[General] Real 1z1-809 Braindumps - Latest 1z1-809 Mock Test
28
【General】 Real 1z1-809 Braindumps - Latest 1z1-809 Mock Test
Posted at yesterday 21:31      View:17 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Pass4training 1z1-809 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1rjpivlA9vxhwtTy6XyVTIW7xO5Kz1RhY
If you don't prepare with real Oracle 1z1-809 questions, you fail, lose time and money. Pass4training product is specially designed to help you pass the exam on the first try. The study material is easy to use. You can choose from 3 different formats available according to your needs. The 3 formats are Oracle 1z1-809 desktop practice test software, browser based practice exam, and PDF.
To take the Oracle 1z0-809 exam, you should have a good understanding of Java programming, including topics such as inheritance, polymorphism, interfaces, and exceptions. You should also be familiar with the various Java API packages, including java.time, java.io, and java.util. Additionally, you should be comfortable with using Java tools such as Eclipse or NetBeans to develop, debug, and test Java applications.
Latest Oracle 1z1-809 Mock Test, 1z1-809 Dump FileIn this knowledge-dominated world, the combination of the knowledge and the practical working competences has been paid high attention to is extremely important. If you want to improve your practical abilities you can attend the 1z1-809 certificate examination. Passing the 1z1-809 Certification can prove that you boost both the practical abilities and the knowledge and if you buy our 1z1-809 latest question you will pass the 1z1-809 exam smoothly.
Oracle 1z1-809 Certification Exam consists of 85 multiple-choice questions that need to be completed in 150 minutes. 1z1-809 exam covers various topics such as Java Class Design, Generics and Collections, Lambda Built-in Functional Interfaces, Java Stream API, Exceptions and Assertions, Java I/O Fundamentals, Java Concurrency, JDBC, Localization, Annotations, and Java Date/Time API. To pass the exam, you need to score at least 65% of the total marks. By passing the Java SE 8 Programmer II certification exam, you become a certified Java programmer and gain expertise in advanced Java programming concepts.
The Oracle 1z1-809 Exam covers a wide range of topics, including advanced Java class design, generics and collections, lambda expressions, concurrency, JDBC, and security. 1z1-809 exam also tests the candidate's ability to write advanced Java code and solve complex programming problems.
Oracle Java SE 8 Programmer II Sample Questions (Q61-Q66):NEW QUESTION # 61
Given the code fragments:
class TechName   {
String techName;
TechName (String techName) {
this.techName=techName;
and
List<TechName> tech = Arrays.asList (
new TechName("Java-"),
new TechName("Oracle DB-"),
new TechName("J2EE-")
Stream<TechName> stre = tech.stream();
/ /line n1
Which should be inserted at line n1 to print Java-Oracle DB-J2EE-?
  • A. stre.forEach(System.out::print);
  • B. stre.map(a-> a).forEachOrdered(System.out::print);
  • C. stre.map(a-> a.techName).forEach(System.out::print);
  • D. stre.forEachOrdered(System.out::print);
NEW QUESTION # 62
Given:
Which two classes use the shape class correctly?
  • A. Option E
  • B. Option C
  • C. Option A
  • D. Option D
  • E. Option B
  • F. Option F
Answer: A,E
When an abstract class is subclassed, the subclass usually provides implementations for all of the abstract methods in its parent class (E). However, if it does not, then the subclass must also be declared abstract (B). Note: An abstract class is a class that is declared abstract--it may or may not include abstract methods. Abstract classes cannot be instantiated, but they can be subclassed.
NEW QUESTION # 63
Given:
What is the result?
  • A. Hi MyClass
  • B. A compilation error occurs.
  • C. Hi Interface-2
  • D. Hi Interface-1
NEW QUESTION # 64
Given the following code for the classes MyException and Test:
What is the result?
  • A. A compile time error occurs at line n1.
  • B. Either A or B
  • C. B
  • D. A
  • E. AB
NEW QUESTION # 65
Given the code fragment:
Which code fragment, when inserted at line 7, enables printing 100?
  • A. ToIntFunction<Integer> funRef = e -> e + 10;
    int result = funRef.applyAsInt (value);
  • B. ToIntFunction funRef = e -> e + 10;
    int result = funRef.apply (value);
  • C. IntFunction funRef = e -> e + 10;
    Integer result = funRef.apply (10);
  • D. Function<Integer> funRef = e -> e + 10;
    Integer result = funRef.apply(value);
NEW QUESTION # 66
Latest 1z1-809 Mock Test: https://www.pass4training.com/1z1-809-pass-exam-training.html
BTW, DOWNLOAD part of Pass4training 1z1-809 dumps from Cloud Storage: https://drive.google.com/open?id=1rjpivlA9vxhwtTy6XyVTIW7xO5Kz1RhY
