transfer existing goals between employees
  • C. Delete goal comments
  • D. Update goals
  • E. Assign team goals
Answer: A,D,E
NEW QUESTION # 73
Which of the following are applicable to the Employee Information section?
  • A. Elements CANNOT be reordered.
  • B. Section content can be edited on the form.
  • C. Custom elements can be displayed.
  • D. Elements can be relabeled specifically per form template.
Answer: B,C,D
The Employee Information section in performance forms supports:
* Relabeling elements per form template: Elements can be customized with specific labels.
* Displaying custom elements: Additional custom fields can be included.
* Editing section content: Users with appropriate permissions can edit content on the form.
Extract from SAP SuccessFactors Documentation:
* SAP SuccessFactors Performance Management Guide (Q3 2025):"The Employee Information section allows elements to be relabeled specifically for each form template, supports the display of custom elements, and permits editing of section content by users with appropriate permissions. Elements can also be reordered as needed." Explanation of Options:
* A. Correct: Elements can be relabeled per form template.
* B. Correct: Custom elements can be displayed.
* C. Correct: Section content can be edited on the form.
* D. Incorrect: Elements can be reordered, contrary to the statement.
SAP SuccessFactors Performance Management Guide, Section: "Employee Information Section," Subsection:
"Configuration Options" (Q3 2025).
NEW QUESTION # 74
When will ratings be displayed as a drop-down list?
  • A. When showing numeric values
  • B. When hiding numeric values
  • C. When using rating scales below 5 points
  • D. When using matrix grid rating scales
  • E. When using rating scales over 5 points
Answer: B,D,E
NEW QUESTION # 75
Which permissions for approved sessions can be granted to facilitators?
  • A. Reopen
  • B. Finalize
  • C. Export
  • D. Write
  • E. Delete
Answer: A,B,C
Facilitators of approved calibration sessions can be granted permissions to:
* Export: Export session data for reporting.
* Finalize: Complete the session and lock ratings.
* Reopen: Reopen a finalized session for further adjustments.
* SAP SuccessFactors Calibration Configuration Guide (Q3 2025):"Facilitators of approved calibration sessions can be granted permissions to export session data, finalize the session to lock ratings, and reopen a finalized session for additional changes, subject to role-based permissions." Explanation of Options:
* A. Correct: Export permission is supported.
* B. Incorrect: Delete permission is not typically granted for approved sessions.
* C. Correct: Finalize permission is supported.
* D. Incorrect: Write permission is not a standard term for calibration sessions; edit permissions are covered under other roles.
* E. Correct: Reopen permission is supported.
SAP SuccessFactors Calibration Configuration Guide, Section: "Facilitator Permissions," Subsection:
"Approved Sessions" (Q3 2025).
NEW QUESTION # 76
Which of the following are options in the Review Information section of the performance form?
  • A. Custom elements can be added.
  • B. Review dates are hard-coded from Form Template Settings.
  • C. Only fixed dates set at form template level can be made editable in the section.
  • D. This section type is generally disabled for end users.
NEW QUESTION # 77
Our SAP C-THR82-2505 practice test software is the most distinguished source for the SAP C-THR82-2505 exam all over the world because it facilitates your practice in the practical form of the SAP Certified Associate - SAP SuccessFactors Performance and Goals certification exam. Moreover, you do not need an active internet connection to utilize SAP C-THR82-2505 Practice Exam software. It works without the internet after software installation on Windows computers.
Exam C-THR82-2505 Question: https://www.real4prep.com/C-THR82-2505-exam.html
The sooner we can reply, the better for you to solve your doubts about C-THR82-2505 training materials, It is possible for you to easily pass C-THR82-2505 exam, The C-THR82-2505 latest question we provide all candidates that that is compiled by experts who have good knowledge of exam, and they are very experience in compile study materials, By using the Exam C-THR82-2505 Question - SAP Certified Associate - SAP SuccessFactors Performance and Goals exam study material, they could prepare the exam with high speed and efficiency and the effective learning we bring to you will make you strongly interested in Exam C-THR82-2505 Question - SAP Certified Associate - SAP SuccessFactors Performance and Goals training questions.
Absolute positioning is the crudest way of laying out widgets, Why is normalization important, The sooner we can reply, the better for you to solve your doubts about C-THR82-2505 Training Materials.
SAP C-THR82-2505 Hot Spot Questions: SAP Certified Associate - SAP SuccessFactors Performance and Goals - Real4Prep Download Demo FreeIt is possible for you to easily pass C-THR82-2505 exam, The C-THR82-2505 latest question we provide all candidates that that is compiled by experts who have good knowledge of exam, and they are very experience in compile study materials.
By using the SAP Certified Associate - SAP SuccessFactors Performance and Goals exam study material, they could prepare the exam C-THR82-2505 with high speed and efficiency and the effective learning we bring to you will make you strongly interested in SAP Certified Associate - SAP SuccessFactors Performance and Goals training questions.
We respect your needs toward the useful C-THR82-2505practice materials by recommending our C-THR82-2505 guide preparations for you.
BONUS!!! Download part of Real4Prep C-THR82-2505 dumps for free: https://drive.google.com/open?id=1UPaYuDEk2xRng2D75ZeCtPQxM962RYZq
