[General] Valid Braindumps NSE5_FNC_AD_7.6 Ebook - NSE5_FNC_AD_7.6 Reliable Exam Testking
26
【General】 Valid Braindumps NSE5_FNC_AD_7.6 Ebook - NSE5_FNC_AD_7.6 Reliable Exam Testking
Posted at 7 day before      View:57 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ITdumpsfree NSE5_FNC_AD_7.6 dumps for free: https://drive.google.com/open?id=1dGL_zTMOibaunXR1FUbQzUjHpjLGlGNJ
If you are still afraid of trying our NSE5_FNC_AD_7.6 exam quiz, you will never have a chance to grow. Opportunities are always for those who prepare themselves well. The only way to harvest wealth is challenging all the time. Our NSE5_FNC_AD_7.6 practice materials are waiting for you. Cheer up for yourself. There is nothing that you will lose for our demos of the NSE5_FNC_AD_7.6 study materials are totally free to download.
NSE5_FNC_AD_7.6 certification can demonstrate your mastery of certain areas of knowledge, which is internationally recognized and accepted by the general public as a certification. NSE5_FNC_AD_7.6 certification is so high that it is not easy to obtain it. It requires you to invest time and energy. If you are not sure whether you can strictly request yourself, our NSE5_FNC_AD_7.6 Exam Training can help you. Help is to arrange time for you and provide you with perfect service. If you use our learning materials to achieve your goals, we will be honored. NSE5_FNC_AD_7.6 exam prep look forward to meeting you.
NSE5_FNC_AD_7.6 Reliable Exam Testking | Free NSE5_FNC_AD_7.6 Exam QuestionsObtaining an IT certification shows you are an ambitious individual who is always looking to improve your skill set. Most companies think highly of this character. Our NSE5_FNC_AD_7.6 exam original questions will help you clear exam certainly in a short time. You don't need to worry about how difficulty the exams are. ITdumpsfree release the best high-quality NSE5_FNC_AD_7.6 Exam original questions to help you most candidates pass exams and achieve their goal surely.
Fortinet NSE 5 - FortiNAC-F 7.6 Administrator Sample Questions (Q12-Q17):NEW QUESTION # 12
A healthcare organization is integrating FortiNAC-F with its existing MDM. Communication is failing between the systems.
What could be a probable cause?
  • A. REST API communication is failing
  • B. SOAP API communication is failing
  • C. Security Fabric traffic is failing
  • D. SSH communication is failing
The integration between FortiNAC-F and Mobile Device Management (MDM) platforms (such as Microsoft Intune, VMware Workspace ONE, or Jamf) is a critical component for providing visibility into mobile assets that do not connect directly to the managed infrastructure via standard wired or wireless protocols.
According to the FortiNAC-F MDM Integration Guide, the communication between the FortiNAC-F appliance and the MDM server is handled through REST API calls. FortiNAC-F acts as an API client, periodically polling the MDM server to retrieve device metadata, compliance status, and ownership information. If communication is failing, it is most likely because the API credentials (Client ID/Secret) are incorrect, the MDM's API endpoint is unreachable from the FortiNAC-F service port, or the SSL certificate presented by the MDM is not trusted by the FortiNAC-F root store.
While SSH (B) is used for switch CLI management and the Security Fabric (A) uses proprietary protocols for FortiGate synchronization, neither is the primary vehicle for MDM data exchange. SOAP API (D) is an older protocol that has been largely replaced by REST in modern FortiNAC integrations.
"FortiNAC integrates with MDM systems by utilizing REST API communication to query the MDM database for device information. To establish this link, administrators must configure the MDM Service Connector with the appropriate API URL and authentication credentials. If the 'Test Connection' fails, verify that the FortiNAC can reach the MDM provider via the REST API port (usually HTTPS 443)." - FortiNAC-F Administration Guide: MDM Integration and Troubleshooting.
NEW QUESTION # 13
During an evaluation of state-based enforcement, an administrator discovers that ports that should not be under enforcement have been added to enforcement groups.
In which view would the administrator be able to identify who added the ports to the groups?
(Selected)
  • A. The Security Events view
  • B. The Port Changes view
  • C. The Event Management view
  • D. The Admin Auditing view
In FortiNAC-F, accountability and forensic tracking of configuration changes are managed through the Admin Auditing functionality. When an administrator performs an action that modifies the system state-such as creating a policy, changing a device's status, or adding a switch port to an Enforcement Group-the system generates an audit record. This record is essential for troubleshooting scenarios where unauthorized or accidental configuration changes have occurred, leading to unintended network behavior.
