JN0-364 Latest Exam Price & JN0-364 Test Engine
Posted at 5/18/2026 12:26:56
View68
Replies0
P.S. Free 2026 Juniper JN0-364 dumps are available on Google Drive shared by itPass4sure: https://drive.google.com/open?id=1JRnxPnAkkXUHh70gcyQvLmI4lyfTwq0s
Along with Service Provider Routing and Switching, Specialist (JNCIS-SP) (JN0-364) self-evaluation exams, JN0-364 dumps PDF is also available at itPass4sure. These JN0-364 questions can be used for quick Service Provider Routing and Switching, Specialist (JNCIS-SP) (JN0-364) preparation. Our JN0-364 dumps PDF format works on a range of Smart devices, such as laptops, tablets, and smartphones. Since JN0-364 Questions Pdf are easily accessible, you can easily prepare for the test without time and place constraints. You can also print this format of itPass4sure's Service Provider Routing and Switching, Specialist (JNCIS-SP) (JN0-364) exam dumps to prepare off-screen and on the go.
Our company concentrates on relieving your pressure of preparing the JN0-364 exam. Getting the certificate equals to embrace a promising future and good career development. Perhaps you have heard about our JN0-364 exam question from your friends or news. Why not has a brave attempt? You will certainly benefit from your wise choice. Now our JN0-364 practice materials have won customers' strong support. Our sales volume is increasing every year. The great achievements benefit from our enormous input. First of all, we have done good job on researching the new version of the JN0-364 exam question.
JN0-364 Test Sample Questions & JN0-364 Vce Pdf Training & JN0-364 Valid Test SimulatorAs we all know, the world does not have two identical leaves. Peoples tastes also vary a lot. So we have tried our best to develop the three packages for you to choose. Now we have free demo of the JN0-364 study materials, which can print on papers and make notes. Then windows software of the JN0-364 Exam Questions, which needs to install on windows software. Aiso online engine of the JN0-364 study materials, which is convenient because it doesnt need to install on computers.
Juniper Service Provider Routing and Switching, Specialist (JNCIS-SP) Sample Questions (Q53-Q58):NEW QUESTION # 53
You are configuring BGP on a Juniper router to peer with an external provider. After committing the configuration, the BGP session remains in the Idle state.
Which configuration issue would prevent the BGP session from progressing beyond the Idle state?
- A. The BGP group type is set to internal instead of external.
- B. The peer is configured with a different router ID.
- C. The peer IP address is unreachable
- D. The local AS number is higher than the peer's AS number.
The Idle state means the router has not successfully initiated a TCP connection to the BGP peer.
If the peer IP address is unreachable, the router cannot establish the required TCP session on port 179, so the BGP process remains in the Idle state and does not progress to the Connect or Active states.
NEW QUESTION # 54
What are two types of BGP messages exchanged while in the Established state? (Choose two.)
- A. open
- B. notification
- C. update
- D. request
Update messages are exchanged between BGP peers in the Established state to advertise new routes, withdraw previously advertised routes, and share path attributes for reachable prefixes.
Notification messages are used to signal errors detected in the BGP session and immediately terminate the session when a protocol error occurs.
NEW QUESTION # 55
A service provider is onboarding a new enterprise customer that operates multiple branch offices, each with its own set of VLANs. The customer requires transparent Layer 2 connectivity between sites while maintaining separation of internal VLANs. The provider must also ensure that customer VLAN identifiers do not conflict with other customers on the shared infrastructure.
Which solution would provide the desired results?
- A. Aggregate customer traffic using GRE tunnels.
- B. Provide Internet access with NAT and firewall services.
- C. Extend customer VLANs using Q-in-Q tunneling.
- D. Deliver Layer 3 VPN services using MPLS.
Q-in-Q tunneling (802.1ad) allows a service provider to encapsulate customer VLAN tags inside an additional provider VLAN tag. This enables transparent Layer 2 connectivity between customer sites while preserving the customer's internal VLAN structure. The outer service- provider VLAN tag ensures separation between different customers and prevents VLAN ID conflicts on the shared provider infrastructure.
NEW QUESTION # 56
What information is determined by using the AS path attribute included in the BGP update message? (Choose two.)
