[Hardware] AP-212 Test Passing Score & Online AP-212 Tests
19
【Hardware】 AP-212 Test Passing Score & Online AP-212 Tests
Posted at before yesterday 14:38      View:23 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that Dumpleader AP-212 dumps now are free: https://drive.google.com/open?id=1dkuAA98XrbTIUAj2PYcHHMD5q0xWOzii
Our AP-212 qualification test guide boosts the self-learning and self-evaluation functions so as to let the clients understand their learning results and learning process of AP-212 exam questions , then find the weak links to improve them. Through the self-learning function the learners can choose the learning methods by themselves and choose the contents which they think are important. Through the self-evaluation function the learners can evaluate their mastery degree of our AP-212 test materials and their learning process.
Our company has become the front-runner of this career and help exam candidates around the world win in valuable time. With years of experience dealing with AP-212 exam, they have thorough grasp of knowledge which appears clearly in our AP-212 Exam Questions. All AP-212 study materials you should know are written in them with three versions to choose from: the PDF, Software and APP online versions.
Online Salesforce AP-212 Tests - New AP-212 Exam FeeWe has a long history of 10 years in designing the AP-212 exam guide and enjoys a good reputation across the globe. There are so many features to show that our AP-212 study engine surpasses others. We can confirm that the high quality is the guarantee to your success. At the same time, the prices of our AP-212 practice materials are quite reasonable for no matter the staffs or the students to afford. What is more, usually we will give some discounts to our worthy customers.
Salesforce Loyalty Management Accredited Professional Sample Questions (Q53-Q58):NEW QUESTION # 53
A Consultant was tasked with setting up the connection between Salesforce Loyalty Management and Marketing Cloud. The Consultant created a new user account in Marketing Cloud Which two items on the Marketing Cloud user account should the Consultant configure to enable the user account to successfully connect with Salesforce Loyalty Management?
  • A. API access
  • B. User account must exist within the Loyalty Management org
  • C. Assign the permission set to the user account
  • D. Grant access to the correct business unit
When configuring a new user account in Marketing Cloud for integration with Salesforce Loyalty Management, the Consultant must ensure to Grant access to the correct business unit (B) and Enable API access (D). Access to the correct business unit is necessary to ensure that the user has access to the relevant data and functionalities within Marketing Cloud. API access is essential for the technical integration, allowing for communication between Salesforce Loyalty Management and Marketing Cloud.
NEW QUESTION # 54
An Administrator needs to analyze the performance of the Loyalty Program.
What Loyalty Analytics permission does a System Administrator need to set up and customize?
  • A. Loyalty Analytics User
  • B. CRM Analytics User
  • C. Data Pipeline User
  • D. CLAAnalytics Base Admin
To analyze the performance of the Loyalty Program, a System Administrator needs to set up and customize Loyalty Analytics, which requires the Loyalty Analytics User (A) permission. This permission set enables the administrator to access Loyalty Analytics features, configure reports, and customize dashboards to analyze various aspects of the Loyalty Program's performance, such as member engagement, tier progression, redemption rates, and more.
Option B (CLAAnalytics Base Admin), Option C (Data Pipeline User), and Option D (CRM Analytics User) refer to different aspects of Salesforce analytics and data management, which, while potentially relevant in broader contexts, are not specifically tailored to the setup and customization of Loyalty Analytics within Salesforce Loyalty Management.
Salesforce documentation on Loyalty Management and Analytics would provide guidance on leveraging analytics capabilities to gain insights into Loyalty Program performance, guiding data-driven decision-making and program optimization.
NEW QUESTION # 55
A loyalty Program would like to set up a new process where a push notification or email will be sent to the client immediately after a voucher is added to their member account within Salesforce Marketing Cloud.
The notification message will require the "first name" and the "membership number" to personalize the message and, a custom object named
"voucher issued" with the necessary data attributes.
Which option for the entry event should be selected as the preferred implementation approach that can meet the requirements with the least amount of development effort?
  • A.
  • B.
  • C.
  • D.
For the scenario described, where a loyalty program wants to send an immediate notification after a voucher is added to a member's account, the entry event in Salesforce Marketing Cloud needs to trigger off of the creation of a record in Salesforce that contains the necessary data attributes for personalization.
Option C is the most suitable choice because it specifies an entry event based on the "Voucher," "Contact," and "LoyaltyProgramMember" objects. This approach aligns with the requirements because it directly utilizes the "first name" from the Contact object and the "membership number" from the LoyaltyProgramMember object, which are necessary for personalizing the notification message.
Moreover, Option C would likely require the least amount of development effort because it leverages existing Salesforce data and related objects without the need for additional configuration or data extensions. In contrast, other options would require the setup of a data extension or custom objects that may not be directly tied to the triggering event, thereby increasing the complexity and development effort.
In Salesforce Marketing Cloud, Journey Builder is the tool that would be used to create this customer journey.
It allows for the configuration of entry events based on data changes in Salesforce, such as the addition of a voucher to a member's account. The real-time nature of this trigger is essential for the immediate notification requirement.
