Pass ISO-IEC-27001-Lead-Auditor-CN Guaranteed - ISO-IEC-27001-Lead-Auditor-CN Sa
Posted at 7 day before
P.S. Free 2026 PECB ISO-IEC-27001-Lead-Auditor-CN dumps are available on Google Drive shared by PassExamDumps: https://drive.google.com/open?id=1d9E_bR8Y4H03aGkSO0dbiVR5kgWqSXa3
As we all know, if you get a ISO-IEC-27001-Lead-Auditor-CN certification in a large company, you will have more advantages no matter you apply for jobs or establish some business. With a ISO-IEC-27001-Lead-Auditor-CN certification, you can not only get a good position in many companies, but also make your financial free come true. Besides, you can have more opportunities and challenge that will make your life endless possibility. We promise you that ISO-IEC-27001-Lead-Auditor-CN Actual Exam must be worth purchasing, and they can be your helper on your way to get success in gaining the certificate. So why not have a detailed interaction with our ISO-IEC-27001-Lead-Auditor-CN study material?
ISO-IEC-27001-Lead-Auditor-CN practice prep broke the limitations of devices and networks. You can learn anytime, anywhere. As long as you are convenient, you can choose to use a computer to learn, you can also choose to use mobile phone learning. No matter where you are, you can choose your favorite equipment to study our ISO-IEC-27001-Lead-Auditor-CN Learning Materials. As you may know that we have three different ISO-IEC-27001-Lead-Auditor-CN exam questions which have different advantages for you to choose.
Free PDF 2026 PECB Updated ISO-IEC-27001-Lead-Auditor-CN: Pass PECB Certified ISO/IEC 27001 Lead Auditor exam (ISO-IEC-27001-Lead-Auditor中文版) GuaranteedIf you want to sharpen your skills, and get the PECB Certified ISO/IEC 27001 Lead Auditor exam (ISO-IEC-27001-Lead-Auditor中文版) (ISO-IEC-27001-Lead-Auditor-CN) certification done within the target period, it is important to get the best PECB Certified ISO/IEC 27001 Lead Auditor exam (ISO-IEC-27001-Lead-Auditor中文版) (ISO-IEC-27001-Lead-Auditor-CN) exam questions. You must try the PassExamDumps PECB Certified ISO/IEC 27001 Lead Auditor exam (ISO-IEC-27001-Lead-Auditor中文版) (ISO-IEC-27001-Lead-Auditor-CN) practice exam that will help you get the PECB ISO-IEC-27001-Lead-Auditor-CN Certification. PassExamDumps hires the top industry experts to draft the PECB Certified ISO/IEC 27001 Lead Auditor exam (ISO-IEC-27001-Lead-Auditor中文版) (ISO-IEC-27001-Lead-Auditor-CN) exam dumps and help the candidates to clear their PECB Certified ISO/IEC 27001 Lead Auditor exam (ISO-IEC-27001-Lead-Auditor中文版) (ISO-IEC-27001-Lead-Auditor-CN) exam easily. PassExamDumps plays a vital role in their journey to get the ISO-IEC-27001-Lead-Auditor-CN certification.
