Snowflake SOL-C01 Questions Are Designed By Experts
20
Posted at 6 hour before      View:15 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Snowflake SOL-C01 dumps are available on Google Drive shared by TestSimulate: https://drive.google.com/open?id=16CBd7B_2Bq9LiDI46I7UPIwtQD0NhmW6
The TestSimulate is one of the top-rated and leading platforms that offer real and exam trainers verified Snowflake Certified SnowPro Associate - Platform Certification SOL-C01 practice test questions. These Snowflake Certified SnowPro Associate - Platform Certification SOL-C01 exam questions are designed after deep research and verified by qualified Snowflake SOL-C01 exam preparation experts. So rest assured that you will get the top-notch TestSimulate SOL-C01 exam questions. These TestSimulate SOL-C01 exam questions are the ideal Snowflake Certified SnowPro Associate - Platform Certification SOL-C01 exam preparation material that will prepare you to perform well for the final Snowflake Certified SnowPro Associate - Platform Certification SOL-C01 Certification Exam. So rest assured that with the TestSimulate SOL-C01 exam questions you will get everything that is necessary for SOL-C01 exam preparation and success. Take a decision right now and just get registered in Snowflake SOL-C01 certification exam and start preparation with TestSimulate SOL-C01 exam questions. The TestSimulate is committed since the beginning to offer the top-notch Snowflake Certified SnowPro Associate - Platform Certification SOL-C01 exam questions to Snowflake Certified SnowPro Associate - Platform Certification SOL-C01 exam candidates.
We know that you have strong desire for success in your career, now, we recommend you to get the SOL-C01 exam certification. TestSimulate will help you and provide you with the high quality Snowflake training material. SOL-C01 questions are selected and edited from the original questions pool and verified by the professional experts. Besides, the updated of SOL-C01 Pdf Torrent is checked every day by our experts and the new information can be added into the SOL-C01 exam dumps immediately.
2026 SOL-C01: Efficient Valid Snowflake Certified SnowPro Associate - Platform Certification Test ForumAre you planning to attempt the Snowflake Certified SnowPro Associate - Platform Certification (SOL-C01) exam of the SOL-C01 certification? The first hurdle you face while preparing for the Snowflake Certified SnowPro Associate - Platform Certification (SOL-C01) exam is not finding the trusted brand of accurate and updated SOL-C01 exam questions. If you don't want to face this issue then you are at the trusted TestSimulate is offering actual and Latest SOL-C01 Exam Questions that ensure your success in the Snowflake Certified SnowPro Associate - Platform Certification (SOL-C01) certification exam on your maiden attempt.
Snowflake Certified SnowPro Associate - Platform Certification Sample Questions (Q167-Q172):NEW QUESTION # 167
Query History can display data up to how many days?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
InSnowsight, the Query History user interface retains and displays executed query information for up to14 days. This includes query text, status, start/end timestamps, duration, warehouse usage, and result statistics.
Snowsight also offers grouping by session, user, warehouse, and time windows for detailed analytics and troubleshooting.
It is important to distinguish Snowsight UI limits from SQL-based history functions. The table functionINFORMATION_SCHEMA.QUERY_HISTORY()returns only7 daysof history, whereas Snowsight visually retains 14 days. Snowflake's Account Usage views (e.g., QUERY_HISTORY) retain data for longer periods but are meant for programmatic auditing rather than UI display.
Incorrect options:
* 7 days refers only to Information Schema.
* 21 or 28 days are not supported by Snowsight's UI.
Thus, the correct visibility window in the Snowsight interface is14 days.
NEW QUESTION # 168
You are tasked with creating a share to provide access to a database named `CUSTOMER DB'.
This database contains a table 'CUSTOMER INFO and a secure UDF `MASK EMAIL'. You need to grant the necessary privileges on the share such that consumers can use both the table and the UDF. Which of the following SQL statements are required to properly configure the share named 'CUSTOMER SHARE? (Select all that apply)
  • A.
  • B.
  • C.
  • D.
  • E.
Answer: A,B,C,E
To properly configure the share, you need to grant USAGE on the database, SELECT on the table, USAGE on the schema containing the table and UDF, and EXECUTE on the UDF.
Granting ALL PRIVILEGES on the database is generally not recommended for security reasons and is not necessary in this case.
NEW QUESTION # 169
You need to create a database named 'SALES DB' that is only accessible to users with the
'ACCOUNTADMIN' role. After the database is created, you want to grant the 'USAGE' privilege on it to a custom role named 'DATA ANALYST. Which sequence of commands is the MOST efficient and correct way to achieve this?
