[Hardware] Fortinet NSE7_SOC_AR-7.6 Exam Online & Guaranteed NSE7_SOC_AR-7.6 Success
27
【Hardware】 Fortinet NSE7_SOC_AR-7.6 Exam Online & Guaranteed NSE7_SOC_AR-7.6 Success
Posted at yesterday 17:36      View:21 | Replies:0        Print      Only Author   [Copy Link] 1#
With EduDump's help, you do not need to spend a lot of money to participate in related cram or spend a lot of time and effort to review the relevant knowledge, but can easily pass the exam. Simulation test software of Fortinet NSE7_SOC_AR-7.6 Exam is developed by EduDump's research of previous real exams. EduDump's Fortinet NSE7_SOC_AR-7.6 exam practice questions have a lot of similarities with the real exam practice questions.
Our NSE7_SOC_AR-7.6 study materials can help you achieve your original goal and help your work career to be smoother and your family life quality to be better and better. There is no exaggeration to say that you will be confident to take part in you exam with only studying our NSE7_SOC_AR-7.6 practice dumps for 20 to 30 hours. And thousands of candidates have achieved their dreams and ambitions with the help of our outstanding NSE7_SOC_AR-7.6 training materials.
Guaranteed Fortinet NSE7_SOC_AR-7.6 Success | Valid NSE7_SOC_AR-7.6 Test CostThe whole payment process on our NSE7_SOC_AR-7.6 exam braindumps only lasts a few seconds as long as there has money in your credit card. Then our system will soon deal with your orders according to the sequence of payment. Usually, you will receive the NSE7_SOC_AR-7.6 Study Materials no more than five minutes. Then you can begin your new learning journey of our NSE7_SOC_AR-7.6 praparation questions. All in all, our payment system and delivery system are highly efficient.
Fortinet NSE 7 - Security Operations 7.6 Architect Sample Questions (Q10-Q15):NEW QUESTION # 10
A customer wants FortiAnalyzer to run an automation stitch that executes a CLI command on FortiGate to block a predefined list of URLs, if a botnet command-and-control (C&C) server IP is detected.
Which FortiAnalyzer feature must you use to start this automation process?
  • A. Event handler
  • B. Connector
  • C. Playbook
  • D. Data selector
* Understanding Automation Processes in FortiAnalyzer:
* FortiAnalyzer can automate responses to detected security events, such as running commands on FortiGate devices.
* Analyzing the Customer Requirement:
* The customer wants to run a CLI command on FortiGate to block predefined URLs when a botnet C&C server IP is detected.
* This requires an automated response triggered by a specific event.
* Evaluating the Options:
* Option Alaybooks orchestrate complex workflows but are not typically used for direct event- triggered automation processes.
* Option Bata selectors filter logs based on criteria but do not initiate automation processes.
* Option C:Event handlers can be configured to detect specific events (such as detecting a botnet C&C server IP) and trigger automation stitches to execute predefined actions.
* Option D:Connectors facilitate communication between FortiAnalyzer and other systems but are not the primary mechanism for initiating automation based on log events.
* Conclusion:
* To start the automation process when a botnet C&C server IP is detected, you must use anEvent handlerin FortiAnalyzer.
Fortinet Documentation on Event Handlers and Automation Stitches in FortiAnalyzer.
Best Practices for Configuring Automated Responses in FortiAnalyzer.
NEW QUESTION # 11
Refer to the exhibits.
You configured a custom event handler and an associated rule to generate events whenever FortiMail detects spam emails. However, you notice that the event handler is generating events for both spam emails and clean emails.
Which change must you make in the rule so that it detects only spam emails?
  • A. In the Log Type field, select Anti-Spam Log (spam)
  • B. Disable the rule to use the filter in the data selector to create the event.
  • C. In the Log filter by Text field, type type==spam.
  • D. In the Trigger an event when field, select Within a group, the log field Spam Name (snane) has 2 or more unique values.
* Understanding the Custom Event Handler Configuration:
* The event handler is set up to generate events based on specific log data.
* The goal is to generate events specifically for spam emails detected by FortiMail.
* Analyzing the Issue:
* The event handler is currently generating events for both spam emails and clean emails.
* This indicates that the rule's filtering criteria are not correctly distinguishing between spam and non-spam emails.
* Option A:Selecting the "Anti-Spam Log (spam)" in the Log Type field will ensure that only logs related to spam emails are considered. This is the most straightforward and accurate way to filter for spam emails.
* Option B:Typing type==spam in the Log filter by Text field might help filter the logs, but it is not as direct and reliable as selecting the correct log type.
* Option Cisabling the rule to use the filter in the data selector to create the event does not address the issue of filtering for spam logs specifically.
* Option D:Selecting "Within a group, the log field Spam Name (snane) has 2 or more unique values" is not directly relevant to filtering spam logs and could lead to incorrect filtering criteria.
* Conclusion:
* The correct change to make in the rule is to select "Anti-Spam Log (spam)" in the Log Type field. This ensures that the event handler only generates events for spam emails.
