Did you try to use screenrecord from adb shell in lollipop?
53
Posted at 4/6/2016 08:30:06      View6544 | Replies8        Print      Only Author   [Copy Link] 1#
i've finished the recording with following command.
(sceenrecord --verbose --time-limit 5 /sdcard/recvid.mp4 )
But  when trying to play the recorded file with video player, screen is always green.
How to solve this?
Firmware: lollipop(Firefly-RK3288_Android4.4_201602251453.7z)
adb logs:
01-02 07:12:19.864 2287-2291/? I/OMXClient: Using client-side OMX mux.
01-02 07:12:19.866 2287-2290/? V/MediaCodec: Found 0 pieces of codec specific data.
01-02 07:12:19.868 2287-2291/? W/ACodec: do not know color format 0x7f000789 = 2130708361
01-02 07:12:19.869 2287-2291/? I/ACodec: setupVideoEncoder succeeded
01-02 07:12:19.870 2287-2291/? W/ACodec: do not know color format 0x7f000789 = 2130708361
01-02 07:12:19.871 168-501/? D/OMXNodeInstance:    <void android::OMXNodeInstance::setGraphicBufferSource(const android::sp<android::GraphicBufferSource>&)>_211     mFrameRate = 60
01-02 07:12:19.871 168-501/? D/GraphicBufferSource:     danielycycyc   GraphicBufferSource::setFrameRate()_112  interval_time = 16(16666666)  mFrameRate = 60
01-02 07:12:19.872 2287-2290/? V/MediaCodec: input buffers allocated
01-02 07:12:19.873 168-2292/? E/ROCKCHIP_VIDEO_ENC: EncParam.framerate  = 60 outPort->sPortParam.format.video.xFramerate = 3932160 4000000
01-02 07:12:19.873 168-2292/? E/ROCKCHIP_VIDEO_ENC: ConvertOmxAvcLevelToAvcSpecLevel: 512
01-02 07:12:19.873 168-2292/? D/pv_avcenc_api: cml->cabacintIdc  0 cml->enablaCabac 0 cml->intraPicRate 30
01-02 07:12:19.873 2287-2290/? V/MediaCodec: output buffers allocated
01-02 07:12:19.874 168-2292/? D/pv_avcenc_api: init intraPeriodCnt 30
01-02 07:12:19.875 2287-2290/? V/MediaCodec: codec output format changed
01-02 07:12:19.891 2287-2287/? I/MPEG4Writer: limits: 4294967295/0 bytes/us, bit rate: -1 bps and the estimated moov size 3072 bytes
01-02 07:12:19.969 2287-2297/? I/MPEG4Writer: setStartTimestampUs: 4842810320
01-02 07:12:19.969 2287-2297/? I/MPEG4Writer: Earliest track starting time: 4842810320
01-02 07:12:24.754 457-1380/? D/ConnectivityManager.CallbackHandler: CM callback handler got msg 524298
01-02 07:12:24.755 457-1380/? D/ConnectivityManager: expireRequest with 120, 119
01-02 07:12:24.933 168-168/? W/GraphicBufferSource: Dropped back down to Loaded without Executing
01-02 07:12:24.938 2287-2287/? D/MPEG4Writer: Video track stopping
01-02 07:12:24.939 2287-2287/? D/MPEG4Writer: Video track source stopping
01-02 07:12:24.939 2287-2287/? D/MPEG4Writer: Video track source stopped
01-02 07:12:24.939 2287-2297/? I/MPEG4Writer: Received total/0-length (131/0) buffers and encoded 131 frames. - Video
01-02 07:12:24.939 2287-2287/? D/MPEG4Writer: Video track stopped