- A. the shortest AS path to reach a prefix
- B. the origin of a route from IGP or EGP
- C. the presence of a routing loop
- D. the total number of next-hop devices to reach a prefix
TheAS_PATHattribute is a "well-known mandatory" attribute in BGP, meaning it must be present in every BGP Update message exchanged between External BGP (eBGP) peers. It records the sequence of Autonomous System numbers that a route has traversed. Per Juniper Networks Service Provider documentation, this attribute serves two fundamental purposes:
1. Loop Prevention (Option B):
This is the most critical function of the AS_PATH. When a BGP router receives an update from an eBGP peer, it scans the AS_PATH attribute for its own AS number. If the router finds its local AS number already listed in the path, it concludes that the route has already passed through its network and has "looped" back. To prevent an infinite routing loop, the router will immediately discard the update. This mechanism is the cornerstone of BGP's stability as a path-vector protocol.
2. Path Selection / Shortest Path Determination (Option C):
BGP uses a complex "tie-breaking" algorithm to select the best path among multiple candidates. One of the highest-ranking criteria in this algorithm (after Weight, Local Preference, and AS_PATH length) is the length of the AS_PATH. A shorter AS_PATH (fewer AS numbers listed) is generally preferred over a longer one, as it typically represents a more direct path through the internet hierarchy.
* Option A:The "origin" of a route (IGP, EGP, or Incomplete) is determined by theORIGINattribute, which is a separate well-known mandatory attribute.
* Option D:BGP does not count individual "next-hop devices" (which would be an IGP metric like hop count in RIP); it only tracks Autonomous Systems. A single AS in the path might contain hundreds of internal routers (next-hops), but BGP only sees it as one "hop" in the AS_PATH.
NEW QUESTION # 57
You are asked to configure a new network environment that will be based on IPv6 and use OSPF. In this scenario, which two statements correctly identify configuration task considerations? (Choose two.)
- A. The router ID used must be based on a 128-bit identifier value.
- B. Participating interfaces are only required to be configured with the IPv6 protocol family and address.
- C. The router ID used must be based on a 32-bit identifier value.
- D. Participating interfaces must be configured with both IPv4 and IPv6 protocol families and addresses.
When transitioning to an IPv6 environment usingOSPFv3(the version of OSPF designed for IPv6), there are significant architectural differences compared to OSPFv2 (IPv4). According to Juniper Networks technical documentation, OSPFv3 was redesigned to be more protocol-agnostic.
Router ID (Option C):
Despite OSPFv3 routing IPv6 (which uses 128-bit addresses), the OSPFRouter IDremains a32-bit value formatted like an IPv4 address (e.g., 1.1.1.1). This is a common point of confusion. In a pure IPv6 environment where no IPv4 addresses are configured on any interfaces, a Juniper router cannot automatically derive a Router ID. Therefore, the administrator must manually configure a 32-bit Router ID under [edit routing-options] for the OSPFv3 process to initialize.
Interface Configuration (Option D):
OSPFv3 runs directly over the IPv6 link-local scope. Unlike OSPFv2, it does not require an IPv4 address to function. Therefore, interfaces areonly required to be configured with family inet6(Option D). You do not need "dual-stack" (both IPv4 and IPv6) functionality just to run OSPFv3. The protocol uses the link-local address (fe80::/10) of the interface for neighbor adjacencies and as the next hop for routing updates. This separation allows OSPFv3 to carry multiple "address families" (both IPv4 and IPv6 unicast) if needed, but the base requirement for an IPv6-only network is simply the family inet6 configuration.
NEW QUESTION # 58
The second format of Juniper JN0-364 exam preparation material is the web-based Service Provider Routing and Switching, Specialist (JNCIS-SP) (JN0-364) practice test. It is useful for the ones who prefer to study online. itPass4sure have made this format so that users don't face the hassles of installing software while preparing for the Service Provider Routing and Switching, Specialist (JNCIS-SP) (JN0-364) certification. The customizable feature of this format allows you to adjust the settings of Service Provider Routing and Switching, Specialist (JNCIS-SP) (JN0-364) practice exams.
JN0-364 Test Engine: https://www.itpass4sure.com/JN0-364-practice-exam.html
The other thing is to prepare for the JN0-364 Test Engine - Service Provider Routing and Switching, Specialist (JNCIS-SP) exam by evaluating your preparation using authentic exam questions, Also, this content material can boost your confidence by providing you with enough knowledge that you need to get before the itPass4sure JN0-364 exam dumps, Juniper JN0-364 Latest Exam Price ACTUAL EXAM QUESTIONS, The JN0-364 web-based practice questions carry the above-mentioned notable features of the desktop-based software.
