[General] Trustable Vce JN0-336 Free & Leading Provider in Qualification Exams & C
15
【General】 Trustable Vce JN0-336 Free & Leading Provider in Qualification Exams & C
Posted at before yesterday 10:38      View:23 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Juniper JN0-336 dumps are available on Google Drive shared by Pass4Test: https://drive.google.com/open?id=1DLDm4W6wRx5oXm9KxFCt7udeXA4iZzxL
To be well-prepared, you require trustworthy and reliable Pass4Test practice material. You also require accurate Pass4Test study material to polish your capabilities and improve your chances of passing the JN0-336 Certification Exam. Pass4Test facilitates your study with updated Juniper JN0-336 exam dumps.
It is necessary to strictly plan the reasonable allocation of JN0-336 test time in advance. Many students did not pay attention to the strict control of time during normal practice, which led to panic during the process of examination, and even some of them are not able to finish all the questions. If you purchased JN0-336 learning dumps, each of your mock exams is timed automatically by the system. JN0-336 learning dumps provide you with an exam environment that is exactly the same as the actual exam. It forces you to learn how to allocate exam time so that the best level can be achieved in the examination room.
Exam Juniper JN0-336 Pass4sure | JN0-336 New Practice QuestionsTo ensure that the JN0-336 dumps PDF format remains up to date, the Juniper JN0-336 questions in it are regularly revised to reflect any modifications to the JN0-336 exam content. This commitment to staying current and aligned with the JN0-336 Exam Topics ensures that candidates receive the Security, Specialist (JNCIS-SEC) (JN0-336) updated questions.
Juniper Security, Specialist (JNCIS-SEC) Sample Questions (Q76-Q81):NEW QUESTION # 76
A client has attempted communication with a known command-and-control server and it has reached the configured threat level threshold.
Which feed will the clients IP address be automatically added to in this situation?
  • A. the allowlist and blocklist feed
  • B. the command-and-control cloud feed
  • C. the custom cloud feed
  • D. the infected host cloud feed
Infected hosts are internal hosts that have been compromised by malware and are communicating with external C&C servers3. Juniper ATP Cloud provides infected host feeds that list internal IP addresses or subnets of infected hosts along with a threat level3. Once the Juniper ATP Cloud global threshold for an infected host is met, that host is added to the infected host feed and assigned a threat level of 10 by the cloud4. You can also configure your SRX Series device to block traffic from these IP addresses using security policies4.
NEW QUESTION # 77
Which statement regarding Juniper Identity Management Service (JIMS) domain PC probes is true?
  • A. JIMS domain PC probes are triggered if no username to IP address mapping is found in the domain security event log.
  • B. JIMS domain PC probes are triggered to map usernames to group membership information.
  • C. JIMS domain PC probes are initiated by an SRX Series device to verify authentication table information.
  • D. JIMS domain PC probes analyze domain controller security event logs at60-mmute intervals by default.
Juniper Identity Management Service (JIMS) domain PC probes are used to map usernames to IP addresses in the domain security event log. This allows for the SRX Series device to verify authentication table information, such as group membership. The probes are triggered whenever a username to IP address mapping is not found in the domain security event log. By default, the probes are executed at 60-minute intervals.
NEW QUESTION # 78
You want to control when cluster failovers occur.
In this scenario, which two specific parameters would you configure on an SRX Series device? (Choose two.)
  • A. heartbeat-interval
  • B. heartbeat-address
  • C. heartbeat-threshold
  • D. heartbeat-cos
To control when cluster failovers occur, you need to configure two specific parameters on an SRX Series device: heartbeat-interval and heartbeat-threshold. These parameters determine how often the nodes in a cluster exchange heartbeat messages and how many consecutive heartbeats can be missed before a failover is triggered. The heartbeat-interval specifies the time interval in seconds between each heartbeat message. The default value is 1 second and the range is from 0.1 to 10 seconds. The heartbeat- threshold specifies the number of consecutive heartbeats that must be missed before a failover occurs.
The default value is 3 and the range is from 2 to 255.
Reference: = Configuring Chassis Clustering on SRX Series Devices, Chassis Cluster Redundancy Group Failover
NEW QUESTION # 79
Click the Exhibit button.
Referring to the exhibit, what will the SRX Series device do in this configuration?
  • A. Packets from the infected hosts with a threat level of 8 will be dropped and a log message will be generated.