According to Salesforce's official documentation, using Salesforce data as the entry source for a journey allows for real-time messaging based on record creation or updates. This means that as soon as a voucher record is created or updated in Salesforce, the entry event can trigger and begin the journey, which will send the personalized notification to the member.
In practice, setting up this entry event in Journey Builder would involve specifying the criteria for the trigger (in this case, the creation of a voucher) and mapping the necessary data fields for personalization. This is consistent with Salesforce's best practices for creating personalized, real-time customer engagements through Journey Builder.
Salesforce's documentation on Journey Builder and real-time event triggers provides further details on how to configure these types of journeys and can be referred to for step-by-step guidance and the latest feature updates.
NEW QUESTION # 56
The existing Loyalty Program would need to have its "members-record" transferred from an SQL database into a new Salesforce Loyalty Management org, where its members' records are kept within a data table named
"tbl_Member" with the following data contents:
* the program member's personal particular and contact information
* member's current-tier value
* member's tier-points
Which object combinations should be used for data migration of the source's member records into the Loyalty Member org?
  • A. "LoyaltyProgramMember", "LoyaltyMemberTier", "LoyaltyProgamCurrency". "Account" Object.
  • B. "LoyaltyProgramMember". "LoyaltyMemberTier", "LoyaltyMemberCurrency". "Contact" and
    "Account" Object.
  • C. "LoyaltyProgramMember", "LoyaltyTier", "LoyaltyMemberCurrency". 'Contact" and "Account" Object.
  • D. "LoyaltyProgramMember', "LoyaltyTier". "LoyaltyProgramCurrency". "Contact" and "Account" Object.
For migrating "members-record" from an SQL database into Salesforce Loyalty Management, the correct combination of objects to use is:
* D: "LoyaltyProgramMember," "LoyaltyMemberTier," "LoyaltyMemberCurrency," "Contact," and
"Account" Object. This combination covers all necessary aspects of Loyalty Program members' records, including personal information, tier status, and point balances.
NEW QUESTION # 57
The Member Services team wants to view the information of a member's recent transactions and manual adjustments on the Contact record.
What are the two recommendations that an IT Administrator should suggest?
  • A. Embed the Member Service Manager Home Dashboard on the Contact record
  • B. Embed the 'Member Summary Embedded Dashboard on the Contact record
  • C. Add the 'View Member Profile' component on the Contact record
  • D. Add the 'Transaction Journals' related list to the Contact record
To provide the Member Services team with the information they need directly on the Contact record, the IT Administrator can take two main actions. Firstly, embedding the 'Member Summary Embedded Dashboard' on the Contact record allows the team to have a visual and comprehensive overview of a member's loyalty activities, including recent transactions and adjustments, directly within the context of the contact. This dashboard is specifically designed to aggregate and display relevant loyalty information, making it a suitable tool for quick insights.
Secondly, adding the 'Transaction Journals' related list to the Contact record enables the team to view detailed entries of each transaction and manual adjustment made by or for the member. This related list provides granular data about each activity, allowing for a deeper analysis and understanding of the member's loyalty interactions.
These recommendations are based on best practices for Salesforce Loyalty Management, ensuring that the team has access to both summarized and detailed loyalty information within their usual workflows, enhancing efficiency and providing a holistic view of member activities.
NEW QUESTION # 58
As long as you buy our AP-212 practice materials and take it seriously consideration, we can promise that you will pass your AP-212 exam and get your certification in a short time. We can claim that if you study with our AP-212 Guide quiz for 20 to 30 hours, you will be confident to pass the exam for sure. So choose our exam braindumps to help you review, you will benefit a lot from our AP-212 study guide.
Online AP-212 Tests: https://www.dumpleader.com/AP-212_exam.html
Salesforce AP-212 Test Passing Score The claim for Warranty should be filed in within the 7 days of failure of the exam, At some point in your AP-212 test certification journey, you will need to sit an Loyalty Management Accredited Professional exam test, The workers who pass the Salesforce Online AP-212 Tests exam can not only obtain a decent job with a higher salary, but also enjoy a good reputation in this industry, We are the world's leading enterprise which offers professional AP-212 exam torrent and AP-212 actual exam questions many years.
The cables used to connect to the network look like oversized phone connectors AP-212 Test Passing Score and, as luck has it, plug directly into your MacBook's Ethernet port, The public trusts small businesses more than large corporations.
Latest AP-212 – 100% Free Test Passing Score | Online AP-212 TestsThe claim for Warranty should be filed in within the 7 days of failure of the exam, At some point in your AP-212 test certification journey, you will need to sit an Loyalty Management Accredited Professional exam test.
The workers who pass the Salesforce exam can not Online AP-212 Tests only obtain a decent job with a higher salary, but also enjoy a good reputation in this industry, We are the world's leading enterprise which offers professional AP-212 exam torrent and AP-212 actual exam questions many years.
But in order to let the job position to improve spending AP-212 some money to choose a good training institution to help you pass the exam is worthful.
P.S. Free 2026 Salesforce AP-212 dumps are available on Google Drive shared by Dumpleader: https://drive.google.com/open?id=1dkuAA98XrbTIUAj2PYcHHMD5q0xWOzii
