New Topic
¡¾update£¡¡¿Firefly-RK3288 Android5.1 SDK update£¡
1661
administrator
Rank: 9Rank: 9Rank: 9
Posted at 1/7/2016 15:21:03      View£º16043 | Replies£º20        Print      Only Author   [Copy Link] 1#
SDK Download£ºfirefly-rk3288_android5.1_git_20150910.tar
Firmware Download£ºFireFly-RK3288_Android5.1_201512311008.7z
Update instructions:
1.Improve system stability
2.Optimization settings display interface
3.Update vpu driver
4.Update gpu driver
5.Update video decoding
6.Update the system apk
7.support VGA and HDMI dual display
Reviews
Great news! We need this ffmpeg and librkffplayer updated for run 15.2 kodi... but thanks firefly team for this update!  Posted at 1/12/2016 21:26
Posted at 3/25/2016 11:43:37        Only Author  recommend
leungtek Posted at 3/25/2016 11:39
open CONFIG_ANDROID_PARANOID_NETWORK from menuconfig for ubuntu kernel .
wifi will be able to int ...
is turn off , not open . My mistake
Posted at 1/8/2016 02:16:10        Only Author  2#
Thanks very much.
Is it possible to fix the following bugs.
1. Bluetooth Headset Mic not working.
Solution is to disable internal mic first to route sound through Bluetooth headset mic.
Soundabout app from Google Play Store can do this correctly.
2. On some 4K TV's UHD resolution setting in Android Settings, Display causes users to get a black screen.
3. Feature - Use Ethernet connection but trick Android system to believe it is actually a wifi connection.
On Android KitKat you could install Xposed Framework and 'Fake Wifi' v1.7 module to do this.
This helps to download big games from Google Play Store that only download through a wifi connection.
It also helps some streaming apps that only work on phones/tablets with a wifi connection and not work with an ethernet connection.
4. Feature - Support for Xpoesed Framework Lollipop edition.
To install different modules to give Android extra features.
5.Hide HDMI State, set it to '0' instead of '1' permanently - Some streaming apps only work on phones/tablets without an HDMI connection.
6. On some TV's like Phillips users get  green/purple screen colors on their TV's
7. Feature - TVHeadend support library & tv tuner modules and startup script to load modules.
8. USB Keyboard repeating keys bug. I'm not sure if this is fixable.
Posted at 1/10/2016 15:54:54        Only Author  3#
Please add 'Multi Window' Light Biz Os support.
It is included in the Firefly SDK but is not accessible in Display Settings.
Also FFMPEG and librkffplayer.so are very old libraries and don't support Kodi 15.2 or Kodi 16 with pass-through support.
Posted at 1/13/2016 02:10:16        Only Author  4#
How to make the IR Remote buttons work on Lollipop?
Home button & OK button doesn't work.
Posted at 1/13/2016 16:53:42        Only Author  5#
dewet Posted at 1/13/2016 02:10
Official remote control can be normal use£¬there is something wrong with your remote£¿
Posted at 1/16/2016 08:34:09        Only Author  6#
Please also add Fireasy support.
Posted at 1/19/2016 19:01:30        Only Author  7#
Great work! Also saw that you added ubuntu switch. Is there an easy way to make a dualboot lollipop/ubuntu image? Or can you release such a dualboot image?
That would help me in making a machybris/mackodi release based on lollipop...
Thanks in advance!
ÒÑÓÐ 1ÆÀ·ÖPrestige +2 Pack up reason
psycmos + 2
View all ratings
Posted at 1/20/2016 14:10:06        Only Author  8#
mac_l1 Posted at 1/19/2016 19:01
Great work! Also saw that you added ubuntu switch. Is there an easy way to make a dualboot lollipop/ ...
Never mind. Just made a lollipop dualboot img myself.
For those interested: had to change the kernel a bit by patching the volname attribute part of the following commit in kernel sources, see https://github.com/TeeFirefly/li ... bf65c63cb5c6911a0cb. Also turn on: CONFIG_VT=y in your kernel config file.
Then of course configure the right dualboot image to generate an update.img.
Posted at 1/21/2016 10:49:18        Only Author  9#
Great release .
And It is DualBoot Firefly with newest lollipop/ubuntu .
https://mega.nz/#!UokGTTCB
!XcaDmJy1sS_5yuukHDPHVZPWeqvtHhYGn_ZPl8-bXgs
ÒÑÓÐ 1ÆÀ·ÖPrestige +10 Money +11 Contribution +12 Pack up reason
psycmos + 10 + 11 + 12
View all ratings
Posted at 1/24/2016 15:29:29        Only Author  10#
leungtek Posted at 1/21/2016 10:49
Great release .
Hi
Which kernel & resource.img(second) do you use for the Lubuntu part of the firmware?
I want to replace the wifi with AP6335 wifi with different GPIO and add different IR Remote.
Also want to add RK1000 sound driver to kernel.
If I use unmkbootimg on linux-boot.img, rename second to resource.img and unpack rk-kernel.dts and make changes, repack and flash back it doesn't boot.
I will try again.
Return to List
12