The Admin Auditing view (found under Logs > Admin Auditing) provides a comprehensive log of the "Who, What, and When" for every administrative session. Each entry includes the username of the administrator, the source IP address from which they accessed the FortiNAC-F console, a precise timestamp, and a detailed description of the modification. In the scenario described, where ports have been incorrectly added to enforcement groups, the Admin Auditing view allows a supervisor to filter by the specific "Port" or "Group" object to identify exactly which administrator executed the command.
In contrast, the Event Management view (B) is designed to monitor system and network events, such as RADIUS authentications, host connections, and SNMP trap arrivals. While it tracks system activity, it does not typically log the manual configuration changes performed by admins. The Port Changes view (C) tracks the operational history of a port (such as VLAN assignment changes and host movements) but does not attribute the administrative assignment of the port to a group. Finally, the Security Events view (D) is dedicated to alerts triggered by security rules and external threat feeds.
"Admin Auditing displays a record of all modifications made to the FortiNAC-F system by an administrator. This view includes the administrator's name, the date and time of the change, and a description of the action taken. It is the primary resource for determining which administrative user performed a specific configuration change, such as modifying port group memberships or altering policy settings." - FortiNAC-F Administration Guide: Logging and Auditing Section.
NEW QUESTION # 14
Which two requirements must be met to set up an N+1 HA cluster? (Choose two.)
  • A. At least two FortiNAC-F devices designated as primary
  • B. A dedicated VLAN for primary and secondary synchronization
  • C. A FortiNAC-F device designated as a secondary
  • D. A FortiNAC-F manager
The N+1 High Availability (HA) architecture was introduced in FortiNAC-F version 7.6 to provide a more scalable and flexible redundancy model compared to the traditional 1+1 active/passive setup. In an N+1 configuration, a single secondary (standby) appliance can provide coverage for multiple primary (active) Control and Application (CA) appliances.
To set up an N+1 HA cluster, there are two fundamental structural requirements:
A FortiNAC-F Manager (FortiNAC-M): Unlike standard 1+1 HA, which can be configured directly between two CAs, N+1 management is centralized. The FortiNAC-M acts as the orchestrator that manages the failover groups, monitors the health of the primaries, and coordinates the promotion of the secondary server if a primary fails.
A FortiNAC-F device designated as a Secondary: The cluster must have one appliance explicitly configured with the Secondary failover role. This device remains in a standby state, receiving database replications from all N primaries in its group until it is called upon to take over the functions of a failed unit.
While a cluster can support multiple primaries (D), it does not strictly require "at least two" to function as an N+1 group; it simply requires N primaries (where N ≥ 1). Additionally, N+1 is typically a Layer 3 managed solution via the Manager, meaning it does not mandate a "dedicated VLAN" for synchronization like some Layer 2 HA deployments.
"In FortiNAC-F 7.6, FortiNAC-M functions as a manager to manage the N+1 Failover Groups... enabling N+M high availability for CAs. To create an N+1 Failover group, you should add the secondary CA to the FortiNAC-M first, then add the primary CAs. The secondary CA is designed to take over the functionality of any single failed primary component." - FortiNAC-F 7.6.0 N+1 Failover Reference Manual.
NEW QUESTION # 15
A network administrator is troubleshooting a network access issue for a specific host. The administrator suspects the host is being assigned a different network access policy than expected.
Where would the administrator look to identify which network access policy, if any, is being applied to a particular host?
  • A. The Policy Details view for the host
  • B. The Connections view
  • C. The Policy Logs view
  • D. The Port Properties view of the hosts port
When troubleshooting network access in FortiNAC-F, it is often necessary to verify exactly why a host has been granted a specific level of access. Since FortiNAC-F evaluates policies from the top down and assigns access based on the first match, an administrator needs a clear way to see the results of this evaluation for a specific live endpoint.
The Policy Details (C) view is the designated tool for this purpose. By navigating to the Hosts > Hosts (or Adapter View) in the Administration UI, an administrator can search for the specific MAC address or IP of the host in question. Right-clicking on the host record reveals a context menu from which Policy Details can be selected. This view provides a real-time "look" into the policy engine's decision for that specific host, showing the Network Access Policy that was matched, the User/Host Profile that triggered the match, and the resulting Network Access Configuration (VLAN/ACL) currently applied.
While Policy Logs (A) provide a historical record of all policy transitions across the system, they are often too high-volume to efficiently find a single host's current state. The Connections view (B) shows the physical port and basic status but lacks the granular policy logic breakdown. The Port Properties (D) view shows the configuration of the switch interface itself, which is only one component of the final access determination.
