[General] C-ARCIG-2508 Pdf Demo Download, C-ARCIG-2508 Test Pdf
28
【General】 C-ARCIG-2508 Pdf Demo Download, C-ARCIG-2508 Test Pdf
Posted at yesterday 22:08      View:16 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ExamDiscuss C-ARCIG-2508 dumps for free: https://drive.google.com/open?id=1MkCTtY91eCibkXahSYCPQPIHHNy6YypR
Are you preparing for the SAP C-ARCIG-2508 certification exam? Whether you're an experienced professional SAP C-ARCIG-2508 looking to take your career to the next level or a recent graduate trying to break into the tech field, the road to SAP C-ARCIG-2508 Certification can be a long and challenging one. The good news is that you do not have to navigate it alone.
SAP C-ARCIG-2508 Exam Syllabus Topics:
  • SAP Ariba Cloud Integration Overview: This section of the exam measures skills of Solution Architects and covers the foundational knowledge of SAP Ariba Cloud integration. It ensures familiarity with the general integration landscape and prepares candidates to understand the key elements of cloud connectivity.
  • Managed Gateway Tools: This section of the exam measures skills of Solution Architects and addresses the tools provided within Managed Gateway. It covers their role in monitoring, managing, and troubleshooting integration scenarios.
  • Supplier Lifecycle Performance: This section of the exam measures the skills of Implementation Consultants and includes the setup and management of supplier lifecycle performance processes. It validates understanding of integration elements supporting supplier evaluation and collaboration.
  • SAP Ariba Procurement Integration Configuration: This section of the exam measures the skills of Implementation Consultants and focuses on procurement-related integration tasks. It highlights knowledge of system setup that enables seamless procurement processes between SAP Ariba and SAP S
  • 4HANA.
Topic 5
  • SAP Ariba AddOn Simplified Configuration (SPRO): This section of the exam measures the skills of Solution Architects and includes simplified configuration through the SPRO transaction in SAP. It ensures candidates can manage add-on settings to streamline system deployment.
Top C-ARCIG-2508 Pdf Demo Download | Efficient C-ARCIG-2508 Test Pdf: SAP Certified Associate - Implementation Consultant - Managed gateway for spend management and SAP Business NetworkOur C-ARCIG-2508 practice test is high quality product revised by hundreds of experts according to the changes in the syllabus and the latest developments in theory and practice, it is focused and well-targeted, so that each student can complete the learning of important content in the shortest time. With C-ARCIG-2508 training prep, you only need to spend 20 to 30 hours of practice before you take the C-ARCIG-2508 exam. Meanwhile, using our C-ARCIG-2508 exam questions, you don't need to worry about missing any exam focus.
SAP Certified Associate - Implementation Consultant - Managed gateway for spend management and SAP Business Network Sample Questions (Q28-Q33):NEW QUESTION # 28
Which parameters are relevant to extract supplier location master data? Note: There are 2 correct answers to this question.
  • A. SL_VENDOR_ADDRESS
  • B. SL_VENDOR_TYPE
  • C. SL_PARTNER_TYPE
  • D. SL_PARTNER_ADDRESS
NEW QUESTION # 29
You are migrating from Ariba Cl to SAP Managed Gateway for Spend&Network solutions. If you choose to make changes to the partner profile manually, which of the following fields of outbound parameters should you focus on? Note: There are 3correctanswers to this question.
  • A. Extension
  • B. Basic Type
  • C. Receiver Port
  • D. Message Type
  • E. Partner No.
Answer: A,B,C
NEW QUESTION # 30
You are defining the project connection for the Mediated Connectivity deployment. When will a specific system ID value be available for selection in the System ID field's drop-down menu?
  • A. When the middleware is fully integrated with the Managed Gateway for Soend&Network portal
  • B. When you maintain the Logical System ID via the Global Settings activity in the Managed Gateway- AddOn
  • C. When you have the Basic Data or Trading Partner System information populated with that system ID in the Managed Gateway for Spend&Network portal
  • D. When the System ID is made available in the Resources section of the Managed Gateway for Spend&Network portal
From the "Creating a Connection for Mediated Connectivity Integration" module on learning.sap.com, the System ID value becomes available in the System ID dropdown menu when system information has been added in the Resources (also called "Basic Data - Trading Partner System Information") section of the Spend
& Network portal. SAP Learning
Among the provided options, the one that matches this description is: A.
When the System ID is made available in the Resources section of the Spend & Network portal So the correct answer is A.
NEW QUESTION # 31
For which of the following fields are default XPaths available for the PurchaseOrderExportRequest document type in custom-based routing? Note: There are 2 correct answers to this question.
  • A. CompanyCode
  • B. VendorID
  • C. Purchase Org
  • D. Purchase Group
NEW QUESTION # 32
Which of the following API types does SAP recommend to use to achieve clean core integrations? Note: There are 2 correct answers to this question.
  • A. SOAP
  • B. IDoc
  • C. OData
  • D. RFC
NEW QUESTION # 33
The SAP Certified Associate - Implementation Consultant - Managed gateway for spend management and SAP Business Network has become very significant to validate expertise and level up career. Success in the SAP Certified Associate - Implementation Consultant - Managed gateway for spend management and SAP Business Network exam helps you meet the ever-changing dynamics of the tech industry. latest SAP Certified Associate - Implementation Consultant - Managed gateway for spend management and SAP Business Network C-ARCIG-2508 Exam Cram Pdf, collection pdf and exam dumps have been provided in ExamDiscuss. With 365 days updates.
C-ARCIG-2508 Test Pdf: https://www.examdiscuss.com/SAP/exam/C-ARCIG-2508/
BTW, DOWNLOAD part of ExamDiscuss C-ARCIG-2508 dumps from Cloud Storage: https://drive.google.com/open?id=1MkCTtY91eCibkXahSYCPQPIHHNy6YypR
