Certified Pega System Architect 25 PEGACPSA25V1 Dumps Questions
Posted at 2 hour before
Preparing for the Certified Pega System Architect 25 PEGACPSA25V1 exam becomes much easier when you study with focused and updated practice resources. The latest Certified Pega System Architect 25 PEGACPSA25V1 Dumps Questions from Certspots are designed to help candidates understand the real exam structure, key knowledge areas, and commonly tested concepts. By practicing with updated PEGACPSA25V1 questions, candidates can strengthen their understanding of Pega application development, improve their problem-solving skills, and build confidence before taking the actual exam.
What Is the PEGACPSA25V1 Certified Pega System Architect 25 Exam?The Certified Pega System Architect ’25 certification is intended for developers and technical staff who want to learn how to build applications using Pega Platform. It is the first level in the Pega System Architect certification path and validates a candidate’s foundational knowledge of Pega application design, case management, data modeling, user experience configuration, security, and development practices.
This certification is especially useful for professionals who are beginning their Pega development journey and want to prove that they understand the core features and principles of Pega Platform.
PEGACPSA25V1 Exam InformationThe PEGACPSA25V1 Certified Pega System Architect 25 exam includes the following details:
Exam DetailInformation
Exam CodePEGACPSA25V1
CertificationCertified Pega System Architect 25
Number of Questions60
Duration1 hour 30 minutes
Passing Score65%
PrerequisiteSystem Architect knowledgeCandidates should be familiar with basic Pega application development concepts before taking this exam. A solid understanding of case lifecycle design, data configuration, security access, UI setup, and application debugging will be very helpful.
Key Skills Tested in the PEGACPSA25V1 ExamThe exam measures whether candidates can work with essential Pega development features and apply them in real application-building scenarios. Instead of only testing theory, the exam focuses on how well you understand Pega’s low-code development approach and how different platform components work together.
Major skill areas include:
- Designing case lifecycles and workflows
- Configuring data types, data objects, and validation rules
- Managing user access through roles and personas
- Building user interfaces with views, templates, and dynamic behavior
- Understanding DevOps concepts in Pega application delivery
- Creating reusable and maintainable application structures
- Using Insights and dashboards for data analysis
- Understanding Pega GenAI features such as Blueprint, Autopilot, Knowledge Buddy, Coach, Agents, and Tool Rules
PEGACPSA25V1 Exam Topics and WeightingCase Management – 25%Case Management is the largest topic area in the PEGACPSA25V1 exam. Candidates need to understand how to design a case lifecycle, configure stages, set case statuses, and add task instructions. This section also covers service level agreements, urgency, goals, deadlines, routing assignments, approval processes, duplicate case identification, optional actions, workflow decisions, child cases, and automation shapes.
You should also know how to use decision tables and decision trees to automate decisions, as well as how personas are defined and used within a Pega application.
Data and Integration – 20%This section focuses on how Pega applications manage and use data. Candidates should understand the data model, data types, data objects, data relationships, data records, and field types. You should also know how to create calculated values, validate data, configure data transforms, set default property values, and access sourced data in a case.
Other important areas include refresh strategies, populating user interface controls, saving data to a system of record, and simulating application data during development.
Application Development – 15%The Application Development section tests your understanding of how Pega Platform supports enterprise application creation. Candidates should know the benefits of Pega Platform, Center-out architecture, Situational Layer Cake, prescriptive design, studio interoperability, and the Reuse Library.
This area also includes workspaces, branches, Agile Workbench, user stories, feedback, bugs, rules, rulesets, classes, inheritance, relevant records, and debugging application errors.
Security – 10%Security is a key part of Pega application development. This section covers authentication, authorization, the Security Checklist, operators, access groups, access roles, personas, and role-based access control.
Candidates should clearly understand how users gain access to applications and how permissions are managed across different roles.
User Experience – 10%The User Experience section focuses on building and configuring the application interface. Candidates should know how to configure views and templates, customize full page views, understand default and hierarchical forms, configure field settings, and use primary fields and field groups.
You should also understand how patterns, conditional expressions, and when rules control dynamic field behavior. Channels, personas, portal templates, landing page templates, themes, widgets, and localization best practices are also included.
Pega GenAI – 10%Pega GenAI is an important part of the updated PEGACPSA25V1 exam. Candidates should understand how Pega GenAI features support faster and smarter application development.
This section includes Pega GenAI Knowledge Buddy, Pega Blueprint, Pega GenAI Autopilot, GenAI Connect Rules, Pega GenAI Coach, Pega GenAI Agents, and Tool Rules. You should understand what each feature does and how it helps developers or application users.
DevOps – 5%The DevOps section focuses on Pega’s continuous development, integration, delivery, and deployment process. Candidates should understand how CI/CD supports application development and what types of testing are required before successful deployment.
Insights – 5%This section covers the benefits of Insights and how to use the Explore Data landing page to create Insights. Candidates should also understand the relationship between Insights, dashboards, the Dashboards landing page, portal landing pages, and full page case views.
How to Prepare for the PEGACPSA25V1 Exam EffectivelyTo prepare well for the Certified Pega System Architect 25 exam, candidates should begin by reviewing the official exam topics and identifying the areas with the highest weighting. Since Case Management, Data and Integration, and Application Development account for a large portion of the exam, these topics should receive more study time.
It is also important to practice with scenario-based questions. Many Pega concepts are connected, so you need to understand how case lifecycles, data objects, personas, UI views, security settings, and business logic work together in an application.
Using the latest PEGACPSA25V1 practice questions can help you become familiar with the question style and improve your ability to choose the correct answer under time pressure.
Why Practice Questions Are Useful for PEGACPSA25V1 PreparationPractice questions are valuable because they help candidates move beyond passive reading. By answering PEGACPSA25V1 questions, you can check whether you truly understand Pega concepts and can apply them correctly.
Updated practice materials can help you:
- Understand the exam format and topic coverage
- Identify weak knowledge areas quickly
- Review important Pega development concepts
- Improve speed and accuracy
- Build confidence before the real exam
For candidates who want a more efficient preparation path, Certspots PEGACPSA25V1 Dumps Questions can be used as a practical review tool alongside official learning resources and hands-on Pega practice.
Final ThoughtsThe PEGACPSA25V1 Certified Pega System Architect 25 exam is an important starting point for professionals who want to build a career in Pega application development. It validates your knowledge of case management, data modeling, security, user experience, application development, DevOps, Insights, and Pega GenAI features.
With a clear study plan, hands-on practice, and the latest Certified Pega System Architect 25 PEGACPSA25V1 Dumps Questions from Certspots, candidates can prepare more effectively and approach the exam with greater confidence.