"To identify which policy is currently applied to a specific endpoint, use the Policy Details view. Navigate to Hosts > Hosts, select the host, right-click and choose Policy Details. This window displays the specific Network Access Policy, User/Host Profile, and Network Access Configuration currently in effect for that host record." - FortiNAC-F Administration Guide: Policy Details and Troubleshooting.
NEW QUESTION # 16
Refer to the exhibits.
Based on the given configurations and settings, on which date and time would a guest account created at 8:00 AM on 2025/09/12 expire?
  • A. 2025/09/12 at 8:00 PM
  • B. 2025/09/12 at 17:00:00
  • C. 2025/09/13 at 17:00:00
  • D. 2025/09/12 at 7:00 PM
Questio ns no: 22
Verified Answe r: D
Comprehensive and Detailed 250 to 300 words each Explanation with Exact Matched Extract from FortiNAC-F Administrator library and documentation for current versions (including F 7.2, 7.4, and 7.6) documents:
In FortiNAC-F, the expiration of a guest or contractor account is determined by the configuration settings within the Account Creation Wizard and the associated Guest/Contractor Template. While a template can define a default "Account Duration" (as seen in the 12-hour setting in the second exhibit), the Account Creation Wizard allows an administrator to manually specify or override the start and end parameters for a specific user session.
According to the FortiNAC-F Administration Guide regarding guest management, the Account End Date field in the creation wizard is the definitive timestamp for when the account object will be disabled or deleted from the system. In the provided exhibit (Account Creation Wizard), the administrator has explicitly set the Account Start Date to 2025/09/12 08:00:00 and the Account End Date to 2025/09/13 17:00:00.
Even though the template indicates an "Account Duration" of 12 hours, this value typically serves as a pre-populated default. When a manual date and time are entered into the wizard, those specific values take precedence for that individual account. The account will remain active and valid until 5:00 PM (17:00:00) on the following day, 2025/09/13. It is also important to note the "Login Availability" from the template (8:00 AM - 7:00 PM); while the account exists until the 13th at 17:00:00, the user would only be able to authenticate during the active hours defined by the login schedule on both days.
"When creating an account, the administrator can select a template to provide default settings. However, specific values such as the Account End Date can be modified within the Account Creation Wizard. The date and time specified in the 'Account End Date' field determines the absolute expiration of the account. Once this time is reached, the account is moved to an expired state and the user's network access is revoked." - FortiNAC-F Administration Guide: Guest and Contractor Account Management.
NEW QUESTION # 17
Questions remain unsuccessful in the NSE5_FNC_AD_7.6 test and lose their resources. That's why ITdumpsfree is offering real Fortinet NSE5_FNC_AD_7.6 Questions that are real and can save you from wasting time and money. Hundreds of applicants have studied successfully from our NSE5_FNC_AD_7.6 latest questions in one go. We have launched our NSE5_FNC_AD_7.6 Practice Test after consulting with experts who have years of experience in this field. People who have used our NSE5_FNC_AD_7.6 exam preparation material rated it as the best option to study for the NSE5_FNC_AD_7.6 exam in a short time.
NSE5_FNC_AD_7.6 Reliable Exam Testking: https://www.itdumpsfree.com/NSE5_FNC_AD_7.6-exam-passed.html
Every worker knows that NSE5_FNC_AD_7.6 is a dominant figure in international Internet and information technology field, In addition, NSE5_FNC_AD_7.6 exam materials are high quality, and we can ensure you that you can pass the exam just one time, You can take the online Fortinet NSE5_FNC_AD_7.6 practice exam multiple times, So this is a definitive choice, it means our NSE5_FNC_AD_7.6 practice quiz will help you reap the fruit of success.
While the success of the getting the Fortinet NSE5_FNC_AD_7.6 certification cannot be realized without repeated training and valid Fortinet study material, Edit and protect your favorite photos and videos.
TOP Valid Braindumps NSE5_FNC_AD_7.6 Ebook - High Pass-Rate Fortinet NSE5_FNC_AD_7.6 Reliable Exam Testking: Fortinet NSE 5 - FortiNAC-F 7.6 AdministratorEvery worker knows that NSE5_FNC_AD_7.6 is a dominant figure in international Internet and information technology field, In addition, NSE5_FNC_AD_7.6 exam materials are high quality, and we can ensure you that you can pass the exam just one time.
Wherever, it is necessary, the answers have NSE5_FNC_AD_7.6 been explained further with the help of simulations, graphs and extra notes.
DOWNLOAD the newest ITdumpsfree NSE5_FNC_AD_7.6 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1dGL_zTMOibaunXR1FUbQzUjHpjLGlGNJ
