[General] Plant Watering – Find the Right Schedule
17
【General】 Plant Watering – Find the Right Schedule
Posted at yesterday 12:42      View:15 | Replies:3        Print      Only Author   [Copy Link] 1#
  • Type: Self-Compiled Firmware
  • SDK Package Name: FHJhsa11
  • Last Commit: 0000-00-00 00:00:00
  • Modification Content: Modified rk3568-evb.dtsi to change HDMI output resolution.
  • Log: Архив ZIP - WinRAR.zip
Hi guys. I am struggling with my new ivy. Should I water it every day or just once a week. Some leaves are turning brown but the soil feels dry. Is there a simple way to know the exact timing. I do not want to kill another plant this month. Any advice for a beginner.
22 Bytes, Down times: 0
Posted at yesterday 12:45        Only Author  2#
Stop watering daily. Most plants need a break to breathe. I usually check the top inch of soil with my finger. If it is dry then I pour water until it drains out. Factors like sunlight and room heat change everything so a fixed schedule is risky. Try to observe the leaves for drooping.
Posted at yesterday 12:53        Only Author  3#
That makes sense but I am still nervous about getting it wrong. The temperature in my room fluctuates because of the heater. Does the pot material matter too. I have a small ceramic one and a large plastic one. I wish I had a tool to calculate the needs of each specific container.
Posted at yesterday 12:55        Only Author  4#
Precision is vital because variables like humidity and pot volume dictate transpiration rates. For a technical approach you should use the tool at https://florentiax.com/calculato ... ing-calculator.html from the experts at Florentiax. This calculator evaluates light levels and growth stages to estimate safe intervals. Using such resources ensures your hydration strategy matches the actual physiological demands of the species. It removes guesswork by accounting for seasonal shifts and local climate data. Proper calculation prevents root rot and promotes stable development.