01-02 07:12:24.939 2287-2287/? D/MPEG4Writer: Stopping writer thread
01-02 07:12:24.940 2287-2296/? D/MPEG4Writer: 0 chunks are written in the last batch
01-02 07:12:24.940 2287-2287/? D/MPEG4Writer: Writer thread stopped
01-02 07:12:24.942 2287-2287/? D/MPEG4Writer: Video track stopping
01-02 07:12:25.113 2300-2300/? D/AndroidRuntime: >>>>>> START com.android.internal.os.RuntimeInit uid 0 <<<<<<
01-02 07:12:25.116 2300-2300/? D/AndroidRuntime: CheckJNI is OFF
01-02 07:12:25.116 2300-2300/? I/AndroidRuntime: JNI options: '-Xjniopts:warnonly'
01-02 07:12:25.169 2300-2300/? E/memtrack: Couldn't load memtrack module (No such file or directory)
01-02 07:12:25.169 2300-2300/? E/android.os.Debug: failed to load memtrack module: -2
01-02 07:12:25.196 2300-2300/? D/AndroidRuntime: Calling main entry com.android.commands.am.Am
01-02 07:12:25.200 571-571/? D/MediaScannerReceiver: action: android.intent.action.MEDIA_SCANNER_SCAN_FILE path: /mnt/internal_sd/recvid.mov
01-02 07:12:25.204 2300-2300/? D/AndroidRuntime: Shutting down VM
01-02 07:12:25.436 2287-2287/? D/ScreenRecord: success
01-02 07:12:44.810 457-484/? D/Tethering: TetherModeAliveState.processMessage what=4
01-02 07:12:44.810 457-484/? D/ConnectivityManager: renewing startUsingNetworkFeature request NetworkRequest [ id=3, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ]
01-02 07:12:44.811 457-484/? D/ConnectivityManager: renewing request to seqNum 121
01-02 07:12:44.811 457-484/? D/ConnectivityManager: sending expire msg with seqNum 121 and delay 60000
Posted at 1/15/2026 00:06:33        Only Author  2#
This is a truly magnificent article, thank you for sharing your thoughts. Get the Valid AD0-E137 real test exam materials for freeyour path to career success and salary increases!
Posted at 1/19/2026 05:20:28        Only Author  3#
ԇYˤ˺ϸ񤹤ϤϡNSE7_OTS-7.2ʂ䥬ɤmǤयΥ``ϡѧ֕rgޤʤȤ֪äƤޤˌꤷơǩ`ݤѧĤOޤƬĤʕrgʹäѧ뤳ȤǤ1֤Ȥ˄ޤ NSE7_OTS-7.2ԇY}ݤ򱾵Ǥ褦ˡѧӋ{ޤѧӋϡʤ¤ˤ󤭤Ӱ푤뤨Ԥޤ NSE7_OTS-7.2ѧɤ20〜30rgؤѧƤޤꡢNSE7_OTS-7.2ԇYMळȤǤޤ
Posted at 1/21/2026 03:26:30        Only Author  4#
This article is absolutely remarkable, Im so thankful for your share. Get free CWSP-208 valid test guide files to enhance your IT expertise. Wishing you success!
Posted at 1/22/2026 06:40:21        Only Author  5#
{飬FITИIJCԇд녢ӵSAPC-P2W43-2023ԇ_@һdzҪĿԇ@ԇѽ_JCˡ⣬@ԇYC˸߼ܡȻͿԇҪһӣ@ԇҲǷdzyġҪͨ^ԇǺyģՈҪġKaoGuTiԎͨ^yC-P2W43-2023JCԇ
Posted at 1/23/2026 02:57:22        Only Author  6#
Thank you for bringing this shocking article! Im about to take the Guide HPE7-A03 torrent exam C I need all the good vibes!
Posted at 2/17/2026 15:59:00        Only Author  7#
그렇게 많은 IT인증덤프공부자료를 제공하는 사이트중assTIP의 인지도가 제일 높은 원인은 무엇일가요?그건assTIP의 제품이 가장 좋다는 것을 의미합니다. PassTIP에서 제공해드리는 Cisco인증 100-140덤프공부자료는Cisco인증 100-140실제시험문제에 초점을 맞추어 시험커버율이 거의 100%입니다. 이 덤프만 공부하시면Cisco인증 100-140시험패스에 자신을 느끼게 됩니다.