PECB Certified ISO/IEC 27001 Lead Auditor exam (ISO-IEC-27001-Lead-Auditor中文版) Sample Questions (Q395-Q400):NEW QUESTION # 395
情境 8:EsBank 自 9 月起為愛沙尼亞銀行業提供銀行和金融解決方案
2010年,該公司在全國擁有30家分行和100多台ATM機。
EsBank 在高度監管的行業中運營,必須遵守許多有關資料安全和隱私的法律和法規。他們需要透過實施技術和非技術控制來管理整個營運的資訊安全。 EsBank 決定實施基於 ISO/IEC 的 ISMS
27001,因為它提供了更好的安全性、更多的風險控制以及符合法律法規的關鍵要求。
在成功實施 ISMS 九個月後,EsBank 決定由獨立認證機構根據 ISO/IEC 27001 對其 ISMS 進行認證。
第一階段和第二階段審核是共同進行的,發現了一些不符合項。第一個不合格之處與 EsBank 的資訊標籤有關。該公司有資訊分類方案,但沒有資訊標籤程序。因此,需要相同保護等級的文件將被貼上不同的標籤(有時為機密,有時為敏感)。
考慮到所有文件也以電子方式存儲,不合格情況也影響了媒體處理。審計小組透過抽樣得出結論,200 個可移動媒體中有 50 個儲存了被錯誤分類為機密的敏感資訊。根據資訊分類方案,允許將機密資訊儲存在可移動媒體中,而嚴格禁止儲存敏感資訊。這標誌著另一個不合格之處。
他們起草了不合格報告,並與 EsBank 代表討論了審計結論,代表同意在兩個月內針對發現的不合格問題提交行動計劃。
EsBank 接受了審計組組長提出的解決方案。他們根據實體和電子格式的分類方案起草了資訊標籤程序,解決了不合格問題。可移動媒體程式也基於此程式進行了更新。
審計完成兩週後,EsBank 提交了總體行動計畫。在那裡,他們解決了檢測到的不合格問題以及採取的糾正措施,但沒有包括有關受影響的系統、控製或操作的任何詳細資訊。審核小組評估了該行動計劃並得出結論,該計劃將解決不合格問題。然而,EsBank 收到了不利的認證建議。
根據上述場景,回答以下問題:
根據情境 8,審核小組評估了行動計畫並得出結論,該計畫將解決檢測到的不符合項。這是可以接受的嗎?
- A. 是,前提是 EsBank 之前已經驗證了行動計劃的有效性,並告知審核團隊該行動計劃允許糾正不合格項
- B. 是的。審核小組必須評估行動計畫並驗證其是否適合糾正檢測到的不合格項
- C. 否,被審核方應驗證行動計畫是否允許糾正不合格項並消除根本原因
Yes, the audit team must evaluate the action plan and verify if it is appropriate for correcting the detected nonconformities. This is part of the auditor's responsibilities to ensure that the proposed actions adequately address the issues identified during the audit.
NEW QUESTION # 396
場景 9:Techmanic 是一家比利時公司,成立於 1995 年,目前在布魯塞爾運作。它提供 IT 諮詢、軟體設計和硬體/軟體服務,包括部署和維護。該公司服務於公共服務、金融、電信、能源、醫療保健和教育等行業。作為一家以客戶為中心的公司,它優先考慮建立牢固的客戶關係並引領安全實踐。
Techmanic 已獲得 ISO/IEC 27001 認證一年,並對此認證感到自豪。在認證審核期間,審核員發現其 ISMS 實施上存在一些不一致之處。由於觀察到的情況並不影響其 ISMS 實現預期結果的能力,因此在審計師遠端跟進根本原因分析和糾正措施後,Techmanic 獲得了認證。的遵守情況。認識持續改進的價值並從過去的評估中學習。 Techmanic 實施了審查先前的監督審計報告的做法。這種積極主動的方法不僅有助於識別和解決潛在的不合格情況,而且還旨在簡化 IT 諮詢領域的重新認證流程。
監督審核期間,發現了多處不符合項。 ISMS 繼續滿足 ISO/IEC 27001*s 的要求,但根據內部稽核員的報告,Techmanic 未能解決與託管服務相關的不符合問題。此外,內部稽核報告存在多處不一致之處,這使人們對內部稽核師在託管服務審計過程中的獨立性產生了質疑。基於此,延期認證未獲核准。因此。 Techmanic 請求轉移到另一個認證機構。同時,該公司向客戶發布聲明稱,ISO/IEC 27001 認證涵蓋 IT 服務以及託管服務。
根據上述情景,回答以下問題:
根據 ISO/IEC 17021-1,監督審核的目的為何?
