[General] Pass4sure Red Hat Certified Specialist in OpenShift Automation and Integration c
25
【General】 Pass4sure Red Hat Certified Specialist in OpenShift Automation and Integration c
Posted at 5/16/2026 18:30:59      View:76 | Replies:0        Print      Only Author   [Copy Link] 1#
Some people prefer to read paper materials rather than learning on computers. Of course, your wish can be fulfilled in our company. We have PDF version EX380 exam guides, which are printable format. You can print it on papers after you have downloaded it successfully. If you want to change the fonts, sizes or colors, you can transfer the EX380 exam torrent into word format files before printing. There are many advantages of the PDF version. Firstly, there are no restrictions to your learning. You can review the EX380 Test Answers everywhere. You spare time can be made good use. Secondly, you can make notes on your materials, which will accelerate your understanding of the EX380 exam guides. In a word, our company seriously promises that we do not cheat every customer.
Have similar features to the desktop-based exam simulator contains actual RedHat EX380 Practice Test that will help you grasp every topic Compatible with every operating system such as Mac, Linus, iOS, Windows, and Android Works properly on Google chrome, Internet explorer, Microsoft Edge, Opera, etc. Does not require any special plugins to operate creates an exam atmosphere making candidates more confident. Keep track of your progress with self-analysis Points out mistakes at the end of every attempt.
EX380 Demo Test - EX380 Related CertificationsTo practice for a Red Hat Certified Specialist in OpenShift Automation and Integration in the software (free test), you should perform a self-assessment. The RedHat EX380 practice test software keeps track of each previous attempt and highlights the improvements with each attempt. The RedHat EX380 Mock Exam setup can be configured to a particular style & arrive at unique questions.
RedHat Red Hat Certified Specialist in OpenShift Automation and Integration Sample Questions (Q23-Q28):NEW QUESTION # 23
Kubeconfig Management - Approve CSR
See the solution below in Explanation:
Step 1: Identify the pending certificate signing request.
The lab names it audit-csr.
Step 2: Run the approval command:
oc adm certificate approve audit-csr
Step 3: Confirm approval.
The lab output shows:
certificatesigningrequest.certificates.k8s.io/audit-csr approved
Detailed explanation:
In Kubernetes and OpenShift, a CSR must be approved before the requester can use the signed certificate for authentication. This Task approves the CSR named audit-csr, which is likely associated with the audit user or service account access flow in the lab. Certificate-based authentication is commonly used for kubeconfig access because it enables secure client identity without relying solely on tokens. Until the CSR is approved, the certificate cannot be trusted by the cluster API for authenticated operations. Administrative approval is therefore a gatekeeping step that ensures only intended certificate requests become valid credentials. This Task is part of a broader kubeconfig workflow that continues with setting credentials and defining context.
NEW QUESTION # 24
Create an Argo CD Application (OpenShift GitOps)
Task Information : Create an Argo CD Application that syncs from Git into namespace gitops-demo with automated sync enabled.
* Create target namespace
* oc new-project gitops-demo
* Destination must exist (unless Argo is configured to auto-create).
* Create Application manifest
* apiVersion: argoproj.io/v1alpha1
* kind: Application
* metadata:
* name: demo-app
* namespace: openshift-gitops
* spec:
* project: default
* source:
* repoURL: https://git.example.com/org/repo.git
* targetRevision: main
* path: manifests/demo
* destination:
* server: https://kubernetes.default.svc
* namespace: gitops-demo
* syncPolicy:
* automated:
* prune: true
* selfHeal: true
* automated: enables auto sync.
* prune: removes deleted objects from Git.
* selfHeal: corrects drift.
* Apply Application
* oc apply -f demo-app.yaml
* Verify sync health
* oc -n openshift-gitops get application demo-app -o yaml | grep -i -E "sync|health" -n
* oc -n gitops-demo get all
NEW QUESTION # 25
Deploy Event Router and capture Kubernetes events in logging
Task Information : Deploy an event router so Kubernetes events are recorded as logs, then trigger events and confirm they appear in logging queries.
