New Topic
RK3288 + ov13850 camera module => RAW
142
Rank: 8Rank: 8
Posted at 12/13/2015 23:51:49      View8074 | Replies14        Print      Only Author   [Copy Link] 1#
Hi,
Is there a way to retrieve RAW images from the camera module using android 5.1?
many thanks,
vip
Rank: 6Rank: 6
Posted at 12/18/2015 09:10:02        Only Author  2#
have a look at  : hardware/rockchip/camera/CameraHal/
Rank: 8Rank: 8
Posted at 12/18/2015 19:07:10        Only Author  3#
Is this the path to the driver sources or a location on where I can find a temporary raw file?
vip
Rank: 6Rank: 6
Posted at 12/19/2015 11:26:15        Only Author  4#
grep the raw keyword you can find out and analys it by youself
Posted at 9/26/2017 00:24:25        Only Author  5#
Hi.
Like Macdam, I'm also looking for RAW format.
As a java/android developer, i'm not satisfied by Zhansb reply.
calling camera1 api  :
  1. camera.getParameters().getSupportedPictureFormats()
Copy the code
returns only one value ==> 256 which is the JPEG format as documented in android SDK (https://developer.android.com/re ... cs/ImageFormat.html)
Is there any plan to support RAW/YUV format ?
Is there any workaround to get this format?
Posted at 10/27/2017 06:21:16        Only Author  6#
I was able to get a "raw" (YUV422)  picture with android 5.1 running on a rk3288.
The Camera.takePicture() method takes a callback for raw as second parameter.
  1. camera.takePicture ( shutterCallback, rawCallback, jpegCallback );
Copy the code
This callback will return a null byteArray, unless you explicitly add a buffer for raw image .
  1. addRawImageCallbackBuffer.invoke(camera, bytes);
Copy the code
Surprisingly,  the method is public but not exported, so you cannot call it directly.
The pseudo-code below demonstrate how to call it by reflection.
  1. ...
  2. byte[] bytes = new byte[100000000]);
  3. android.hardware.Camera  camera = Camera.Open();
  4. ...
  5.    try {
  6.         final Method addRawImageCallbackBuffer =
  7.                 camera.getClass()
  8.                        .getDeclaredMethod("addRawImageCallbackBuffer",
  9.                                           byte[].class);
  10.         addRawImageCallbackBuffer.invoke(camera0, bytes);
  11.     } catch (Exception e) {
  12.         Log.e("RNG", "Error", e);
  13.     }
  14. ...
  15. camera.takePicture ( shutterCallback, rawCallback, jpegCallback );
  16. ...
Copy the code
For reference : https://stackoverflow.com/questi ... and-raw-takepicture
Posted at 11/3/2017 00:17:23        Only Author  7#
I have similar need for raw preview format. Currently preview only support NV21 and Yv12.
Posted at 1/10/2026 00:48:50        Only Author  8#
VMware 3V0-21.23 һI֪RͼܵJCԇITИIҹܶYԴԇrЩVMwarePIJCCVMware 3V0-21.23JCC@Ȼĸ
Posted at 1/15/2026 13:27:56        Only Author  9#
Absolutely worthy of a like, no hesitation. The 220-1101 valid study guide files exam questions are the foundation for your career growthget them for free!
Posted at 1/16/2026 01:43:33        Only Author  10#
ZertSoft ist eine Website, die Prfungsressourcen den IT-leuten , die sich an der Salesforce Salesforce-Media-Cloud Zertifizierungsprfung (Salesforce Media Cloud Accredited Professional (AP) Exam) beteiligen, bieten. Es gibt verschiedene Schulungsmethoden und Kurse fr verschiedene Studenten. Mit der Ausbildungmethode von ZertSoft können die Studenten die Prfung ganz leicht bestehen. Viele Kandidaten, die sich an der IT-Zertifizierungsprfung beteiligt haben, haben die Salesforce Salesforce-Media-Cloud Zertifizierungsprfung (Salesforce Media Cloud Accredited Professional (AP) Exam) mit Hilfe der Prfungsfragen und Antworten von ZertSoft sehr erfolglich abgelegt. So genießt ZertSoft einen guten Ruf in der IT-Branche.
Return to List
12