- A. 評估組織的財務績效
- B. 在審核期間保持對認證管理系統的信心
- C. 評估合規性並授予初始認證
Relevant Standard Reference:
ISO/IEC 17021-1:2015 Clause 9.6.2 (Purpose of Surveillance Audits)
NEW QUESTION # 397
選擇最能完成下面句子的字詞來描述審計資源:
According to ISO 19011:2018, clause 5.3, the person responsible for managing the audit programme should determine the resources necessary for the audit programme, such as the audit team members, the budget, the time, the tools, etc. The audit resources should be sufficient and appropriate to ensure the quality and effectiveness of the audit programme and the audit results. The audit resources include the following elements12:
* Essential resources: These are the resources that are required to conduct the audit programme and the individual audits, such as the audit documents, the audit methods, the audit tools, the audit schedule, the audit budget, etc. The essential resources should be identified and allocated based on the audit objectives, scope, and criteria, and the availability and cooperation of the auditee. The essential resources should also be reviewed and updated as necessary to reflect any changes or deviations in the audit programme or the individual audits.
* Competent personnel: These are the audit team members who have the appropriate knowledge, skills, and experience to conduct the audit effectively and efficiently, and to provide credible and reliable audit results and recommendations. The competent personnel should include the audit team leader, the auditors, and any technical experts or observers who support the audit team. The competent personnel should be selected and appointed based on the audit objectives, scope, and criteria, and the specific competence requirements for the audit programme and the individual audits. The competent personnel should also be independent and impartial, and avoid any conflicts of interest or self-interest that may affect the audit results or the audit decisions.
ISO 19011:2018 - Guidelines for auditing management systems, clause 5.3 PECB Candidate Handbook ISO 27001 Lead Auditor, page 19
NEW QUESTION # 398
根據 ISO/IEC 27001,資訊安全管理系統旨在保護下列哪兩項?
- A. 資訊的機密性
- B. 資訊的一致性
- C. 資訊的可訪問性
- D. 資訊的完整性
- E. 資訊整合
- F. 訊息的真實性
ISO/IEC 27001 focuses on the core principles of the CIA triad:
* Confidentiality: Ensuring information is accessible only to authorized individuals.
* Integrity: Maintaining the accuracy and completeness of information, protecting it from unauthorized modification.
* Availability: Information should be accessible to authorized users when needed (this is also important, but not one of the choices in this specific question).
* ISO/IEC 27001:2022, Section 4.2 (Understanding the needs and expectations of interested parties): This section highlights the importance of determining relevant interested parties and their requirements related to information security, which includes addressing confidentiality, integrity, and availability.
NEW QUESTION # 399
下列哪一項是組織環境的定義?
- A. 對可能影響組織實現其目標的願望的內部和外部問題的控制
- B. 可能影響組織制定和實現其目標的方法的內部和外部問題的組合
- C. 協調可能對組織的成功產生正面或負面影響的內部和外部問題
- D. 可能影響組織制定和實現其目標的方法的內部和外部問題的複雜性
The context of the organisation is the business environment in which the organisation operates and defines its information security management system (ISMS). It includes the internal and external factors and conditions that can influence the organisation's information security objectives, strategies, and policies. The context of the organisation helps the organisation to identify the scope, boundaries, and requirements of the ISMS, as well as the interested parties and their expectations. The context of the organisation is determined by considering both internal and external issues, such as the organisational structure, culture, values, mission, vision, objectives, strategies, resources, capabilities, processes, activities, products, services, markets, customers, competitors, suppliers, partners, regulators, laws, regulations, standards, guidelines, best practices, risks, opportunities, threats, vulnerabilities, etc. Reference: ISO 27001:2022 Clause 4 Context of the organization, ISO 27001 Requirement 4.1 - Understanding the Context of the Organisation, ISO 27001 context of the organization - How to define it - Advisera
NEW QUESTION # 400
In today’s society, there are increasingly thousands of people put a priority to acquire certificates to enhance their abilities. With a total new perspective, ISO-IEC-27001-Lead-Auditor-CN study materials have been designed to serve most of the office workers who aim at getting an exam certification. Moreover, ISO-IEC-27001-Lead-Auditor-CN Exam Questions have been expanded capabilities through partnership with a network of reliable local companies in distribution, software and product referencing for a better development. That helping you pass the ISO-IEC-27001-Lead-Auditor-CN exam successfully has been given priority to our agenda.
