AIBOX-K3 AI Vision Usage
Posted at 5/26/2026 17:35:48
View424
Replies0
Step 1:
Download the Bianbu firmware and flash it to the AIBOX-K3.
Firmware flashing tutorial link: https://wiki.t-firefly.com/en/AI ... tmode_spacemit.html
Step 2:
2.1 Obtaining the Code
Install the Git tool- sudo apt update
- sudo apt install git
Copy the code
This repository uses Git Submodules to manage the source code of each component; recursive fetching is recommended.
- git clone --recurse-submodules https://github.com/spacemit-com/model-zoo.git
- # or ssh
- # git clone --recurse-submodules git@github.com:spacemit-com/model-zoo.git
Copy the code
If you have already cloned the main repository but not the sub-repository:- cd model-zoo
- git submodule update --init --recursive
Copy the code
If you only want to compile a specific component in the SDK, you can navigate to the corresponding directory and execute `mm` (you also need to source `build/envsetup.sh` first):- source build/envsetup.sh
- cd vision && mm
Copy the code
The build artifacts are typically installed to output/staging (based on the SDK project).
3. Example Run
Note: The following examples assume you have already completed the one-click compilation as described above (the example executables will be installed in output/staging).
3.1 Computer Vision
Step 1: Download the Model. Download all vision example models (they will be placed in ~/.cache/models/vision/)- bash vision/scripts/download_all_models.sh
Copy the code
Step 2: Download resource files (images/videos). Download example image/video resources (they will be placed under ~/.cache/assets/)- bash vision/scripts/download_assets.sh
Copy the code
Default directories:
Models: ~/.cache/models/vision/
Resources: ~/.cache/assets/
Step 3: Run the Examples
The following are the commands to run all the examples under vision/examples/ (C++, which can be run directly in the SDK root directory after executing m):
- # Facial Recognition (Similarity)
- arcface vision/examples/arcface/config/arcface.yaml
- # Face detection
- yolov5-face vision/examples/yolov5-face/config/yolov5-face.yaml
- # Gesture detection
- yolov5_gesture vision/examples/yolov5_gesture/config/yolov5_gesture.yaml
- # Object Detection
- yolov8 vision/examples/yolov8/config/yolov8.yaml
- yolov11 vision/examples/yolov11/config/yolov11.yaml
- # Attitude estimation
- yolov8_pose vision/examples/yolov8_pose/config/yolov8_pose.yaml
- # Instance splitting
- yolov8_seg vision/examples/yolov8_seg/config/yolov8_seg.yaml
- # Image Classification / Emotion Recognition
- resnet vision/examples/resnet/config/resnet50.yaml
- emotion vision/examples/emotion/config/emotion.yaml
- # Multi-target tracking (video/camera)
- # The following two examples demonstrate real-time target tracking and require a screen connection; otherwise, an error will occur.