* Deploy event router resources
* Apply a deployment/serviceaccount/rolebinding manifest for eventrouter:
* oc apply -f eventrouter.yaml -n openshift-logging
* Eventrouter watches event API and writes them to stdout (collected by logging).
* Verify eventrouter pod is running
* oc -n openshift-logging get pods | grep -i event
* Trigger some events
* oc -n default run evtest --image=busybox --restart=Never -- sleep 1
* oc -n default delete pod evtest
* Creation/deletion generates events.
* Query logs for events
* In the logging UI/backend, search for the namespace/pod name evtest or eventrouter messages.
* Explanation: Validates that events are being converted to searchable logs.
NEW QUESTION # 26
Maintain group synchronization on a schedule (CronJob)
Task Information : Create a CronJob that runs LDAP group sync on a schedule using a service account that has the required permissions.
* Create a namespace for the sync job
* oc new-project id-sync
* Keeps the automation components organized.
* Create a service account for the sync job
* oc -n id-sync create sa group-sync
* CronJob runs under this SA identity.
* Grant cluster permissions to manage groups
* oc adm policy add-cluster-role-to-user cluster-admin system:serviceaccount:id-sync:group-sync
* In real environments you should scope down, but lab Task SIMULATIONs often accept cluster- admin for speed.
* Create a ConfigMap for groupsync.yaml and Secret(s) for bind password/CA
* Mount them into the job container.
* Create CronJob to run group sync
* Command inside job:
* oc adm groups sync --sync-config=/config/groupsync.yaml --confirm
* The CronJob ensures periodic reconciliation with LDAP.
* Verify job runs
* oc -n id-sync get cronjob
* oc -n id-sync get jobs
* oc -n id-sync logs job/ < job-name >
NEW QUESTION # 27
Configure and synchronize OpenShift groups from LDAP (group sync)
Task Information : Create an LDAP group-sync config, run a one-time sync, and confirm groups exist in OpenShift.
* Create a group sync config file (example groupsync.yaml)
* This file defines how OpenShift queries LDAP for groups and members.
* Run a one-time group sync
* oc adm groups sync --sync-config=groupsync.yaml --confirm
* --confirm actually applies changes (without it, it's a dry-run preview).
* Verify groups created/updated
* oc get groups
* oc describe group < groupname >
* Confirms group objects exist and membership is present.
NEW QUESTION # 28
If you are finding a study material in order to get away from your exam, you can spend little time to know about our EX380 test torrent, it must suit for you. Therefore, for your convenience, more choices are provided for you, we are pleased to suggest you to choose our Red Hat Certified Specialist in OpenShift Automation and Integration guide torrent for your exam. If you choice our product and take it seriously consideration, we can make sure it will be very suitable for you to help you pass your exam and get the EX380 Certification successfully. You will find Our EX380 guide torrent is the best choice for you
EX380 Demo Test: https://www.torrentvalid.com/EX380-valid-braindumps-torrent.html
In the world of industry, EX380 Demo Test certification is the key to a successful career, Believe us because the EX380 test prep are the most useful and efficient, and the EX380 exam preparation will make you master the important information and the focus of the exam, If you choose our EX380 exam guide, under the guidance of our EX380 exam torrent, we have the confidence to guarantee a passing rate of over 99%, If you are quite satisfied with EX380 exam materials and want the complete version, you just need to add them to cart and pay for it.
Remember, you're only as quiet as your loudest fan, I always offer the same EX380 advice regarding school choice  learning to think and write is much more important than choosing a major, especially in undergrad school.
Red Hat Certified Specialist in OpenShift Automation and Integration Prep Practice & EX380 Exam Torrent & Red Hat Certified Specialist in OpenShift Automation and Integration Updated TrainingIn the world of industry, Red Hat OpenShift certification is the key to a successful career, Believe us because the EX380 Test Prep are the most useful and efficient, and the EX380 exam preparation will make you master the important information and the focus of the exam.
The software keeps track of the previous Red Hat Certified Specialist in OpenShift Automation and Integration (EX380) practice exam attempts and shows the changes of each attempt.