Fortinet Documentation on Event Handlers and Log Types.
Best Practices for Configuring FortiMail Anti-Spam Settings.
NEW QUESTION # 12
Which three end user logs does FortiAnalyzer use to identify possible IOC compromised hosts? (Choose three.)
  • A. DNS filter logs
  • B. Email filter logs
  • C. IPS logs
  • D. Application filter logs
  • E. Web filter logs
Answer: A,C,E
* Overview of Indicators of Compromise (IoCs): Indicators of Compromise (IoCs) are pieces of evidence that suggest a system may have been compromised. These can include unusual network traffic patterns, the presence of known malicious files, or other suspicious activities.
* FortiAnalyzer's Role: FortiAnalyzer aggregates logs from various Fortinet devices to provide comprehensive visibility and analysis of network events. It uses these logs to identify potential IoCs and compromised hosts.
* Relevant Log Types:
* DNS Filter Logs:
* DNS requests are a common vector for malware communication. Analyzing DNS filter logs helps in identifying suspicious domain queries, which can indicate malware attempting to communicate with command and control (C2) servers.
Reference: Fortinet Documentation on DNS Filtering FortiOS DNS Filter
IPS Logs:
Intrusion Prevention System (IPS) logs detect and block exploit attempts and malicious activities. These logs are critical for identifying compromised hosts based on detected intrusion attempts or behaviors matching known attack patterns.
Reference: Fortinet IPS Overview FortiOS IPS
Web Filter Logs:
Web filtering logs monitor and control access to web content. These logs can reveal access to malicious websites, download of malware, or other web-based threats, indicating a compromised host.
Reference: Fortinet Web Filtering FortiOS Web Filter
Why Not Other Log Types:
Email Filter Logs:
While important for detecting phishing and email-based threats, they are not as directly indicative of compromised hosts as DNS, IPS, and Web filter logs.
Application Filter Logs:
These logs control application usage but are less likely to directly indicate compromised hosts compared to the selected logs.
Detailed Process:
Step 1: FortiAnalyzer collects logs from FortiGate and other Fortinet devices.
Step 2: DNS filter logs are analyzed to detect unusual or malicious domain queries.
Step 3: IPS logs are reviewed for any intrusion attempts or suspicious activities.
Step 4: Web filter logs are checked for access to malicious websites or downloads.
Step 5: FortiAnalyzer correlates the information from these logs to identify potential IoCs and compromised hosts.
Fortinet Documentation: FortiOS DNS Filter, IPS, and Web Filter administration guides.
FortiAnalyzer Administration Guide: Details on log analysis and IoC identification.
By using DNS filter logs, IPS logs, and Web filter logs, FortiAnalyzer effectively identifies possible compromised hosts, providing critical insights for threat detection and response.
NEW QUESTION # 13
Refer to the Exhibit:
An analyst wants to create an incident and generate a report whenever FortiAnalyzer generates a malicious attachment event based on FortiSandbox analysis. The endpoint hosts are protected by FortiClient EMS integrated with FortiSandbox. All devices are logging to FortiAnalyzer.
Which connector must the analyst use in this playbook?
  • A. FortiClient EMS connector
  • B. FortiSandbox connector
  • C. Local connector
  • D. FortiMail connector
* Understanding the Requirements:
* The objective is to create an incident and generate a report based on malicious attachment events detected by FortiAnalyzer from FortiSandbox analysis.
* The endpoint hosts are protected by FortiClient EMS, which is integrated with FortiSandbox. All logs are sent to FortiAnalyzer.
* Key Components:
* FortiAnalyzer: Centralized logging and analysis for Fortinet devices.
* FortiSandbox: Advanced threat protection system that analyzes suspicious files and URLs.
* FortiClient EMS: Endpoint management system that integrates with FortiSandbox for endpoint protection.
* Playbook Analysis:
* The playbook in the exhibit consists of three main actions: GET_EVENTS, RUN_REPORT, and CREATE_INCIDENT.
* EVENT_TRIGGER: Starts the playbook when an event occurs.
* GET_EVENTS: Fetches relevant events.
* RUN_REPORT: Generates a report based on the events.
* CREATE_INCIDENT: Creates an incident in the incident management system.
* Selecting the Correct Connector:
* The correct connector should allow fetching events related to malicious attachments analyzed by FortiSandbox and facilitate integration with FortiAnalyzer.
* Connector Options:
* FortiSandbox Connector:
* Directly integrates with FortiSandbox to fetch analysis results and events related to malicious attachments.
* Best suited for getting detailed sandbox analysis results.
* Selected as it is directly related to the requirement of handling FortiSandbox analysis events.
* FortiClient EMS Connector:
* Used for managing endpoint security and integrating with endpoint logs.
* Not directly related to fetching sandbox analysis events.
* Not selected as it is not directly related to the sandbox analysis events.
* FortiMail Connector:
* Used for email security and handling email-related logs and events.
