[General] Sample NCP-AII Questions Pdf Professional Questions Pool Only at Itcerttest
19
【General】 Sample NCP-AII Questions Pdf Professional Questions Pool Only at Itcerttest
Posted at 5 day before      View:30 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Itcerttest NCP-AII dumps from Cloud Storage: https://drive.google.com/open?id=1l4dO1WALQw5HlIP1oNwZIAzx9dIt1lQD
Our website are specialized in offering customers with reliable NVIDIA braindumps and study guide, which written by a team of IT experts and certified trainers who enjoy great reputation in the IT field. All NCP-AII Test Questions are created based on the real test and followed by valid test answers and explanations. We guarantee you get high passing score with our NCP-AII exam prep.
NVIDIA NCP-AII Exam Syllabus Topics:
  • Control Plane Installation and Configuration: Covers deploying the software stack including Base Command Manager, OS, Slurm
  • Enroot
  • Pyxis, NVIDIA GPU and DOCA drivers, container toolkit, and NGC CLI.
  • System and Server Bring-up: Covers end-to-end physical setup of GPU-based AI infrastructure, including BMC
  • OOB
  • TPM configuration, firmware upgrades, hardware installation, and power and cooling validation to ensure servers are workload-ready.
  • Troubleshoot and Optimize: Covers identifying and replacing faulty hardware components such as GPUs, network cards, and power supplies, along with performance optimization for AMD
  • Intel servers and storage.
  • Cluster Test and Verification: Covers full cluster validation through HPL and NCCL benchmarks, NVLink and fabric bandwidth tests, cable and firmware checks, and burn-in testing using HPL, NCCL, and NeMo.
Topic 5
  • Physical Layer Management: Covers configuring BlueField network platform devices and setting up Multi-Instance GPU (MIG) partitioning for AI and HPC workloads.
NCP-AII Accurate Prep Material - Cert NCP-AII GuideIn order to make all customers feel comfortable, our company will promise that we will offer the perfect and considerate service for all customers. If you buy the NCP-AII study materials from our company, you will have the right to enjoy the perfect service. We have employed a lot of online workers to help all customers solve their problem. If you have any questions about the NCP-AII Study Materials, do not hesitate and ask us in your anytime, we are glad to answer your questions and help you use our NCP-AII study materials well. We believe our perfect service will make you feel comfortable when you are preparing for your exam.
NVIDIA AI Infrastructure Sample Questions (Q108-Q113):NEW QUESTION # 108
A financial services firm is deploying an AI model for fraud detection that requires rapid inference and data retrieval across multiple sites. Which feature should their storage system prioritize?
  • A. Multi-protocol data access with low latency.
  • B. Low-cost HDD solutions.
  • C. High capacity with moderate speed.
  • D. Tape backup systems.
Fraud detection in financial services is a real-time AI workload. The system must ingest transaction data, retrieve historical customer profiles, and perform inference in milliseconds. This requires a storage architecture that supportsmulti-protocol access(such as S3 for ingestion and POSIX/NFS for inference engines) combined withlow latency. In these environments, storage latency directly impacts the "Time to Decision". An All-Flash storage tier is mandatory, as traditional HDD solutions (Option D) or moderate speed systems (Option B) introduce "Tail Latency" that can cause the fraud detection model to time out during peak transaction windows. Additionally, multi-site synchronization ensures that the latest model weights and historical data are available across different geographic data centers for high availability and localized inference.
NEW QUESTION # 109
A user reports that their deep learning training job is crashing with a 'CUDA out of memory' error, even though 'nvidia-smi' shows plenty of free memory on the GPU. The job uses TensorFlow. What are the TWO most likely causes?
  • A. The system's swap space is full, preventing memory from being allocated.
  • B. The CUDA VISIBLE DEVICES environment variable is not set correctly.
  • C. TensorFlow is fragmenting GPU memory, making it difficult to allocate contiguous blocks.
  • D. TensorFlow is allocating memory on the CPU instead of the GPU.
  • E. The TensorFlow version is incompatible with the installed NVIDIA driver.
'CUDA out of memory errors, despite seemingly available GPU memory, often indicate memory fragmentation or improper GPU assignment. TensorFlow can fragment GPU memory, leading to allocation failures even if sufficient total memory is available. The variable controls which GPUs TensorFlow can access. If it's not set or is set incorrectly, TensorFlow might be trying to allocate memory on a non-existent or unavailable GPU. While TensorFlow version incompatibilities can cause issues, they are less likely to directly manifest as 'CUDA out of memory' errors. TensorFlow typically prioritizes GPU memory allocation if configured correctly.
