[Hardware] Data-Con-101 Key Concepts, New Data-Con-101 Test Testking
28
【Hardware】 Data-Con-101 Key Concepts, New Data-Con-101 Test Testking
Posted at yesterday 16:25      View:15 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New Data-Con-101 dumps are available on Google Drive shared by Dumpcollection: https://drive.google.com/open?id=1kRi5YvdQTGBi501OBsUEMk1kFvVKQIM6
I know your time is very valuable. We guarantee that you can download our products Data-Con-101 exam questions immediately after payment is successful. After your current page shows that the payment was successful, you can open your e-mail address to receive our Data-Con-101 Study Materials. And you can find that you can get Data-Con-101 learning guide only in 5 to 10 minutes. It is very fast and easy. And our Data-Con-101 practice engine is auto installed, so you don't have to do more work.
Our company also arranges dedicated personnel to ensure the correctness of our Data-Con-101 learning quiz. As you know, our Data-Con-101 study materials are certified products and you can really use them with confidence. On one hand, our company always hire the most professional experts who will be in charge of compiling the content and design the displays. On the other hand, we will ask for some volunteers to study with our Data-Con-101 learning prep to test the pass rate.
New Data-Con-101 Test Testking, Data-Con-101 Valid Exam DumpsAs you know, the first-classs quality always come with the first service. That is exactly what describe our Data-Con-101 exam materials. No only that our Data-Con-101 training guide can attract you for its best quality, but also you will be touched by the excellent service. If you have any question about our Data-Con-101 Learning Engine, our service will give you the most professional suggestion and help. And we work 24/7 online. So you can always find we are acompanying you.
Salesforce Certified Data Cloud Consultant Sample Questions (Q139-Q144):NEW QUESTION # 139
What is Data Cloud's primary value to customers?
  • A. To create a single source of truth for all anonymous data
  • B. To create personalized campaigns by listening, understanding, and acting on customer behavior
  • C. To connect all systems with a golden record
  • D. To provide a unified view of a customer and their related data
Data Cloud is a platform that enables you to activate all your customer data across Salesforce applications and other systems. Data Cloud allows you to create a unified profile of each customer by ingesting, transforming, and linking data from various sources, such as CRM, marketing, commerce, service, and external data providers. Data Cloud also provides insights and analytics on customer behavior, preferences, and needs, as well as tools to segment, target, and personalize customer interactions. Data Cloud's primary value to customers is to provide a unified view of a customer and their related data, which can help you deliver better customer experiences, increase loyalty, and drive growth. References: Salesforce Data Cloud, When Data Creates Competitive Advantage
NEW QUESTION # 140
How does Data Cloud handle an individual's Right to be Forgotten?
  • A. Deletes the records from all data source objects, and any downstream data model objects are updated at the next scheduled ingestion
  • B. Deletes the specified Individual record and its Unified Individual Link record.
  • C. Deletes the specified Individual and records from any data model object/data lake object related to the Individual.
  • D. Deletes the specified Individual and records from any data source object mapped to the Individual data model object.
Data Cloud handles an individual's Right to be Forgotten by deleting the specified Individual and records from any data model object/data lake object related to the Individual. This means that Data Cloud removes all the data associated with the individual from the data space, including the data from the source objects, the unified individual profile, and any related objects. Data Cloud also deletes the Unified Individual Link record that links the individual to the source records. Data Cloud uses the Consent API to process the Right to be Forgotten requests, which are reprocessed at 30, 60, and 90 days to ensure a full deletion.
The other options are not correct descriptions of how Data Cloud handles an individual's Right to be Forgotten. Data Cloud does not delete the records from all data source objects, as this would affect the data integrity and availability of the source systems. Data Cloud also does not delete only the specified Individual record and its Unified Individual Link record, as this would leave the source records and the related records intact. Data Cloud also does not delete only the specified Individual and records from any data source object mapped to the Individual data model object, as this would leave the related records intact.
Requesting Data Deletion or Right to Be Forgotten
Data Deletion for Data Cloud
Use the Consent API with Data Cloud
Data and Identity in Data Cloud
NEW QUESTION # 141
Cumulus Financial wants to create a segment of individuals based on transaction history data. This data has been mapped in the data model and is accessible via multiple container paths for segmentation.
What happens if the optimal container path for this use case is not selected?
  • A. Alternate container paths will be suggested before the segment is published.
  • B. The resulting segment may be smaller or larger than expected.
  • C. The resulting segment will not be generated.
  • D. Data Cloud segmentation will automatically select the optimal container path.
In Salesforce Data Cloud, when segmenting individuals based on transaction history data, there may be multiple paths to the same data through different objects in the data model. If the wrong container path is selected:
The segment may pull in too many or too few individuals because different container paths may define relationships differently.