ISO-IEC-27001-Lead-Auditor-CN Sample Exam: https://www.passexamdumps.com/ISO-IEC-27001-Lead-Auditor-CN-valid-exam-dumps.html
ISO-IEC-27001-Lead-Auditor-CN latest download demo is available for all of you, PECB Pass ISO-IEC-27001-Lead-Auditor-CN Guaranteed Furthermore, we will do our best to provide best products with reasonable price and frequent discounts, PECB Pass ISO-IEC-27001-Lead-Auditor-CN Guaranteed You do not spend twice exam cost which is very high, This ISO-IEC-27001-Lead-Auditor-CN exam simulation software can be readily installed on Windows-based computers and laptops, As long as you have make up your mind, our ISO-IEC-27001-Lead-Auditor-CN Sample Exam - PECB Certified ISO/IEC 27001 Lead Auditor exam (ISO-IEC-27001-Lead-Auditor中文版) study question is available in five minutes, so just begin your review now!
New discussion of managing complex change, On this platform, you will get the valid, updated, and PECB Certified ISO/IEC 27001 Lead Auditor exam (ISO-IEC-27001-Lead-Auditor中文版) exam expert-verified exam questions, ISO-IEC-27001-Lead-Auditor-CN latest download demo is available for all of you.
Free PDF PECB - ISO-IEC-27001-Lead-Auditor-CN - Efficient Pass PECB Certified ISO/IEC 27001 Lead Auditor exam (ISO-IEC-27001-Lead-Auditor中文版) GuaranteedFurthermore, we will do our best to provide ISO-IEC-27001-Lead-Auditor-CN best products with reasonable price and frequent discounts, You do not spend twice exam cost which is very high, This ISO-IEC-27001-Lead-Auditor-CN exam simulation software can be readily installed on Windows-based computers and laptops.
As long as you have make up your mind, our PECB Certified ISO/IEC 27001 Lead Auditor exam (ISO-IEC-27001-Lead-Auditor中文版) ISO-IEC-27001-Lead-Auditor-CN Sample Exam study question is available in five minutes, so just begin your review now!
- ISO-IEC-27001-Lead-Auditor-CN New Dumps Files 📢 Test ISO-IEC-27001-Lead-Auditor-CN Result 🌏 ISO-IEC-27001-Lead-Auditor-CN Discount Code 📚 Download 「 ISO-IEC-27001-Lead-Auditor-CN 」 for free by simply entering ☀ [url]www.prepawayexam.com ️☀️ website 🔩ISO-IEC-27001-Lead-Auditor-CN Questions Pdf[/url]
- ISO-IEC-27001-Lead-Auditor-CN Free Study Torrent - ISO-IEC-27001-Lead-Auditor-CN Pdf Vce - ISO-IEC-27001-Lead-Auditor-CN Updated Torrent 🦋 Copy URL [ [url]www.pdfvce.com ] open and search for “ ISO-IEC-27001-Lead-Auditor-CN ” to download for free 🤕ISO-IEC-27001-Lead-Auditor-CN Study Center[/url]
- Test ISO-IEC-27001-Lead-Auditor-CN Result 🐣 ISO-IEC-27001-Lead-Auditor-CN Test Dates ⌚ ISO-IEC-27001-Lead-Auditor-CN Valid Exam Discount 🛰 Easily obtain 《 ISO-IEC-27001-Lead-Auditor-CN 》 for free download through ➽ [url]www.testkingpass.com 🢪 📡ISO-IEC-27001-Lead-Auditor-CN Questions Pdf[/url]