NEW QUESTION # 110
While running a large A1 training job, you observe the following output from 'nvidia-smi':
GPU O: P2
GPU 1: P2
GPU 2: P2
GPU 3: P2
What does the 'P2' state indicate, and what steps should you take to investigate this further in the context of validating optimal hardware operation?
  • A. P2 indicates the GPU is running at maximum clock speed. Check for thermal throttling.
  • B. P2 indicates the GPUs are in a high-performance state; no further investigation is needed.
  • C. P2 indicates a critical error state; immediately halt the training job and check the system logs for hardware failures.
  • D. P2 indicates the GPUs are in a low-power idle state; investigate if the driver is correctly configured and the workload is properly utilizing the GPUs.
P2 typically indicates a power-saving state where the GPU is operating at a reduced clock speed. It's crucial to investigate whether the workload is demanding sufficient resources from the GPUs, and whether power limits or other configuration settings are preventing the GPUs from reaching their maximum performance state. Review 'nvidia-smi -q' output for power usage and clock speeds to verify proper operation. Other power states (PO, Pl) represent varying levels of performance.
NEW QUESTION # 111
You are leading a project to enhance the energy efficiency of a data center that heavily relies on AI workloads. NVIDIA suggests moving beyond traditional metrics like Power Usage Effectiveness (PUE) to better capture the efficiency of modern data centers. Which strategy should you prioritize?
  • A. Develop benchmarks tailored to specific workloads, such as MLPerf for AI applications, to better understand energy use in real-world scenarios.
  • B. Focus on integrating kilowatt-hours into existing metrics to better reflect the actual energy used for productive work.
  • C. Use watts used as the primary measure of efficiency, as it accurately reflects the power input at any given time.
  • D. Use Power Usage Effectiveness as the primary metric while supplementing it with additional measures of useful work done per unit of energy.
Traditional data center metrics like PUE (Power Usage Effectiveness) only measure how much energy is " wasted " by cooling and power delivery relative to the IT load; they say nothing about how efficiently that IT load is performing its task. In an AI Factory, " Efficiency " is better defined by the amount of AI training or inference performed per watt. NVIDIA advocates for the use of workload-specific benchmarks, such as MLPerf, to quantify this. MLPerf measures the time and energy required to complete standardized AI tasks (like training a ResNet-50 model or an LLM). By prioritizing these benchmarks (Option C), an organization can compare the energy efficiency of different hardware architectures (e.g., A100 vs. H100) or different software optimizations (e.g., FP8 vs. FP16). For example, even if an H100 system draws more peak power than an older system, its ability to complete a training job 9x faster results in a significantly lower " Total Energy Consumed per Job " . This shift from " infrastructure efficiency " (PUE) to " computing efficiency " (MLPerf-per-watt) is essential for modern AI data centers aiming for sustainability and cost-effective scaling.
NEW QUESTION # 112
You have a large dataset stored on a network file system (NFS) and are training a deep learning model on an AMD EPYC server with NVIDIA GPUs. Data loading is very slow. What steps can you take to improve the data loading performance in this scenario? Select all that apply.
  • A. Increase the number of NFS client threads on the AMD EPYC server.
  • B. Mount the NFS share with the 'nolock' option.
  • C. Switch to a parallel file system like Lustre or BeeGFS.
  • D. Use a local SSD or NVMe drive to cache frequently accessed data.
  • E. Reduce the batch size to decrease the amount of data loaded per iteration.
Answer: A,C,D
Increasing NFS client threads enables more concurrent data access. Caching frequently accessed data on a local SSD/NVMe drive reduces network I/O. Switching to a parallel file system provides higher bandwidth and lower latency compared to NFS. 'nolock' can improve performance but sacrifices data consistency. Reducing batch size reduces the amount of data loaded but doesn't address the underlying NFS bottleneck.
NEW QUESTION # 113
The NCP-AII exam prep is produced by our expert, is very useful to help customers pass their NCP-AII exams and get the certificates in a short time. If you want to know the quality of our NCP-AII guide braindumps befor you buy it, you can just free download the demo of our NCP-AII Exam Questions. We can sure that our NCP-AII training guide will help you get the certificate easily. If you are wailing to believe us and try to learn our NCP-AII exam torrent, you will get an unexpected result.
NCP-AII Accurate Prep Material: https://www.itcerttest.com/NCP-AII_braindumps.html
P.S. Free 2026 NVIDIA NCP-AII dumps are available on Google Drive shared by Itcerttest: https://drive.google.com/open?id=1l4dO1WALQw5HlIP1oNwZIAzx9dIt1lQD
