AIBOX-K3 Hermes Agent Application Usage
234
super moderator
Rank: 8Rank: 8
Posted at 6/3/2026 15:24:27
Hermes Agent (Cloud Compute)
Hermes Agent is an open-source AI agent framework that supports multiple LLM providers. It offers capabilities such as tool calling, scheduled tasks, MCP protocol support, and web access, and can be used from a terminal CLI or integrated into messaging platforms such as Telegram and Discord.
Platform Support
Platform & OSSupported
K1 Buildroot❌ No
K1 OpenHarmony❌ No
K1 Bianbu LXQT/GNOME✅ Yes
K3 Buildroot❌ No
K3 OpenHarmony❌ No
K3 Bianbu LXQT/GNOME✅ Yes
Installation
Option 1: apt Installation (Recommended)
Install it directly through apt on Bianbu OS:
  1. sudo apt update
  2. sudo apt install hermes-agent
Copy the code
After installation, you can run the hermes command directly without any additional environment configuration.
Option 2: Source Installation (For Developers)
This method is intended for users who need to modify the codebase or contribute to development.
Prerequisites
  • Python 3.11+ (uv will download it automatically)
  • libffi8 (runtime library, included in the system)
  • libffi-dev headers (must be extracted manually, see below)
1. Clone the Repositor
  1. git clone https://github.com/NousResearch/hermes-agent.git
  2. cd hermes-agent
Copy the code
2. Install uv
  1. curl -LsSf https://astral.sh/uv/install.sh | sh
  2. source ~/.bashrc
Copy the code
3. Extract libffi-dev Headers
Building cffi and cryptography on riscv64 requires ffi.h, but the system includes only the runtime library and not the header files. Use apt-get download to fetch the .deb package without installing it or requiring sudo, then extract the headers with dpkg-deb -x:
  1. apt-get download libffi-dev
  2. mkdir -p /tmp/libffi-dev
  3. dpkg-deb -x libffi-dev_*.deb /tmp/libffi-dev
Copy the code
/tmp/libffi-dev is removed after a reboot. If you need to reinstall dependencies, run this step again. Existing virtual environments are not affected.
4. Create a Virtual Environment and Install Dependencies
  1. cd hermes-agent
  2. export PKG_CONFIG_PATH="/tmp/libffi-dev/usr/lib/riscv64-linux-gnu/pkgconfig:$PKG_CONFIG_PATH"
  3. export C_INCLUDE_PATH="/tmp/libffi-dev/usr/include/riscv64-linux-gnu:$C_INCLUDE_PATH"
  4. export CPATH="/tmp/libffi-dev/usr/include/riscv64-linux-gnu:$CPATH"
  5. export LIBRARY_PATH="/tmp/libffi-dev/usr/lib/riscv64-linux-gnu:$LIBRARY_PATH"
  6. uv venv venv --python 3.11
  7. source venv/bin/activate
  8. uv pip install -e ".[cron,cli,dev,mcp,web]"
Copy the code
The voice and messaging extras have limitations on riscv64. See Unavailable Features for details.
Configuration
1. Configure the API Key
Edit ~/.hermes/.env (generated automatically on first run, or create it manually). The following example uses the MiniMax China endpoint.
  1. MINIMAX_CN_API_KEY=your_key_here
  2. MINIMAX_CN_BASE_URL=https://api.minimaxi.com/v1
Copy the code
For a source installation, you can also edit the .env file directly under the project directory:
  1. cp .env.example .env
Copy the code
2. Configure the Model
Edit ~/.hermes/config.yaml (generated automatically on first run, or create it manually):
  1. model:
  2.   default: MiniMax-M2.7-highspeed
  3.   provider: custom
  4.   base_url: https://api.minimaxi.com/v1
  5.   api_mode: chat_completions
  6. custom_providers:
  7. - name: minimax-cn
  8.   base_url: https://api.minimaxi.com/v1
  9.   api_key: your_key_here
  10.   api_mode: chat_completions
  11.   model: MiniMax-M2.7-highspeed
Copy the code
The MiniMax API accepts only the plain model name, for example MiniMax-M2.7-highspeed. Provider-prefixed formats such as minimax-cn/MiniMax-M2.7-highspeed are not supported.
Start the Agent
For an apt installation, run:
  1. hermes
Copy the code
For a source installation, activate the virtual environment each time you open a new terminal:
  1. cd hermes-agent
  2. source venv/bin/activate
  3. ./hermes
Copy the code
Supported LLM Providers
Set the corresponding key in .env to switch providers.
ProviderEnvironment Variable
OpenRouterOPENROUTER_API_KEY
Google GeminiGOOGLE_API_KEY
Kimi / MoonshotKIMI_API_KEY
MiniMax (Global)MINIMAX_API_KEY
MiniMax (China)MINIMAX_CN_API_KEY
GLM / z.aiGLM_API_KEY
Hugging FaceHF_TOKEN
The following features are currently unavailable because of riscv64 platform limitations:
FeatureReason
voice (speech recognition)ctranslate2 has no riscv64 wheel; faster-whisper depends on it
Local STT (speech-to-text)Same as above
messaging Discord encryptionpynacl depends on cffi and is skipped because libffi headers are unavailable
Messaging Feature (Optional)
The messaging feature allows Hermes Agent to connect to messaging platforms such as Telegram, Discord, Slack, WhatsApp, Signal, and Matrix. After configuring the bot token for the target platform, you can interact with the agent directly from those applications.
To enable it in a source installation, first set the libffi environment variables, and then install it separately:
  1. export PKG_CONFIG_PATH="/tmp/libffi-dev/usr/lib/riscv64-linux-gnu/pkgconfig:$PKG_CONFIG_PATH"
  2. export LIBRARY_PATH="/tmp/libffi-dev/usr/lib/riscv64-linux-gnu:$LIBRARY_PATH"
  3. export CPATH="/tmp/libffi-dev/usr/include/riscv64-linux-gnu:$CPATH"
  4. source venv/bin/activate
  5. uv pip install -e ".[messaging]"
Copy the code
Start the messaging gateway:
  1. ./hermes gateway
Copy the code