- ISO-IEC-27001-Lead-Auditor-CN Valid Examcollection ⛳ ISO-IEC-27001-Lead-Auditor-CN Test Dates ⏹ Practice ISO-IEC-27001-Lead-Auditor-CN Online 🤴 Open website [ [url]www.pdfvce.com ] and search for ➽ ISO-IEC-27001-Lead-Auditor-CN 🢪 for free download 🚘Certification ISO-IEC-27001-Lead-Auditor-CN Exam Dumps[/url]
- ISO-IEC-27001-Lead-Auditor-CN Study Center 📭 Practice ISO-IEC-27001-Lead-Auditor-CN Online 📗 Free ISO-IEC-27001-Lead-Auditor-CN Braindumps 🥃 Simply search for ➤ ISO-IEC-27001-Lead-Auditor-CN ⮘ for free download on “ [url]www.validtorrent.com ” ❤Test ISO-IEC-27001-Lead-Auditor-CN Book[/url]
- ISO-IEC-27001-Lead-Auditor-CN Free Study Torrent - ISO-IEC-27001-Lead-Auditor-CN Pdf Vce - ISO-IEC-27001-Lead-Auditor-CN Updated Torrent 🧉 Search for ☀ ISO-IEC-27001-Lead-Auditor-CN ️☀️ and obtain a free download on 「 [url]www.pdfvce.com 」 🍋ISO-IEC-27001-Lead-Auditor-CN Valid Exam Discount[/url]
- Pass Guaranteed PECB - ISO-IEC-27001-Lead-Auditor-CN –The Best Pass Guaranteed ℹ ➠ [url]www.verifieddumps.com 🠰 is best website to obtain ➤ ISO-IEC-27001-Lead-Auditor-CN ⮘ for free download ✔ISO-IEC-27001-Lead-Auditor-CN Questions Pdf[/url]
- Free ISO-IEC-27001-Lead-Auditor-CN Braindumps 🥭 ISO-IEC-27001-Lead-Auditor-CN Valid Exam Discount 🦙 ISO-IEC-27001-Lead-Auditor-CN Study Center 👪 Easily obtain free download of ⏩ ISO-IEC-27001-Lead-Auditor-CN ⏪ by searching on ➥ [url]www.pdfvce.com 🡄 ⬆ISO-IEC-27001-Lead-Auditor-CN Study Center[/url]
- Dumps ISO-IEC-27001-Lead-Auditor-CN Guide 🥭 ISO-IEC-27001-Lead-Auditor-CN New Dumps Files 🎋 ISO-IEC-27001-Lead-Auditor-CN Study Center 🏕 The page for free download of [ ISO-IEC-27001-Lead-Auditor-CN ] on ➥ [url]www.verifieddumps.com 🡄 will open immediately 👄ISO-IEC-27001-Lead-Auditor-CN Training Materials[/url]
- ISO-IEC-27001-Lead-Auditor-CN Valid Exam Discount 🍇 ISO-IEC-27001-Lead-Auditor-CN Study Center 🔧 ISO-IEC-27001-Lead-Auditor-CN Valid Exam Discount 🦉 Open 【 [url]www.pdfvce.com 】 enter ▛ ISO-IEC-27001-Lead-Auditor-CN ▟ and obtain a free download 🥦ISO-IEC-27001-Lead-Auditor-CN New Dumps Files[/url]
- Where Can I Find Updated ISO-IEC-27001-Lead-Auditor-CN Exam Questions ? 💲 Download [ ISO-IEC-27001-Lead-Auditor-CN ] for free by simply entering ➽ [url]www.prep4sures.top 🢪 website 🥤Dumps ISO-IEC-27001-Lead-Auditor-CN Guide[/url]
- www.1pingg.cc, letusbookmark.com, bookmarkmoz.com, hamzaahod309451.blog-ezine.com, roxannogmu207900.bcbloggers.com, checkbookmarks.com, pr7bookmark.com, craigfjmo347559.59bloggers.com, jasonjtvv520788.anchor-blog.com, robertszkr205122.prublogger.com, Disposable vapes
BTW, DOWNLOAD part of PassExamDumps ISO-IEC-27001-Lead-Auditor-CN dumps from Cloud Storage: https://drive.google.com/open?id=1d9E_bR8Y4H03aGkSO0dbiVR5kgWqSXa3