* Not applicable for sandbox analysis events.
* Not selected as it does not relate to the sandbox analysis.
* Local Connector:
* Handles local events within FortiAnalyzer itself.
* Might not be specific enough for fetching detailed sandbox analysis results.
* Not selected as it may not provide the required integration with FortiSandbox.
* Implementation Steps:
* Step 1: Ensure FortiSandbox is configured to send analysis results to FortiAnalyzer.
* Step 2: Use the FortiSandbox connector in the playbook to fetch events related to malicious attachments.
* Step 3: Configure the GET_EVENTS action to use the FortiSandbox connector.
* Step 4: Set up the RUN_REPORT and CREATE_INCIDENT actions based on the fetched events.
Fortinet Documentation on FortiSandbox Integration FortiSandbox Integration Guide Fortinet Documentation on FortiAnalyzer Event Handling FortiAnalyzer Administration Guide By using the FortiSandbox connector, the analyst can ensure that the playbook accurately fetches events based on FortiSandbox analysis and generates the required incident and report.
NEW QUESTION # 14
Which two ways can you create an incident on FortiAnalyzer? (Choose two.)
  • A. Using a connector action
  • B. Manually, on the Event Monitor page
  • C. By running a playbook
  • D. Using a custom event handler
* Understanding Incident Creation in FortiAnalyzer:
* FortiAnalyzer allows for the creation of incidents to track and manage security events.
* Incidents can be created both automatically and manually based on detected events and predefined rules.
* Analyzing the Methods:
* Option A:Using a connector action typically involves integrating with other systems or services and is not a direct method for creating incidents on FortiAnalyzer.
* Option B:Incidents can be created manually on the Event Monitor page by selecting relevant events and creating incidents from those events.
* Option C:While playbooks can automate responses and actions, the direct creation of incidents is usually managed through event handlers or manual processes.
* Option D:Custom event handlers can be configured to trigger incident creation based on specific events or conditions, automating the process within FortiAnalyzer.
* Conclusion:
* The two valid methods for creating an incident on FortiAnalyzer are manually on the Event Monitor page and using a custom event handler.
Fortinet Documentation on Incident Management in FortiAnalyzer.
FortiAnalyzer Event Handling and Customization Guides.
NEW QUESTION # 15
Our Fortinet NSE 7 - Security Operations 7.6 Architect (NSE7_SOC_AR-7.6) exam dumps are useful for preparation and a complete source of knowledge. If you are a full-time job holder and facing problems finding time to prepare for the Fortinet NSE 7 - Security Operations 7.6 Architect (NSE7_SOC_AR-7.6) exam questions, you shouldn't worry more about it. One of the main unique qualities of the EduDump Fortinet Exam Questions is its ease of use. Our practice exam simulators are user and beginner friendly. You can use Fortinet NSE 7 - Security Operations 7.6 Architect (NSE7_SOC_AR-7.6) PDF dumps and Web-based software without installation. Fortinet NSE 7 - Security Operations 7.6 Architect (NSE7_SOC_AR-7.6) PDF questions work on all the devices like smartphones, Macs, tablets, Windows, etc. We know that it is hard to stay and study for the Fortinet NSE 7 - Security Operations 7.6 Architect (NSE7_SOC_AR-7.6) exam dumps in one place for a long time. Therefore, you have the option to use Fortinet NSE 7 - Security Operations 7.6 Architect (NSE7_SOC_AR-7.6) PDF questions anywhere and anytime.
Guaranteed NSE7_SOC_AR-7.6 Success: https://www.edudump.com/exams/Fortinet/NSE7_SOC_AR-7.6/
However, the appearance of our NSE7_SOC_AR-7.6 certification materials will solve your question and change your impression of NSE7_SOC_AR-7.6 certification exam, Based on advanced technological capabilities, our NSE7_SOC_AR-7.6 study materials are beneficial for the masses of customers, Fortinet NSE7_SOC_AR-7.6 Exam Online The test has vital sections where questions are arranged as per their level of difficulty, EduDump Guaranteed NSE7_SOC_AR-7.6 Success release the best exam preparation materials to help you exam at the first attempt.
Select the Eraser tool on the Standard toolbar, A NSE7_SOC_AR-7.6 Free Exam class can have multiple constructors to change the way in which the object is created, However, the appearance of our NSE7_SOC_AR-7.6 Certification Materials will solve your question and change your impression of NSE7_SOC_AR-7.6 certification exam.
100% Pass Quiz Fortinet NSE7_SOC_AR-7.6 Latest Exam OnlineBased on advanced technological capabilities, our NSE7_SOC_AR-7.6 study materials are beneficial for the masses of customers, The test has vital sections where questions are arranged as per their level of difficulty.
EduDump release the best exam preparation materials to help you exam at the NSE7_SOC_AR-7.6 first attempt, The Fortinet practice test software simulates real exam scenarios for you to get used to the pressure of the Fortinet certification exam.