Where a single switch can be divided into JN0-364 two or more virtual switches, For this reason, this chapter focuses mostly on queuing delay, The other thing is to prepare for Valid Dumps JN0-364 Book the Service Provider Routing and Switching, Specialist (JNCIS-SP) exam by evaluating your preparation using authentic exam questions.
Pass Guaranteed Juniper - Perfect JN0-364 Latest Exam PriceAlso, this content material can boost your confidence by providing you with enough knowledge that you need to get before the itPass4sure JN0-364 Exam Dumps, ACTUAL EXAM QUESTIONS.
The JN0-364 web-based practice questions carry the above-mentioned notable features of the desktop-based software, If you prefer to read paper materials rather than learning on computers, the PDF version of our JN0-364 guide torrent must the best choice for you.
- Exam JN0-364 Preview 🤒 JN0-364 Exam Exercise 🥩 Download JN0-364 Pdf ☑ [ [url]www.prep4sures.top ] is best website to obtain ⏩ JN0-364 ⏪ for free download 😜JN0-364 New Study Materials[/url]
- Free PDF 2026 Juniper JN0-364: First-grade Service Provider Routing and Switching, Specialist (JNCIS-SP) Latest Exam Price 🚝 Immediately open [url]www.pdfvce.com and search for { JN0-364 } to obtain a free download 🥟Relevant JN0-364 Answers[/url]
- Pass Guaranteed Quiz Fantastic JN0-364 - Service Provider Routing and Switching, Specialist (JNCIS-SP) Latest Exam Price 🍒 The page for free download of ➡ JN0-364 ️⬅️ on [url]www.dumpsquestion.com will open immediately ⌛JN0-364 Certification Torrent[/url]
- JN0-364 Valid Braindumps Files 🎑 JN0-364 Reliable Test Labs 🔏 Original JN0-364 Questions 📑 Go to website ➥ [url]www.pdfvce.com 🡄 open and search for [ JN0-364 ] to download for free 🔙Minimum JN0-364 Pass Score[/url]
- VCE JN0-364 Dumps ⛰ JN0-364 Reliable Test Labs 🍇 100% JN0-364 Exam Coverage 🤙 Search for JN0-364 and download it for free on [url]www.prep4away.com website 👞Exam JN0-364 Preview[/url]
- Original JN0-364 Questions ✔ New JN0-364 Test Registration ☕ JN0-364 Reliable Test Labs 🎆 Search for ☀ JN0-364 ️☀️ on ⏩ [url]www.pdfvce.com ⏪ immediately to obtain a free download 🏺JN0-364 Exam Exercise[/url]
- Latest JN0-364 Material ☯ JN0-364 Pdf Braindumps 🩱 Exam JN0-364 Preview 🧱 Download ☀ JN0-364 ️☀️ for free by simply entering ⏩ [url]www.testkingpass.com ⏪ website ☘Valid JN0-364 Exam Labs[/url]
- Pass Guaranteed Juniper - JN0-364 CTrustable Latest Exam Price 👫 Copy URL ☀ [url]www.pdfvce.com ️☀️ open and search for JN0-364 to download for free 🕚JN0-364 Pdf Braindumps[/url]
- Quiz 2026 JN0-364: Useful Service Provider Routing and Switching, Specialist (JNCIS-SP) Latest Exam Price 🕺 Easily obtain free download of JN0-364 by searching on ➥ [url]www.testkingpass.com 🡄 🐞Valid JN0-364 Exam Labs[/url]
- Free PDF 2026 Juniper JN0-364: First-grade Service Provider Routing and Switching, Specialist (JNCIS-SP) Latest Exam Price 🧍 Download ➥ JN0-364 🡄 for free by simply entering [url]www.pdfvce.com website 👱Valid JN0-364 Exam Labs[/url]
- JN0-364 New Study Materials 🪂 Original JN0-364 Questions 🍒 JN0-364 Valid Braindumps Files 🤕 Simply search for ▷ JN0-364 ◁ for free download on ⮆ [url]www.vce4dumps.com ⮄ 🧟Original JN0-364 Questions[/url]
- teganghqw420845.izrablog.com, www.ted.com, opensocialfactory.com, kuhenan.com, susanjpir240157.muzwiki.com, delilahrzdg005647.bcbloggers.com, keziamaus657608.mdkblog.com, college.gkctinfo.in, one-bookmark.com, blanchebtfk532331.blognody.com, Disposable vapes
DOWNLOAD the newest itPass4sure JN0-364 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1JRnxPnAkkXUHh70gcyQvLmI4lyfTwq0s
