[General] Valid H19-341_V1.0 Test Dumps - Exam H19-341_V1.0 Topic
26
【General】 Valid H19-341_V1.0 Test Dumps - Exam H19-341_V1.0 Topic
Posted at 5 day before      View:62 | Replies:0        Print      Only Author   [Copy Link] 1#
The exam will be vanquished smoothly this time by the help of valid latest H19-341_V1.0 exam torrent. Written by meticulous and professional experts in this area, their quality has reached to the highest level compared with others’ similar H19-341_V1.0 test prep and concord with the syllabus of the exam perfectly. Their questions points provide you with simulation environment to practice. In that case, when you sit in the Real H19-341_V1.0 Exam room, you can deal with almost every question with ease.
I know that the purpose of your test is definitely passing the H19-341_V1.0 exam. So, buying our H19-341_V1.0 guide quiz is definitely your best choice. Users who used H19-341_V1.0 exam questions basically passed the exam. I believe that after you use our H19-341_V1.0 Study Materials for a while, we will understand why we have a 99% pass rate. With the best quality and the latest version which we are always trying our best to develop, our H19-341_V1.0 practice engine can help you pass the exam for sure.
Exam H19-341_V1.0 Topic, H19-341_V1.0 Cheap DumpsIf you feel difficult in choosing which version of our H19-341_V1.0 reliable exam guide, if you want to be simple, PDF version may be suitable for you. PDF version is a normal file. Many candidates are used to printing out and then writing & reading of H19-341_V1.0 reliable exam guide on paper. Yes, it is silent and clear. Also if you have some unclearly questions, you can ask or talk with others easily. Others may just think that it is normally practice material. Also you can print out many copies of Huawei H19-341_V1.0 Reliable Exam Guide and share with others.
Huawei H19-341_V1.0 Exam Syllabus Topics:
  • HUAWEI Smart Office Solution Introduction: Covers Huawei's integrated smart office solution designed to enhance workplace collaboration and efficiency.
  • Typical Networking of Huawei Video Conferencing Solution: Covers the standard network architectures and topologies used to deploy Huawei video conferencing solutions.
  • Huawei Video Conferencing Platform Product Training (SMC, SC, MCU, RSE): Covers the core platform components including the SMC, SC, MCU, and RSE that enable video conferencing management and connectivity.
  • HUAWEI IdeaHub Product Technology Training: Covers the technology, features, and use cases of the HUAWEI IdeaHub all-in-one collaboration board.
Topic 5
  • HUAWEI Digital Classroom Solution Introduction: Covers Huawei's solution for enabling technology-driven smart digital classroom environments.
Huawei HCSA-Field-Intelligent Collaboration V1.0 Sample Questions (Q54-Q59):NEW QUESTION # 54
Which multimedia communication protocols does the Huawei Bar 310 support? (Select all that apply)
  • A. BFCP
  • B. H.323
  • C. H.239
  • D. SIP
Answer: A,B,C,D
The Huawei CloudLink Bar 310 is an industry-standard terminal designed for maximum interoperability. It supports the two primary signaling protocols: H.323 (B) and SIP (D) .
To facilitate content sharing (dual-stream) during a call, it supports the corresponding data protocols for each signaling type:
* H.239 (A): The standard for dual-streaming within H.323 calls.
* BFCP (C): The Binary Floor Control Protocol used for dual-streaming within SIP calls.
This ensures the Bar 310 can share presentations and video simultaneously regardless of the infrastructure it is connected to.
NEW QUESTION # 55
Which statements are correct about Huawei SMC resource pool management? (Select all that apply)
  • A. Smooth switchover without interruption of calls when an MCU is faulty.
  • B. The system automatically schedules resources to the best-performing MCU and CloudRSE based on resource usage.
  • C. MCU resources can be dynamically released, and scheduled conferences do not occupy resources.
  • D. Inter-region interaction and automatic MCU cascading.
Answer: A,B,C,D
Huawei SMC3.0 introduced advanced Resource Pool Management features:
* Option A: The SMC monitors the load and performance of all MCUs/RSEs in a pool, automatically routing new calls to the node with the most available capacity (Load Balancing).
* Option B: If a physical MCU fails, the SMC can migrate participants to another active MCU in the pool to ensure high availability and meeting continuity.
* Option C: Resources (like media ports) are allocated only when a conference actually starts. Simply
"scheduling" a meeting doesn't consume live hardware ports, allowing for higher efficiency.
* Option D: The system supports multi-level, hierarchical networking where MCUs in different geographic regions can be cascaded automatically to optimize bandwidth and provide local access.
NEW QUESTION # 56
Huawei SMC provides different roles (common user, conference administrator, and system administrator) with functions such as conference control and visualized O & M, etc.
  • A. TRUE
  • B. FALSE
The Huawei Service Management Center (SMC) is designed with a role-based access control (RBAC) model to ensure secure and efficient management.
* System Administrator: Responsible for global configurations, NE (Network Element) management, and system-wide maintenance.
* Conference Administrator: Focuses on scheduling, managing, and controlling conferences, as well as managing organizational resources.
* Common User: Typically has access to personal conference scheduling and joining functions.
The SMC also provides a "Visualized O & M" dashboard that allows administrators to monitor the health of the entire CloudVC network, including MCU status and participant line quality, in real-time.
NEW QUESTION # 57
Huawei IdeaHub S2 passed global authoritative security certification, what security measures are included?
(Select All that can apply)
  • A. Separate storage of sensitive data
  • B. Refined permission granularity
  • C. Randomized distribution of kernel address space
  • D. Traceable access records
  • E. Controllable interface permissions
Answer: A,B,C,D,E
The IdeaHub S2 is the first large-screen collaboration device to achieve CC EAL5+ high-level security certification. Its multi-layered defense includes:
* Interface Control (A & D): Administrators can disable physical ports (USB, etc.) and set granular permissions for apps.
* Data Security (B): Sensitive data and keys are stored in a TEE (Trusted Execution Environment) , isolated from the standard OS.
* O & M Security (C): Every login and system change is logged for auditing and traceability.
* Kernel Security (E): It uses ASLR (Address Space Layout Randomization) to prevent memory- based cyberattacks by making the location of system processes unpredictable.
NEW QUESTION # 58
Huawei SMC can manage the conference system and resources in a centralized manner.
  • A. TRUE
  • B. FALSE
The Huawei Service Management Center (SMC) is the centralized management hub for the entire video conferencing solution. It is responsible for the unified management of all Network Elements (NEs), including MCUs, SwitchCenters (SC), and Recording & Streaming Engines (RSE). Its core functions include user and endpoint management, conference scheduling, resource allocation (resource pooling), and visualized O & M (Operations and Maintenance). By centralizing these tasks, the SMC ensures that large-scale enterprise networks can be controlled from a single interface.
NEW QUESTION # 59
One of the great features of our H19-341_V1.0 training material is our H19-341_V1.0 pdf questions. H19-341_V1.0 exam questions allow you to prepare for the real H19-341_V1.0 exam and will help you with the self-assessment. You can easily pass the Huawei H19-341_V1.0 exam by using H19-341_V1.0 dumps pdf. Moreover, you will get all the updated H19-341_V1.0 Questions with verified answers. If you want to prepare yourself for the real HCSA-Field-Intelligent Collaboration V1.0 exam, then it is one of the most important ways to improve your H19-341_V1.0 preparation level. We provide 100% money back guarantee on all H19-341_V1.0 braindumps products.
Exam H19-341_V1.0 Topic: https://www.testpassking.com/H19-341_V1.0-exam-testking-pass.html