  • B. Packets from the infected hosts with a threat level of 8 or above will be dropped and no log message will be generated.
  • C. Packets from the infected hosts with a threat level of 8 or above will be dropped and a log message will be generated.
  • D. Packets from the infected hosts with a threat level of 8 will be dropped and no log message will be generated.
The exhibit shows a configuration snippet for security intelligence on an SRX Series device. Security intelligence is a feature that allows you to block or monitor traffic from malicious sources based on threat intelligence feeds from Juniper ATP Cloud or other providers. The configuration defines a profile for ATP Infected-Hosts, which is a feed that contains IP addresses of hosts that are infected with malware and communicate with command-and-control servers. The configuration also defines a rule for threat level 8, which is a parameter that indicates the severity of the threat.
Based on this configuration, the SRX Series device will do the following:
Packets from the infected hosts with a threat level of 8 or above will be dropped: The action block-and- drop under the rule means that the device will block any traffic from the infected hosts that have a threat level equal to or higher than 8. This will prevent the hosts from sending or receiving malicious commands or data.
No log message will be generated: The absence of any log option under the rule means that the device will not generate any log message for the blocked traffic. This may reduce the load on the device and the logging server, but it may also limit the visibility and analysis of the security events. Reference: = Security Intelligence Theory, Firewall Filter Support on Loopback Interface
NEW QUESTION # 80
You are asked to ensure that if the session table on your SRX Series device gets close to exhausting its resources, that you enforce a more aggress.ve age-out of existing flows.
In this scenario, which two statements are correct? (Choose two.)
  • A. The early-ageout configuration specifies the timeout value, in seconds, that will be applied once the low-watermark value is met.
  • B. The high-watermark configuration specifies the percentage of how much of the session table is left before disabling a more aggressive age- out timer.
  • C. The high-watermark configuration specifies the percentage of how much of the session table can be allocated before applying a more aggressive age-out timer
  • D. The early-ageout configuration specifies the timeout value, in seconds, that will be applied once the high-watermark value is met.
The early-ageout configuration specifies the timeout value, in seconds, that will be applied once the high- watermark value is met. The high-watermark configuration specifies the percentage of how much of the session table can be allocated before applying a more aggressive age-out timer. This ensures that the session table does not become full and cause traffic issues, and also ensures that existing flows are aged out quickly when the table begins to get close to being full.
NEW QUESTION # 81
Pass4Test's website pages list the important information about our JN0-336 real quiz, the exam name and code, the updated time, the total quantity of the questions and answers, the characteristics and merits of the product, the price, the discounts to the client, the details of our JN0-336 training materials, the contact methods, the evaluations of the client on our JN0-336 learning guide. You can analyze the information the website pages provide carefully before you decide to buy our JN0-336 real quiz. Also our pass rate is high as 99% to 100%, you will pass the JN0-336 exam for sure.
Exam JN0-336 Pass4sure: https://www.pass4test.com/JN0-336.html
Just take the best decision of your career and enroll in the Security, Specialist (JNCIS-SEC) (JN0-336) exam, It enhances the learning with a sequence for producing the right result based on different stages of learning the Juniper JN0-336 study material, JN0-336 test questions have a mock examination system with a timing function, which provides you with the same examination environment as the real exam, Juniper Vce JN0-336 Free But we are professional in this career for over ten years.
Gaining Code Confidence Through Testing, Troubleshooting virtual environments: identifying and resolving specific problems, one step at a time, Just take the best decision of your career and enroll in the Security, Specialist (JNCIS-SEC) (JN0-336) exam.
JN0-336 Practice Materials: Security, Specialist (JNCIS-SEC) & JN0-336 Test King & JN0-336 Test QuestionsIt enhances the learning with a sequence for producing the right result based on different stages of learning the Juniper JN0-336 study material, JN0-336 test questions have a mock examination system JN0-336 New Practice Questions with a timing function, which provides you with the same examination environment as the real exam.
But we are professional in this career for JN0-336 over ten years, But in case you face any problem in accessing the Juniper JN0-336 exam questions while preparing for the Exam JN0-336 Pass4sure Security, Specialist (JNCIS-SEC) exam, there is a product support team at Pass4Test to help you with it.
BTW, DOWNLOAD part of Pass4Test JN0-336 dumps from Cloud Storage: https://drive.google.com/open?id=1DLDm4W6wRx5oXm9KxFCt7udeXA4iZzxL