- bytetrack vision/examples/bytetrack/config/bytetrack.yaml
- ocsort vision/examples/ocsort/config/ocsort.yaml
Copy the code
Example results:
arcface
- root@firefly:/home/firefly/model-zoo# arcface vision/examples/arcface/config/arcface.yaml
- SpaceMIT EP initialized: /root/.cache/models/vision/arcface/arcface_mobilefacenet_cut.q.onnx
- ƶ: 0.1584
- ж: ͬһ
Copy the code yolov5-face
- root@firefly:/home/firefly/model-zoo# yolov5-face vision/examples/yolov5-face/config/yolov5-face.yaml
- Loading image: /root/.cache/assets/image/006_test.jpg
- SpaceMIT EP initialized: /root/.cache/models/vision/yolov5-face/yolov5n-face_cut.q.onnx
- Detected 3 face(s):
- face 1 score=0.812 box=[166.036,75.602,196.464,110.691]
- face 2 score=0.799 box=[44.460,117.240,65.123,145.286]
- face 3 score=0.748 box=[262.426,125.130,287.910,162.370]
- Result saved to: result_face.jpg
Copy the code
yolov5_gesture
- root@firefly:/home/firefly/model-zoo# yolov5_gesture vision/examples/yolov5_gesture/config/yolov5_gesture.yaml
- Warning: failed to load labels from: assets/labels/gesture.txt
- Loading image: /root/.cache/assets/image/012_gesture.jpg
- SpaceMIT EP initialized: /root/.cache/models/vision/yolov5/yolov5_gesture.q.onnx
- Detected 2 gesture(s):
- Class 0 (class 0) score=0.900 box=[809.209,762.571,923.803,915.754]
- Class 5 (class 5) score=0.815 box=[401.791,1386.415,469.781,1524.662]
- Result saved to: result_gesture.jpg
Copy the code
yolov8
- root@firefly:/home/firefly/model-zoo# yolov8 vision/examples/yolov8/config/yolov8.yaml
- SpaceMIT EP initialized: /root/.cache/models/vision/yolov8/yolov8n.q.onnx
- Detected 3 objects:
- Class 0, Score: 0.9169, Box: [0.5928,114.2840,85.0366,351.8688]
- Class 0, Score: 0.8943, Box: [230.9659,122.4463,315.6410,371.7448]
- Class 33, Score: 0.6868, Box: [64.7624,168.9862,247.7783,371.1805]
- Result image saved to: result.jpg
Copy the code
yolov11
- root@firefly:/home/firefly/model-zoo# yolov11 vision/examples/yolov11/config/yolov11.yaml
- SpaceMIT EP initialized: /root/.cache/models/vision/yolov11/yolo11n.q.onnx
- Detected 5 objects:
- 1: Class 0, Score: 0.8821, Box: [0.2121,114.1500,84.3134,352.4440]
- 2: Class 0, Score: 0.8821, Box: [230.5667,121.9574,315.4816,372.6761]
- 3: Class 0, Score: 0.5720, Box: [111.6640,48.7848,215.3329,269.6542]
- 4: Class 0, Score: 0.4291, Box: [6.0540,261.3405,14.3792,269.3897]
- 5: Class 33, Score: 0.6063, Box: [67.3937,236.3271,246.2147,372.6607]
- Result image saved to: yolo11_result.jpg
Copy the code
yolov8_pose
- root@firefly:/home/firefly/model-zoo# yolov8_pose vision/examples/yolov8_pose/config/yolov8_pose.yaml
- Running pose estimation...
- SpaceMIT EP initialized: /root/.cache/models/vision/yolov8_pose/yolov8n-pose.q.onnx
- Detected 1 persons with keypoints
- Result image saved to: yolov8_pose_result.jpg
Copy the code
yolov8_seg
- root@firefly:/home/firefly/model-zoo# yolov8_seg vision/examples/yolov8_seg/config/yolov8_seg.yaml
- Running instance segmentation...
- SpaceMIT EP initialized: /root/.cache/models/vision/yolov8_seg/yolov8n-seg.q.onnx
- Detected 4 objects with segmentation masks
- Result image saved to: yolov8_seg_result.jpg
Copy the code
resnet
- root@firefly:/home/firefly/model-zoo# resnet vision/examples/resnet/config/resnet50.yaml
- Loading image: /root/.cache/assets/image/005_kitten.jpg
- SpaceMIT EP initialized: /root/.cache/models/vision/resnet/resnet50.q.onnx
- Classification results:
- 1. tabby, tabby cat (confidence: 0.5056)
Copy the code
emotion
- root@firefly:/home/firefly/model-zoo# emotion vision/examples/emotion/config/emotion.yaml
- Loading image: /root/.cache/assets/image/003_face0.png
- SpaceMIT EP initialized: /root/.cache/models/vision/resnet/emotion_resnet50_final.q.onnx
- Emotion: neutral (class 0, score: 1.7003)
- Result saved to: result_emotion.jpg
Copy the code
For optional parameters for each example (such as --image, --video, --use-camera, --output, threshold, etc.), please refer to the README in the corresponding directory (vision/examples/*/README.md) or see the model-zoo-vision README.
