Posted at 6/25/2026 13:55:31
The problem was solved by removing the module, blowing it out and degreasing the ASM1074(gpio control is not required - POR_N is pulled up via a resistor) components.
linaro@bm1684:~$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 10000M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M <- was absent previously
|__ Port 2: Dev 3, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M |