Some records may be unintentionally excluded or duplicated, affecting segmentation accuracy.
Identity resolution and relationships between objects might not behave as expected.
Why Not A? Data Cloud does not suggest alternate container paths automatically. The user must choose the correct path.
Why Not C? Data Cloud does not automatically select the optimal path; it relies on the user's selection.
Why Not D? The segment will still be generated but may have inaccurate results.
# Salesforce Data Cloud Reference:
Salesforce Help Documentation - Data Model and Segmentation Best Practices Trailhead Module: Segmentation in Data Cloud Salesforce Knowledge Base - Using Container Paths for Segmentation
NEW QUESTION # 142
Which permission setting should a consultant check if the custom Salesforce CRM object is not available in New Data Stream configuration?
  • A. Confirm the View All object permission is enabled in the source Salesforce CRM org.
  • B. Confirm the Ingest Object permission is enabled in the Salesforce CRM org.
  • C. Confirm that the Modify Object permission is enabled in the Data Cloud org.
  • D. Confirm the Create object permission is enabled in the Data Cloud org.
To create a new data stream from a custom Salesforce CRM object, the consultant needs to confirm that the View All object permission is enabled in the source Salesforce CRM org. This permission allows the user to view all records associated with the object, regardless of sharing settings1. Without this permission, the custom object will not be available in the New Data Stream configuration2. References:
Manage Access with Data Cloud Permission Sets
Object Permissions
NEW QUESTION # 143
A consultant is planning the ingestion of a data stream that has profile information including a mobile phone number.
To ensure that the phone number can be used for future SMS campaigns, they need to confirm the phone number field is in the proper E164 Phone Number format. However, the phone numbers in the file appear to be in varying formats.
What is the most efficient way to guarantee that the various phone number formats are standardized?
  • A. Create a formula field to standardize the format.
  • B. Assign the PhoneNumber field type when creating the data stream.
  • C. Edit and update the data in the source system prior to sending to Data Cloud.
  • D. Create a calculated insight after ingestion.
The most efficient way to guarantee that the various phone number formats are standardized is to assign the PhoneNumber field type when creating the data stream. The PhoneNumber field type is a special field type that automatically converts phone numbers into the E164 format, which is the international standard for phone numbers. The E164 format consists of a plus sign (+), the country code, and the national number. For example, +1-202-555-1234 is the E164 format for a US phone number. By using the PhoneNumber field type, the consultant can ensure that the phone numbers are consistent and can be used for future SMS campaigns.
The other options are either more time-consuming, require manual intervention, or do not address the formatting issue. References: Data Stream Field Types, E164 Phone Number Format, Salesforce Data Cloud Exam Questions
NEW QUESTION # 144
Customizable practice tests comprehensively and accurately represent the actual Professional Salesforce Data-Con-101 Certification Exam pattern. Many students have studied from product and passed the Salesforce Certified Data Cloud Consultant (Data-Con-101) test with ease. Our customers can receive questions updates for up to 1 year after purchasing the product. These free updates of questions will help them to prepare according to the latest syllabus.
New Data-Con-101 Test Testking: https://www.dumpcollection.com/Data-Con-101_braindumps.html
With the Data-Con-101 latest braindumps, you can have a test just like you are in the real test environment, Data-Con-101 certification exams are a hugely popular IT exam in IT industry, The Dumpcollection is a leading platform committed to making entire Salesforce Certified Data Cloud Consultant (Data-Con-101) exam preparation simple, quick, and easy for everyone, You can use Data-Con-101 dumps PDF files anytime you want.
CourseBuilder creates multiple choice, text entry, drag and Data-Con-101 drop, and other types of assessment interactions using a wizard interface, Testing Wireless Equipment in the Lab.
With the Data-Con-101 Latest Braindumps, you can have a test just like you are in the real test environment, Data-Con-101 certification exams are a hugely popular IT exam in IT industry.
Quiz Salesforce - Data-Con-101 - Salesforce Certified Data Cloud Consultant Latest Key ConceptsThe Dumpcollection is a leading platform committed to making entire Salesforce Certified Data Cloud Consultant (Data-Con-101) exam preparation simple, quick, and easy for everyone, You can use Data-Con-101 dumps PDF files anytime you want.
The Salesforce Certified Data Cloud Consultant test guide is highly New Data-Con-101 Test Testking efficient and the forms of the answers and questions are the same.
P.S. Free 2026 Salesforce Data-Con-101 dumps are available on Google Drive shared by Dumpcollection: https://drive.google.com/open?id=1kRi5YvdQTGBi501OBsUEMk1kFvVKQIM6