  • A. USE ROLE ACCOUNTADMIN; CREATE OR REPLACE DATABASE SALES DB; GRANT USAGE ON DATABASE SALES DB TO ROLE DATA ANALYST,
  • B. USE ROLE ACCOUNTADMIN; CREATE DATABASE SALES DB; GRANT USAGE ON
    DATABASE SALES DB TO ROLE DATA ANALYST; USE ROLE DATA ANALYST;
  • C. CREATE OR REPLACE DATABASE SALES DB; GRANT USAGE ON DATABASE SALES DB TO ROLE DATA ANALYST;
  • D. CREATE DATABASE SALES DB; GRANT USAGE ON DATABASE SALES DB TO ROLE DATA ANALYST;
  • E. USE ROLE ACCOUNTADMIN; CREATE DATABASE SALES DB; GRANT USAGE ON
Option E is the most efficient and correct. You first need to assume the 'ACCOUNTADMIN' role to ensure you have the necessary privileges to create the database. While not strictly necessary,
'CREATE OR REPLACE is often preferred as it allows the script to be re-run without errors if the database already exists. Finally, you grant the USAGE' privilege to the 'DATA ANALYST role.
Options A and B do not specify to assume the 'ACCOUNTADMIN' role first. Options C and D does not use the 'CREATE OR REPLACE which is slightly inefficient and option D returns role to Data Analyst after creation which is not required.
NEW QUESTION # 170
Which of the following types of data can be found on Snowflake Marketplace? (Choose any 3 options)
  • A. Third-party data sets
  • B. Proprietary data sets
  • C. Financial market data
  • D. Public data sets
Answer: A,C,D
Snowflake Marketplace serves as a centralized catalog where providers publishready-to-use datasets, models, and applicationsacross industries. It includes:
Public datasets, such as demographics, weather, healthcare statistics, and government data.
Financial market datasets, including equities, commodities, macroeconomic indicators, and pricing feeds from major financial data vendors.
Third-party datasetssupplied by external organizations specializing in geospatial intelligence, retail analytics, marketing insights, healthcare, census data, and more.
"Proprietary datasets" are internal to organizations and typically not published on the public Marketplace unless the owner chooses to list them. Marketplace listings are curated and governed.
NEW QUESTION # 171
What can a schema in Snowflake contain? (Choose any 3 options)
  • A. Tables
  • B. Stage
  • C. Views
  • D. Virtual warehouses
Answer: A,B,C
Aschemain Snowflake is a logical container inside a database that groups related objects. It can containtables, views,stages,file formats,sequences,streams,tasks, and other database objects. Schemas allow structured organization, privilege management, and separation of workloads.
* Tablesstore structured data.
* Viewsare virtual tables defined by queries on other objects.
* Stagesstore data files for loading/unloading.
Virtual warehouses are compute resources, not database objects, and therefore exist outside schemas.
Warehouses belong to the account-level namespace and are managed independently of databases and schemas.
Schemas play a key role in RBAC and object naming through fully qualified names: database.schema.object.
NEW QUESTION # 172
Users are buying something online (such as SOL-C01 learning materials), always want vendors to provide a fast and convenient sourcing channel to better ensure the user's use. Because without a quick purchase process, users of our SOL-C01 learning materials will not be able to quickly start their own review program. So, our company employs many experts to design a fast sourcing channel for our SOL-C01 Learning Materials. All users can implement fast purchase and use our learning materials.
SOL-C01 Trustworthy Exam Torrent: https://www.testsimulate.com/SOL-C01-study-materials.html
Snowflake Valid SOL-C01 Test Forum Without poor after-sales services or long waiting for arrival of products, they can be obtained within 5 minutes with well-built after-sales services, Snowflake Valid SOL-C01 Test Forum If you download and install on your personal computer online, you can copy to any other electronic products and use offline, Best of luck in Snowflake Certified SnowPro Associate - Platform Certification (SOL-C01) exam and professional career!!!
By adding the entry, Excel spreadsheets can be SOL-C01 imported into Numbers, and Numbers documents can be exported to Excel, Without poor after-sales services or long waiting for arrival SOL-C01 Useful Dumps of products, they can be obtained within 5 minutes with well-built after-sales services.
Snowflake - SOL-C01 –Newest Valid Test ForumIf you download and install on your personal computer online, you can copy to any other electronic products and use offline, Best of luck in Snowflake Certified SnowPro Associate - Platform Certification (SOL-C01) exam and professional career!!!
Thirdly, SOL-C01 exam simulator online ensures the candidate will pass their exam at the first attempt, Moreover all exam dumps give free demo download.
BONUS!!! Download part of TestSimulate SOL-C01 dumps for free: https://drive.google.com/open?id=16CBd7B_2Bq9LiDI46I7UPIwtQD0NhmW6
