[General] 100% Pass Quiz Marvelous AZ-204 New Developing Solutions for Microsoft Azure Exa
26
【General】 100% Pass Quiz Marvelous AZ-204 New Developing Solutions for Microsoft Azure Exa
Posted at yesterday 09:13      View:24 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PracticeVCE AZ-204 dumps from Cloud Storage: https://drive.google.com/open?id=1QCriahCOxV5HBMwqaJ3EpfRklm7ICrfM
In order to allow our customers to better understand our AZ-204 quiz prep, we will provide clues for customers to download in order to understand our AZ-204 exam torrent in advance and see if our products are suitable for you. We have free demo on the web for you to download. Our AZ-204 Exam Guide deliver the most important information in a simple, easy-to-understand language that you can learn efficiently learn with high quality. Whether you are a student or an in-service person, our AZ-204 exam torrent can adapt to your needs.
Target Audience and PrerequisitesThis certification test is intended for those specialists who are responsible for designing and building Cloud-based software solutions utilizing the Microsoft Azure platform. The candidates for this exam should have at least one to two years of experience with Microsoft Azure. They should also have the ability to accomplish programming tasks in a language that is supported by Azure. In addition, the applicants must be proficient in Azure PowerShell, Azure SDKs, app authentication and authorization, Azure CLI, APIs, monitoring, debugging, performance tuning, data connections, and data storage options.
In general, there are no special requirements that Microsoft lists for its AZ-204 exam. But it is recommended that the students taking this test have the subject matter expertise in building, evaluating, designing, and maintaining Cloud applications and services particularly on Microsoft responsibilities for an Azure Developer.
The Developing Solutions for Microsoft Azure certification exam consists of various types of questions, including multiple-choice, case studies, and drag and drop questions. AZ-204 Exam is 180 minutes long, and the candidate needs to score a minimum of 700 out of 1000 to pass the exam. AZ-204 exam is conducted online, and the candidate needs to schedule the exam through the Microsoft website. Developing Solutions for Microsoft Azure certification is valid for two years, and the candidate needs to take a recertification exam to maintain the certification. Overall, the Microsoft AZ-204 certification exam is an excellent opportunity for professionals who are looking to enhance their career in developing solutions for Microsoft Azure.
Reliable AZ-204 Exam Camp, AZ-204 Reliable Study GuideThe AZ-204 test material is reasonable arrangement each time the user study time, as far as possible let users avoid using our latest AZ-204 exam torrent for a long period of time, it can better let the user attention relatively concentrated time efficient learning. The AZ-204 practice materials in every time users need to master the knowledge, as long as the user can complete the learning task in this period, the AZ-204 test material will automatically quit learning system, to alert users to take a break, get ready for the next period of study.
Microsoft Developing Solutions for Microsoft Azure Sample Questions (Q216-Q221):NEW QUESTION # 216
You need to add code at line PC26 of Processing.cs to ensure that security policies are met.
How should you complete the code that you will add at line PC26? To answer, select the appropriate options in the answer area.
https://github.com/Azure/azure-s ... Rotation/Program.cs
NEW QUESTION # 217
A company is developing a solution that allows smart refrigerators to send temperature information to a central location. You have an existing Service Bus.
The solution must receive and store messages until they can be processed. You create an Azure Service Bus instance by providing a name, pricing tier, subscription, resource group, and location.
You need to complete the configuration.
Which Azure CLI or PowerShell command should you run?
  • A. Option D
  • B. Option B
  • C. Option A
  • D. Option C
A service bus instance has already been created (Step 2 below). Next is step 3, Create a Service Bus queue.
Note:
Steps:
Step 1: # Create a resource group
resourceGroupName="myResourceGroup"
az group create --name $resourceGroupName --location eastus
Step 2: # Create a Service Bus messaging namespace with a unique name
namespaceName=myNameSpace$RANDOM
az servicebus namespace create --resource-group $resourceGroupName --name $namespaceName --location eastus Step 3: # Create a Service Bus queue az servicebus queue create --resource-group $resourceGroupName --namespace-name $namespaceName --name BasicQueue Step 4: # Get the connection string for the namespace connectionString=$(az servicebus namespace authorization-rule keys list --resource-group $resourceGroupName --namespace-name $namespaceName --name RootManageSharedAccessKey --query primaryConnectionString --output tsv)
https://docs.microsoft.com/en-us ... -bus-quickstart-cli
NEW QUESTION # 218
You must ensure that the external party cannot access the data in the SSN column of the Person table.
Will each protection method meet the requirement? To answer, drag the appropriate responses to the correct protection methods. Each response may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
NEW QUESTION # 219
You need to configure Azure App Service to support the REST API requirements.
Which values should you use? To answer, select the appropriate options in the answer area.
Plan: Standard
Standard support auto-scaling
Instance Count: 10
Max instances for standard is 10.
Scenario:
The REST API's that support the solution must meet the following requirements:
* Allow deployment to a testing location within Azure while not incurring additional costs.
* Automatically scale to double capacity during peak shipping times while not causing application downtime.
* Minimize costs when selecting an Azure payment model.
https://azure.microsoft.com/en-u ... /app-service/plans/
NEW QUESTION # 220
You are developing an Azure-hosted application that must use an on-premises hardware security module (HSM) key.
The key must be transferred to your existing Azure Key Vault by using the Bring Your Own Key (BYOK) process.
You need to securely transfer the key to Azure Key Vault.
To perform a key transfer, a user performs following steps:
Generate KEK.
Retrieve the public key of the KEK.
Using HSM vendor provided BYOK tool - Import the KEK into the target HSM and exports the Target Key protected by the KEK.
Import the protected Target Key to Azure Key Vault.
Step 1: Generate a Key Exchange Key (KEK).
Step 2: Retrieve the Key Exchange Key (KEK) public key.
Step 3: Generate a key transfer blob file by using the HSM vendor-provided tool.
Generate key transfer blob using HSM vendor provided BYOK tool
Step 4: Run the az keyvault key import command
Upload key transfer blob to import HSM-key.
Customer will transfer the Key Transfer Blob (".byok" file) to an online workstation and then run a az keyvault key import command to import this blob as a new HSM-backed key into Key Vault.
To import an RSA key use this command:
https://docs.microsoft.com/en-us ... /byok-specification
NEW QUESTION # 221
If you want to get through the AZ-204 practice exam quickly with less time and efforts, our learning materials is definitely your best option. One or two days' preparation and remember the correct AZ-204 test answers, getting the certification will be simple for our candidates. Free trials of AZ-204 Exam PDF are available for everyone and great discounts are waiting for you. Join us and realize your dream.
Reliable AZ-204 Exam Camp: https://www.practicevce.com/Microsoft/AZ-204-practice-exam-dumps.html
BONUS!!! Download part of PracticeVCE AZ-204 dumps for free: https://drive.google.com/open?id=1QCriahCOxV5HBMwqaJ3EpfRklm7ICrfM
