[General] Salesforce CRT-450 Exam Collection, CRT-450 pass rate
26
【General】 Salesforce CRT-450 Exam Collection, CRT-450 pass rate
Posted at 8 hour before      View:12 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Prep4SureReview CRT-450 dumps for free: https://drive.google.com/open?id=1hYPDvey4ve9HHBmsBK8VSLuBce8xYBUF
Prep4SureReview is a reputable platform that has been providing valid, real, updated, and free Salesforce Certified Platform Developer I CRT-450 Exam Questions for many years. Prep4SureReview is now the customer's first choice and has the best reputation in the market. Salesforce CRT-450 Actual Dumps are created by experienced and certified professionals to provide you with everything you need to learn, prepare for, and pass the difficult Salesforce CRT-450 exam on your first try.
Salesforce CRT-450 certification exam is designed for professionals who are interested in building custom applications on the Salesforce platform. CRT-450 exam covers a wide range of topics, including the Salesforce development environment, data modeling and management, Apex programming language, Visualforce user interface framework, and testing and deployment. CRT-450 Exam aims to test the candidates' understanding of the Salesforce development process and their ability to design, develop, test, and deploy custom applications.
100% Pass Quiz Salesforce CRT-450 Latest Latest Test PracticeAs a reliable product website, we have the responsibility to protect our customers' personal information leakage and your payment security. So you can be rest assured the purchase of our CRT-450 exam software. Besides, we have the largest IT exam repository, if you are interested in CRT-450 Exam or any other exam dumps, you can search on our Prep4SureReview or chat with our online support any time you are convenient. Wish you success in CRT-450 exam.
The Salesforce CRT-450 Exam consists of 60 multiple-choice questions that need to be answered in 105 minutes. To pass the exam, you need to score at least 68%, which means you need to answer at least 41 questions correctly out of the 60 questions.
Salesforce Certified Platform Developer I Sample Questions (Q185-Q190):NEW QUESTION # 185
A developer wants to invoke on outbound message when a record meets a specific criteria.
Which three features satisfy this use case?
Choose 3 answer
  • A. Approval Process has the capacity to check the record criteria and send an outbound message without Apex Code
  • B. Process builder can be used to check the record criteria and send an outbound message with Apex Code.
  • C. Process builder can be used to check the record criteria and send an outbound messagewithout Apex Code.
  • D. workflows can be used to check the record criteria and send an outbound message.
  • E. Visual Workflow can be used to check the record criteria and send an outbound message without Apex Code.
Answer: A,B,D
NEW QUESTION # 186
In a single record, a user selects multiple values from a multi-select picklist.
How are the selected values represented in Apex?
  • A. As a Stringwith each value separated by a comma
  • B. As a List<String>with each value as an element in the list
  • C. As a Set<String>with each value as an element in the set
  • D. As a Stringwith each value separated by a semicolon
NEW QUESTION # 187
A developer must modify the following code snippet to prevent the number of SOQL queries issued from exceeding the platform governor limit. public class without sharing OpportunityService( public   static   List<OpportunityLineItem>   getOpportunityProducts(Set<Id>   opportunityIds){ List<OpportunitylineItem> oppLineItems = new List<OpportunityLineItem>();   for(Id thisOppId :
opportunityIds){   oppLineItems.addAll([Select Id FROM OpportunityLineItems WHERE OpportunityId = :thisOppId)];   } return oppLineItems; } } The above method might be called during a trigger execution via a Lightning component. Which technique should be implemented to avoid reaching the governor limit?
  • A. Use the System.Limits.getlimitQueries() method to ensure the number of queries is less than 100.
  • B. Use the System.Limits.getQueries() method to ensure the number of queries is less than 100.
  • C. Refactor the code above to perform only one SOQL query, filtering by the Set of opportunityIds.
  • D. Refector the code above to perform the SOQL query only if the Set of opportunityIds contains less 100 Ids.
NEW QUESTION # 188
A developer considers the following snippet of code:
Based an this code, what is the value of x?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
NEW QUESTION # 189
Developer needs to automatically populate the Reports To field in a Contact record based on the values of the related Account and Department fields in the Contact record. Which type of trigger would the developer create? Choose 2 answers
  • A. Before update
  • B. After insert
  • C. Before insert
  • D. After update
NEW QUESTION # 190
Simulation CRT-450 Questions: https://www.prep4surereview.com/CRT-450-latest-braindumps.html
BTW, DOWNLOAD part of Prep4SureReview CRT-450 dumps from Cloud Storage: https://drive.google.com/open?id=1hYPDvey4ve9HHBmsBK8VSLuBce8xYBUF
